Some video evidences of explosives in Twin Tower collapse
Old January 12th 04, 03:06 AM
Bjørnar Bolsøy
Alan Minyard wrote in
On Sat, 10 Jan 2004 16:31:30 -0500, kirill
just to have a break in hot and very productive discussions
of Pentagon missing 757 let's look at WTC collapse:
http://vancouver.indymedia.org/print.php?id=56715
Michael
To anyone who is even slightly familiar with the construction of
the towers the symmetry of the collapse was quite predictable,
given the damage they sustained. These conspio-whacko theories
are simply ridiculous.
I agree, but the secrecy, misinformation and almost complete
absence of any thorough fullscale investigation into the attacks
and the physics behind collapse of the buildings to me is
disturbing, and seems precisely why conspiricy theories are
allowed to flourish.
Regards...
Old January 12th 04, 04:27 AM
Bjørnar Bolsøy
On Sat, 10 Jan 2004 21:17:22 GMT, "Bjørnar Bolsøy"
Mark and Kim Smith wrote in
Well sure there were explosives. It's called jet fuel and
oxygen. These folks really need to learn how those building
were built before they start coming up with these dumb
theories.
Is it likely to assume that the fuel burned up in the explosion
when the airplane impacted?
Regards...
No, there would be a great deal of fuel remaining. Remember that
the "explosion" would rob itself of Oxygen.
Looking at the video of the south tower impact, doesn't the huge
fireball outside the building seem to suggest that much, if not
most, of the fuel burned up on the outside?
Regards...
Old January 12th 04, 10:32 AM
Keith Willshaw
"Bjørnar Bolsøy" wrote in message
The fuel on the aircraft perhaps but the trouble is there was large
fuel load in the building in the form of furniture, carpets, paper
computers etc. The fireball ignited all of that fuel simultaneously
and the impact destroyed fireproof partitions and knocked
the fireprrofing off the floor struts. It was the heat from the subsequent
fire that cause those struts to fail. Once they had done so the bracing
between the outer wall and inner core that was essential to the
strength of the building was lost and outer skin failed in buckling.
The damager inner core was unable to tale the extra stress and also
failed.
This sequence can be clearly seen in the video footage.
Keith
Old January 12th 04, 11:00 PM
Bjørnar Bolsøy
Michael
After reading through much of the updates on the current
NIST investigation I need to retract part of that statement.
A new technical progress report based on substantial scrutiny
of the disaster is out in a short while, it will surely
address many of the conspiracy allegations with new and much
more solid data.
http://wtc.nist.gov/
Regards...
Old January 12th 04, 11:39 PM
Pete
To me it seems that the "office fire" theory leaves enough
unanswered questions to warrant deeper studies. Not at least because
there has been serious fires in high raised steel buildings before
and none has ever caused any collapse.
None have ever been hit by an aircraft of that size, with that much fuel on
board before.
Pete
Old January 13th 04, 12:23 AM
Chad Irby
Nothing like this, especially with a start of a few thousand pounds of a
major accelerant *plus* major physical damage to the building as the
fire started.
The closest we've seen was the B-25 that hit the Empire State Building,
and that was an order of magnitude less serious to begin with.
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Old January 13th 04, 12:28 AM
Keith Willshaw
None of the those fires involved major damage to
the structure before the fire and had several flloors
burning simultaneoulsy.
The WTC could have survided either the impact
or the fire, what it couldnt handle was both.
Keith
turbo video Peter Holm Aerobatics 13 September 30th 04 12:31 AM
Aviation Video: Another F-16 bites the dust Iwan Bogels Instrument Flight Rules 0 September 21st 04 08:02 AM
In-Flight Video Ron Wanttaja Home Built 11 May 16th 04 07:11 AM
twin tail questions Kevin Horton Home Built 12 January 2nd 04 04:21 PM
SR-71 Video Dave Jones Military Aviation 0 November 10th 03 09:00 PM
