#21
On Dec 9, 11:22*pm, Mike wrote:
StrategyPage.com December 2, 2009 The Melting Deck Plates Muddle by James Dunnigan Earlier this year, the U.S. Navy discovered that the heat from the MV-22's gas turbine engines, which blow their exhaust right on to the deck of the LHD while waiting to take off, caused high enough temperatures to the steel under the deck plates, to possibly warp the understructure. This was already a known potential problem with the new F-35B vertical takeoff jet fighter. So now the Navy has two hot new aircraft that require an innovative solution to the melting deck problem. The Navy also discovered that the exhaust heat problem varied in intensity between different classes of helicopter carriers (each with a different deck design.) The Navy is looking for a solution that will not require extensive modification of current carrier decks. This includes a lot of decks, both the eleven large carriers, and the ten smaller LHAs and LHDs. This is shaping up as another multi-billion dollar "oops" moment, as the melting deck problem was never brought up during the long development of either aircraft. Previously, the Harrier was the only aircraft to put serious amounts of heat on the carrier deck, but not enough to do damage. But when you compare the Harrier engine with those on the V-22 and F-35B, you can easily see that there is a lot more heat coming out of the two more recent aircraft. Someone should have done the math before it became a real problem. Here is the problem laid out in numbers F-35 and V-22: Keeping it Cool on Deck Posted by Graham Warwick at 6/24/2009 8:43 AM CDT We've heard how the stealthy F-22 and F-35 are flying thermos bottles, struggling under the huge heat loads imposed by their powerful engines and systems. Well it seems the latest generation of vertical-lift aircraft is turning the flight decks of US Navy amphibious assault ships into frying pans. blog post photo Photo: US Navy The initial culprit is the MV-22 tiltrotor, but the big concern is the STOVL F-35B, which is due on deck after 2012. With nacelles tilted and rotors turning, hot exhaust from the Osprey's engines is buckling the decks, and Navy studies warn repeated buckling will cause deck failure at 40% of planned ship life. F-35B exhaust plumes are expected to have a "severe thermo-mechanical impact" on the structure and non-skid surface of the flight deck. That's according to a new solicitation from the Office of Naval Research, which is looking for new ideas for flight deck thermal management. The solicitation is looking for alternatives to a DARPA/ ONR program that is already looking at "cooled heat pipe technologies" to overcome the thermal issues. It's not a trivial problem. For the MV-22, where the exhausts are close to the deck when the nacelles are vertical, buckling has been observed after just 10min of sitting on the deck, rotors turning. The F-35B will be in STOVL mode for a fraction of that time, but is expected to cause even more heating of the deck. ONR is looking for thermal management technologies that can keep the deck surface temperature below 300ºF when exposed to MV-22 exhaust plumes for 90 minutes before takeoff, and F-35B exhaust plumes for 2 minutes when landing. And cooling the deck is not enough - any solution has to be compatible with the deck's non-skid coating. It also has to be affordable and capable of being installed below deck or retrofitted above deck. Tall order. blog post photo Photo: Lockheed Martin Based on measurements taken during recent hover-pit tests, Lockheed Martin does not believe there will be an issue with deck temperatures. One acknowledged area of concern is the combined auxiliary/emergency powerpack, or IPP, which exhausts downwards on the STOVL aircraft. (It exhausts upwards on the F-35C carrier variant to protect deck crew, but downwards on the F-35B and CTOL F-35A to save weight and gain fuel volume.) The IPP has two modes: bleed and bleed-and-burn. In bleed mode the exhaust is relatively cool, Lockheed says. In bleed-and-burn, fuel is burned in the IPP to generate more power, and exhaust temperature rises. Because of operator concerns about surface heating, Lockheed says the pilot will have the ability to switch the IPP back to bleed mode if holding on the runway, or deck. http://www.aviationweek.com/aw/blogs...6-08049291946b |
"Mark Borgerson" wrote in message ... Maybe they need the mil-spec version of the nanoparticle insulating paint: AFAIK, that stuff is snake oil. Vaughn |
On Thu, 10 Dec 2009 15:53:26 +0200, "Roger Conroy"
wrote: "Bill Kambic" wrote in message .. . On Thu, 10 Dec 2009 02:57:36 -0800 (PST), Jack Linthicum wrote: snipped for brevity Or use the rocket launch technique and spray water across the take-off area. Probably less than optimal. Large clouds of hot, salt water steam would be an annoyance (at a minimum) to the deck crew. It would also be a highly corrosive material that could serious complicate maintenance of both ship and aircraft. Use of fresh water would likely be an excessive demand on the evaporators. The piping of cooling water suggested earlier would be a better idea. It would likely be cheaper that major modifications such as a "ski jump" and permit the continued use of the vertical capability of the aircraft. A water cooled heatsink built into a part of the deck designated for "hot" aircraft makes a lot of sense. Indeed. And since naval architects know a LOT about piping cooling water for lots of stuff the area could be quite large giving use for most, if not all, of the deck. That's a major boost for opertional efficiency. |
On Dec 10, 8:53*am, "Roger Conroy"
wrote: "Bill Kambic" wrote in message ... On Thu, 10 Dec 2009 02:57:36 -0800 (PST), Jack Linthicum wrote: snipped for brevity Or use the rocket launch technique and spray water across the take-off area. Probably less than optimal. *Large clouds of hot, salt water steam would be an annoyance (at a minimum) to the deck crew. *It would also be a highly corrosive material that could serious complicate maintenance of both ship and aircraft. Use of fresh water would likely be an excessive demand on the evaporators. The piping of cooling water suggested earlier would be a better idea. It would likely be cheaper that major modifications such as a "ski jump" and permit the continued use of the vertical capability of the aircraft. A water cooled heatsink built into a part of the deck designated for "hot" aircraft makes a lot of sense. You could have a place underneath to stash beer, like the old sub- mariners did. |
