#28
A. *"Right Now Benefits of PowerFlarm" - This product does not currently exist. *Has it been submitted to the FCC for approval yet? *What is the expect ship date? Later this year, which is fine for me. And FLARM itself is well proven - even if that was all the PowerFlarm did it would be worth it. UAT ADS-B isn't. B. *1090ES ADS-B - You aren't going to see anything on PowerFLARM unless you are also equipped with, and transmitting a properly configured ADS-B Out Signal. *That part is NOT provided by PowerFLARM. Wrong. I'll see the 1090ES mode S directly. Which is exactly what I want to see. C. *PCAS - How does PCAS tell you anything about what kind of target is aiming for you? *In fact, it doesn't give you any information on where the target is, whether it's getting closer or moving away. *All you know is altitude and range (NO bearing). *It's not going to tell you if it's a jet, another glider, or your tow plane. *And you are only going to get that much info if the transponder equipped plane is being interrogated. * That's not a given if you are flying low in remote areas without radar coverage. If I look out the window and see a dot, all I know at first is that it is something out there. I'll watch it until I determine if it's a threat and react accordingly. PCAS helps me find that dot by warning me to look level or slightly high/low, and if I already have an idea where the traffic is coming from (arrival departure routes, VOR/ Airports nearby, VFR/IFR altitudes) I can focus my search there. What else do you need, the pilot's daughter's phone number? The biggest reason pilots don't see other traffic is not that it isn't visible, but that they aren't looking for it - and PCAS/FLARM/ADS-B are all designed to make the pilot get his head out of his PDA and look for traffic. What's my agenda? *Making sure that people know what they are buying and the limitations thereof. Fair enough. Cheers, Kirk |
| Thread Tools | |
| Display Modes | |
| Can I build one of you items? | Gig 601XL Builder | Home Built | 3 | December 23rd 06 09:21 AM |
| Build an RV of ??? | William Snow | Owning | 12 | September 8th 06 04:12 AM |
| Build an RV of ??? | Jim Logajan | Home Built | 1 | September 8th 06 04:12 AM |
| How to build a P-38 ? ? ? | Hans-Marc Olsen | Home Built | 42 | December 11th 04 05:06 PM |
| RV Quick Build build times... | [email protected] | Home Built | 2 | December 17th 03 04:29 AM |
