Captured V-1 Pulsjet being Fed
Old January 22nd 04, 05:57 PM
robert arndt
Default Captured V-1 Pulsjet being Fed
http://www.texasmonthly.com/ranch/sr...1rocket.1.jpeg
A captures pulsejet on a stand. Notice that is operating by being fed
air, fuel, and notice the spark plug lead.
Again, notice how the pulsejet CANNOT operate INDEPENDENTLY without
flying at at least 186 mph.
Rob
Old January 22nd 04, 06:30 PM
Keith Willshaw
"robert arndt" wrote in message
om...
Rob
This does not follow, just because the engine was being fed with air
that does not mean it must be.
The NACA articles describing the tests made it clear that
they used inlet air speeds of 0 mph to 340 mph
At 0 mph the engine DID run independently and produced
500lbs of thrust
The table of data reads as follows
Simulated Ram pressure in water 0 18 48 58
Equivalent indicated airspeed mph 0 190 280 340
Max thrust 500 660 740 770
Thrust for min fuel consumption 420 610 660 680
please take the time to read it
http://naca.larc.nasa.gov/reports/19...a-wr-e-269.pdf
Note especially the comment on page 12
"Figures 8 & 9 show that for a ram pressure of 0 (ie. ZERO ram effect)
from 6 to 9 pounds per second of air is induced into the engine for
combustion upon which an effective jet velocity of about 2300 ft per
second is developed"
They also describe how Argus needed an external spark and air
blast for starting but that immediately after start this was no longer
required.
What they did have to do was put a shroud around the engine to cool the
shell if they were to run it for 30 seconds at zero mph IAS
I dont doubt that the Germans imposed a limit of 7 seconds running on the
ramp before launch but it DID clearly run unaided at launch time
Keith
Old January 22nd 04, 07:37 PM
B2431
Date: 1/22/2004 10:57 AM Central Standard Time
Message-id:
Rob
It's a test stand. Maybe they were testing the engine over a range of simulated
air speeds. Who knows. It is still not an operational V-1 engine or launch.
You have been shown video of the engines running without forced air. That
should be proof enough. Look at the videos of the V-1 launches. The engines
were running before the piston was fired.There was no air being forced in. Are
you suggesting the Nazis were going to launch a V-1 and HOPE the engine kicks
in before the end of the ramp? Are you suggesting there's a hidden forced air
source that just happenes to vanish about the time the missle leaves the ramp?
There was a prototype engine that had a row of glassed over observation ports
down one side. See if you can find the footage of it. I have seen it on
television a few times and do not recall it being hooked up to a forced air
system.
Dan, U.S. Air Force, retired
Old January 22nd 04, 10:47 PM
Bruce Simpson
Rob
Note that, despite what your subject heading might say, this is not a
captured V1 pulsejet being fired. It is actually a replica built by
Survival Research Laboratories. (the page from which the image you
referenced was taken is at :
http://www.texasmonthly.com/ranch/srl/v1.php and more detail on the
SRL's V1 project can be found at http://www.srl.org/machines/v1/
Note that SRL have a number of pulsejets in their inventory, and they
all operate without forced air -- a fact that can be testified to by
the thousands of people who have watched their shows.
And don't tell the millions of people who watched me build/drive a
pulsejet powered gokart on Junkyard Wars last year. I wasn't doing
186mph -- but that pulsejet engine was certainly running strong and
loud without a hint of forced air (except briefly just to get it
firing)
And if you check out this page:
http://aardvark.co.nz/pjet/lhkart.shtml you'll see that I know I was
only going 57mph because I had a GPS system onboard to measure the
speed.
Check the brief video clip at:
http://interestingprojects.com/shcbits01.mpg
You can also see a pulsejet running without forced air on a test stand
in this clip (Real Player required):
http://aardvark.co.nz/pjet/video/pj15srm
So, either I'm achieving the impossible, or I am right when I say that
pulsejets can and do create static thrust and don't need to be moving
through the air at any speed in order to work.
you can contact me via http://aardvark.co.nz/contact/
Old January 23rd 04, 03:28 AM
B2431
Rob
firing)
speed.
An impressive site.
Old January 23rd 04, 12:29 PM
Cub Driver
Perhaps we're conflating the pulse jet and the ram jet?
I thought that the distinction between the two was just that: the
pulse jet could function without forced air, the ram jet couldn't.
all the best -- Dan Ford
email:
see the Warbird's Forum at
www.warbirdforum.com
and the Piper Cub Forum at www.pipercubforum.com
Old January 23rd 04, 04:16 PM
Kevin Brooks
"Cub Driver" wrote in message
But Rob has assured us that the pulse jet is a form of a ram jet, just as he
has assured us that pulse jets can't run or be started in a static mose
without forced air. So far his assurances have not generated much
confidence.
Brooks
email:
Old January 23rd 04, 05:09 PM
Kevin Brooks
"Kevin Brooks" wrote in message
he
Err...that should be "mode". Not "mose", and not "moose" (having encountered
a couple of those critters up-close-and-personal while trout fishing, I'd be
reluctant to try and insert *any* kind of foreign object in said beast even
if he was standing still).
confidence.
Brooks
email:
Left can't read well nor do they understand Constitution Jarg Military Aviation 102 January 19th 04 04:35 PM
Captured Arsenal Aircraft robert arndt Military Aviation 1 November 6th 03 11:56 PM
UN inspectors: Saddam didn't lie Larry Dighera Military Aviation 5 September 19th 03 05:24 PM
PFC Lynch gets a Bronze Star? Brian Military Aviation 77 August 2nd 03 12:15 PM
