Hercules Engines
Old January 22nd 04, 09:26 PM
Tarver Engineering
"Rick" wrote in message
nk.net...
Tarver Engineering wrote:
You are too confused for me to even respond, Dan.
Several of us have provided links to thermocouple sites,
engine manufacturer's and operator's sites that prove you to
be a fool and an idiot.
Yanik was a thermocouple tech, I was a jet engine mechanic and you are the
idiot, Ricky. You seem to be completely stupid and unable to learn.
Now go do a Google seach and congradulate yourself, dippy.
  #152
Old January 22nd 04, 09:27 PM
Tarver Engineering
link.net...
Tarver Engineering drooled on his crayons:
Also, Jim, the "total" is what you want for such small signals.
Averaging
would only reduce: accuracy, reliability simplicity.
http://www.allaboutcircuits.com/vol_1/chpt_9/5.html
LOL
What a dip**** you are, Ricky.
Yanik was a theromouple tech, we don't need your clueless web searches.
  #153
Old January 22nd 04, 09:32 PM
Tarver Engineering
ink.net...
Jim Yanik wrote:
Well,then it violates basic physics.If you have two voltage sources of
slightly different voltages,currents DO flow between them.That's a basic
principle. And bimetal TCs are simply millivolt voltage sources.
Just in case you are not just a Taver sock puppet
Dip****, Ricky, Mr. Yanik is telling you how it is.
We don't need your clueless web searches.
Are you really this stupid, Rick?
Just because someone wrote something in an URL has no bearing on whether it
is true.
  #154
Old January 22nd 04, 09:38 PM
Tarver Engineering
"Jonathan Stone" wrote in message
No, no, no. The Hercules engine is (as is well-known) a 14-cylinder
sleeve-valve radial.
(Lets see what Tarver makes of that.)
That is a lot of sparkplugs.
  #155
Old January 22nd 04, 09:44 PM
Tarver Engineering
"B2431" wrote in message
Oh, heck, and I bet I missed a bunch of tarverisms.
You are bought into the miller sub-idiot detecor, aren't you, Dan?
I know you are a Knoyle Idiot member.
  #157
Old January 22nd 04, 09:49 PM
Tarver Engineering
Subject: Hercules Engines
Date: 1/22/2004 12:43 PM Central Standard Time
Message-id: .net
Averaging
Don't bring facts or evidence into an argument with tarver. It just
confuses
the boy.
Yes, that electricity stuff is tough for us with only an MSEE and a PE.
Gald we got ol' smart Dan here ...
Bwahahahahahahaha
  #158
Old January 22nd 04, 09:58 PM
Jonathan Stone
No, its completely true. Read carefully.
  #159
Old January 22nd 04, 10:38 PM
Tarver Engineering
I see, but you are misusing the term radial WRT turbojets, as the term
radial refers to compressor flow. (ie T-33) Yes, I worked on T-33 motors.
Nice analogy though.
What would you call the new sleevless axial flow high bypass burners?
  #160
Old January 22nd 04, 10:49 PM
Scet
"Tarver Engineering" wrote in message
"Scet" wrote in message
snip
Yep, an averaged TIT signal on a T56.
Nope, only an idiot would devide the Total.
To devide would only increase the complexity and reduce reliability.
Are you a janitor, by any chance, Scat?
If you had any research skills at all Tarver you would quite easily find out
how wrong you are and how stupid you look.
Scat???? So when you are wrong you resort to name calling??? Your a real
thinker aren't you mate?
Those who cannot attack the thought instead attack the thinker.
Scet
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 11:14 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Hercules Engines Tarver Engineering Home Built 0 January 20th 04 12:05 AM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 06:36 PM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