On Dec 10, 7:24 am, Jack Linthicum
wrote: On Dec 10, 8:53 am, "Roger Conroy" wrote: "Bill Kambic" wrote in message .. . On Thu, 10 Dec 2009 02:57:36 -0800 (PST), Jack Linthicum wrote: snipped for brevity Or use the rocket launch technique and spray water across the take-off area. Probably less than optimal. Large clouds of hot, salt water steam would be an annoyance (at a minimum) to the deck crew. It would also be a highly corrosive material that could serious complicate maintenance of both ship and aircraft. Use of fresh water would likely be an excessive demand on the evaporators. The piping of cooling water suggested earlier would be a better idea. It would likely be cheaper that major modifications such as a "ski jump" and permit the continued use of the vertical capability of the aircraft. A water cooled heatsink built into a part of the deck designated for "hot" aircraft makes a lot of sense. You could have a place underneath to stash beer, like the old sub- mariners did. In electronics, we have similiar problems, we usually solve using Al heat sinks, fan air cooled, as the cheapest. Screw a few Al heat sinks to the bottom of the locations of the deck permited to take the heat and engage any fluid to cool it, even water if space is tight, yawn. Ken |
On Dec 10, 2:00*pm, "Ken S. Tucker" wrote:
On Dec 10, 7:24 am, Jack Linthicum wrote: On Dec 10, 8:53 am, "Roger Conroy" wrote: "Bill Kambic" wrote in message .. . On Thu, 10 Dec 2009 02:57:36 -0800 (PST), Jack Linthicum wrote: snipped for brevity Or use the rocket launch technique and spray water across the take-off area. Probably less than optimal. *Large clouds of hot, salt water steam would be an annoyance (at a minimum) to the deck crew. *It would also be a highly corrosive material that could serious complicate maintenance of both ship and aircraft. Use of fresh water would likely be an excessive demand on the evaporators. The piping of cooling water suggested earlier would be a better idea. It would likely be cheaper that major modifications such as a "ski jump" and permit the continued use of the vertical capability of the aircraft. A water cooled heatsink built into a part of the deck designated for "hot" aircraft makes a lot of sense. You could have a place underneath to stash beer, like the old sub- mariners did. In electronics, we have similiar problems, we usually solve using Al heat sinks, fan air cooled, as the cheapest. Screw a few Al heat sinks to the bottom of the locations of the deck permited to take the heat and engage any fluid to cool it, even water if space is tight, yawn. Ken Troll them in the water, saves having all those pipes. |
#28
Bill Kambic wrote in
: On Thu, 10 Dec 2009 15:53:26 +0200, "Roger Conroy" wrote: A water cooled heatsink built into a part of the deck designated for "hot" aircraft makes a lot of sense. Indeed. And since naval architects know a LOT about piping cooling water for lots of stuff the area could be quite large giving use for most, if not all, of the deck. That's a major boost for opertional efficiency. Just take a Mk7 JBD and mount it appropriately. It probably would not need the hydraulics to raise/lower as for conventional takeoffs. scott s. .. |
#29
On Dec 10, 2:23*am, Dan wrote:
David E. Powell wrote: On Dec 9, 11:22 pm, Mike wrote: StrategyPage.com December 2, 2009 The Melting Deck Plates Muddle by James Dunnigan Earlier this year, the U.S. Navy discovered that the heat from the MV-22's gas turbine engines, which blow their exhaust right on to the deck of the LHD while waiting to take off, caused high enough temperatures to the steel under the deck plates, to possibly warp the understructure. This was already a known potential problem with the new F-35B vertical takeoff jet fighter. So now the Navy has two hot new aircraft that require an innovative solution to the melting deck problem. The Navy also discovered that the exhaust heat problem varied in intensity between different classes of helicopter carriers (each with a different deck design.) The Navy is looking for a solution that will not require extensive modification of current carrier decks. This includes a lot of decks, both the eleven large carriers, and the ten smaller LHAs and LHDs. This is shaping up as another multi-billion dollar "oops" moment, as the melting deck problem was never brought up during the long development of either aircraft. Previously, the Harrier was the only aircraft to put serious amounts of heat on the carrier deck, but not enough to do damage. But when you compare the Harrier engine with those on the V-22 and F-35B, you can easily see that there is a lot more heat coming out of the two more recent aircraft. Someone should have done the math before it became a real problem. Make a designated VTOL area and add shuttle style tiles there. * *It wouldn't stand up to mechanical abuse. While the tiles will withstand heat they would crumble under the weight of taxiing aircraft and deck vehicles. Dan, U.S. Air Force, retired- Hide quoted text - - Show quoted text - Use carbon composite plates. They're the materials on the wingtips (not the infamous bottom that killed Columbia). Those are more heat resistant, and less brittle if I'm not mistaken. |
#30
wrote: In electronics, we have similiar problems, we usually solve using Al heat sinks, ... Ken- In my country we put the electronics on the other end of the airplane. |
| Thread Tools | |
| Display Modes | |
| Flight deck queens | Michael Huber[_2_] | Aviation Photos | 2 | January 19th 08 07:38 AM |
| Kiev's deck - with Yak-36s and Ka-25s | Dave Kearton | Aviation Photos | 0 | March 2nd 07 07:12 AM |
| Ka-25s on Kiev's deck | Dave Kearton | Aviation Photos | 0 | March 2nd 07 07:09 AM |
| Straight deck ops | Greasy Rider | Naval Aviation | 18 | January 10th 07 02:35 AM |
| Deck height | Sean Trost | Home Built | 5 | July 16th 04 04:46 AM |
