LOM engines
Old October 30th 03, 02:50 AM
Larry Smith
"ChuckSlusarczyk" wrote in message
In article , Roger Halstead
says...
I wonder why they use such a low compression ratio? Even car engines
running regular usually run 8:1. This one is 6.3:1.
It would reduce the stress on the parts, allowing less expensive
materials than a reliable high compression engine.
I guess they can also use lower octane fuel as well.
Chuck
6.3 to 1 is the compression ratio for the Continental A-65, which loves 80
octane avgas when it can find it.
Old October 30th 03, 03:50 AM
Orval Fairbairn
They use such a low compression ratio so they can use Russian gasoline!
Old October 30th 03, 03:59 AM
clare @ snyder.on .ca
On Thu, 30 Oct 2003 03:50:22 GMT, Orval Fairbairn
No. They use the low compression ratio because the Walther LOM engine
has a centrifugal engine driven supercharger. ANy higher CR would be
dangerous under boost.
Old October 30th 03, 04:04 AM
Capt. Doug
Roger Halstead wrote in message I wonder why they use such a low
Durability is one reason. Additionally, the typical bore and stroke in
aircraft engines is much larger than automotive engines. I forget exactly
why the larger bore and stroke is more susceptable to detonation, but I seem
to recall it has something to do the ratio of quench area to fuel/air charge
decreasing as the cylinder size increases.
D.
Old October 30th 03, 05:22 PM
Roger Halstead
US turbo'd engines use either 8 or 8.5:1 and my 300 HP IO540 uses 10:1
I'd think it would have a lot to do with the gas they are designed to
use and well as durability and manufacturing cost.
Roger Halstead (K8RI EN73 & ARRL Life Member)
www.rogerhalstead.com
N833R World's oldest Debonair? (S# CD-2).
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 12:44 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
LOM engines Salem Farm & Garden Home Built 2 July 22nd 03 11:30 PM
