VOR-DME writes:
I’m sure the FAA is relieved to know that you’re on the case ... The FAA has its head firmly buried in the sand. As far as the VOR’s are concerned, you’re barking up the wrong tree. ADS-B OUT is the first mandated item, but far from the last. ADS-B IN will follow shortly, CPLDC datalink and UAT transceivers as well. At this point we are one ARINC fiber cable away from full ground-based control of every airplane in the system (not that this is a stated goal, but to demonstrate that we are soon achieving far better system integration than your 1980’s instrument textbook lets on). So the VOR’s are really superfluous with a few exceptions, which will be retained along with the odd NDB. What takes over when GPS fails? Loran is gone. NDBs and VORs supposedly will be gone. What's left? A magnetic compass? It will be important to maintain a minimum structure of surveillance radar as a backup ... Radar should be permanently retained. It helps prevent spoofing, for example. Where the battle lines will be drawn is over the issue of cost per participating aircraft and equipment mandates that the AOPA is likely to see as overkill and overpriced for GA. The FAA seems to be much more a friend of airlines than a friend of GA. |
| Thread Tools | |
| Display Modes | |
| (USA) US/Mexico "airspace" (boundary) files available | Tuno | Soaring | 4 | March 27th 10 08:17 PM |
| some planes [11 of 11] "old-air-planes-crashed-underwater-photos-pictures.jpg" yEnc (1/1) | No Name | Aviation Photos | 0 | August 9th 09 10:36 PM |
| On Sharing airspace with "non-rated UAV "pilots" | vaughn | Piloting | 15 | March 15th 09 05:08 PM |
| "Fly Baby, you violated Class B Airspace" | Ron Wanttaja | Piloting | 27 | September 5th 07 09:30 PM |
| Aviation Conspiracy: Connecticut To Get "Creamed" By Airspace Redesign Change? | Free Speaker | General Aviation | 0 | August 8th 06 03:42 PM |
