On Nov 12, 4:48*pm, 150flivver wrote:
On Nov 12, 5:19*pm, Andy wrote: On Nov 12, 3:59*pm, Grider Pirate wrote: Wow. *So let me get this straight. Logging flight time IS considered by the FAA as a form of compensation? Please tell me I got that wrong.. That was the FAA position for a long time and I have not heard that it has changed. *Years ago *SSA negotiated the waiver for private pilots to tow for SSA affiliated clubs using a private cert. *At one phase in the negotiations FAA said ok but the private pilots cannot log the time as that was compensation requiring a commercial cert. When FAA was asked how pilots would prove currency they changed their position to being that such pilots could log the time but that it could not be used to qualify for any additional rating. *That would have required private pilots to keep track of towing time separately from other logged time. I got a restricted commercial cert so I could tow without dealing with the stupidity of it all. Andy The Chief Counsel's letter (excerpts quoted below) clearly states that a qualified private pilot can legally accept compensation for towing gliders. * The preamble to that final rule states, "The FAA is revising § 61.113(g) to allow a private pilot to act as pilot in command while towing an unpowered ultralight vehicle for compensation or hire." The compensation can be flight time, money, or both as the FAA does not break out compensation into different types of compensation. *"The text of § 61.113(g) does not limit the compensation that a private pilot may receive to only the logging of PIC flight time despite a suggestion to that effect by the Soaring Society of America in a comment to the 1995 NPRM." Not sure of the point of your reply. You do not contest the conclusion that FAA regards earning flight time as "compensation" and that was the OP's question. The question you answer is whether that compensation is currently allowed for a private rated tow pilot, and clearly it is. Andy |
| Thread Tools | |
| Display Modes | |
| Adding an airplane rating to private pilot glider | gmcd05 | Soaring | 35 | April 25th 08 02:43 AM |
| US FAR 61.113 Private Pilots Towing gliders for compensation. | Jackal | Soaring | 21 | January 23rd 05 05:37 PM |
| Non Current Private Pilot to Glider ? | Les Ward | Soaring | 1 | November 1st 04 08:06 PM |
| endorsements for private pilot glider rating | Joel Taylor | Soaring | 2 | October 2nd 03 07:44 AM |
| Private Pilot Glider Rating Requirements | John | Soaring | 8 | August 21st 03 02:09 AM |
