Yo! Fuel Tank!
Old October 23rd 03, 08:07 AM
guynoir
Read about "water break" testing and solvent cleaning.
http://www.lmaeronautics.com/materia...docs/pg054.pdf
http://www.westsystem.com/ewmag/20/Contamination.html
These two documents have information on surface preparation for bonding.
I built several glued together aluminum fuel tanks and discovered that I
could consistently make a glue joint fail if I wiped the joint surfaces
with acetone or alcohol after etching and rinsing with water. So I
stopped solvent wiping. I never tried MEK.
Here are two of my tanks:
http://home.teleport.com/~guynoir/re...edinterior.JPG
Old October 24th 03, 01:07 AM
Blueskies
Those should give me pretty good range!
What are those tanks for?
Dan D.
"guynoir" wrote in message nk.net...
Old October 24th 03, 01:51 AM
Larry Smith
"Veeduber" wrote in message
What are PKs?
Hex head sheet metal screws with an attached, non-marring washer. PK's
are
what the world used before clecos.
Do a google for 'Riveting 101,' see if you find anything of interest.
-R.S.Hoover
Gosh, Veeduber, you're the natural successor to Tony Bingelis. I just read
the first of your three articles on Riveting 101 at Ron Wanttaja's website:
http://home1.gte.net/ikvamar/avlinks/.
Excellent.
Old October 24th 03, 06:23 AM
guynoir
They were originally made by BHC, the British Hovercraft Corporation, so
I presume they were originally for hovercraft. I don't know how they
ended up in Boeing helicopters, which is what the photo shows, but two
500 gallon internal tanks work better than two 1000 gallon external
tanks when the helicopter is used for logging. I built 5 from scratch
using BHC drawings, and I converted several original BHC tanks from
bladder to wet cell. (In between other projects, of course).
Four out of the five were in aircraft which have crashed and burned.
So it goes.
Old October 25th 03, 01:11 AM
Blueskies
Columbia Helicopters?
Dan D.
"guynoir" wrote in message ink.net...
So it goes.
Old October 25th 03, 02:57 AM
guynoir
Yes.
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Protecting fiberglass from fuel & oil Paul Lee Home Built 2 September 18th 03 06:14 AM
Fuel pressure Problems smf Home Built 3 September 7th 03 08:25 PM
Hot weather and autogas? Rich S. Home Built 33 July 30th 03 11:25 PM
Question ~ Does fuel injection add weight? Barnyard BOb -- Home Built 0 July 6th 03 09:47 PM
