On Jul 24, 9:04*am, Andy wrote:
On Jul 24, 5:07*am, 150flivver wrote: I disagree. *There should be an urgent, serious emergency type signal-- the wing rock, and a not-so-serious, advisory type signal such as the rudder waggle. *If you can't keep the two separated, then perhaps you need to take up a different hobby where you're actions don't impact on the lives of the tow pilot or yourself. *I don't have the luxury of getting the glider up to 1000 feet if I throw a valve at 200. It's much more common for the glider to survive a release at 200 feet, than a tow plane having a serious problem down there and having a good outcome. I'd be interested in hearing from tow pilots that had a real in flight emergency and used the wave off signal. *It's always seemed to me to be a bit like the "too slow" winch signal i.e. if you need to give it then you're not in a situation to do so. If there's time to negotiate I'll use the radio, if not I think I'll be pulling the release. Andy I have had 3 real ones, all engine related. In all cases the glider responded promptly and correctly. I have done 2 rudder wags for spoilers out. One responded correctly and fixed the problem. The second released. Our club includes these signals in our Spring check. Given all this, I will not do rudder wag until I have placed the glider pilot in a position where misinterpretation will not be a cause of an accident. If I really need him off, it's wing wag and every man for himself. UH |
"Given all this, I will not do rudder wag until I have placed the
glider pilot in a position where misinterpretation will not be a cause of an accident." Now that is a good idea. If you are climbing at all don't wag until well over 200' AGL. If the climb is that slow the glider pilot should realize it and be checking his spoilers. Mike |
On Jul 25, 6:35*am, Mike wrote:
"Given all this, I will not do rudder wag until I have placed the glider pilot in a position where misinterpretation will not be a cause of an accident." Now that is a good idea. If you are climbing at all don't wag until well over 200' AGL. If the climb is that slow the glider pilot should realize it and be checking his spoilers. Mike That is SOP at many places, why it is not followed/emphasized to all tow pilots I don't know. Darryl |
| Thread Tools | |
| Display Modes | |
| using less spoiler just before the flare??? | Gary Emerson | Soaring | 16 | October 29th 07 02:08 PM |
| Landing with one spoiler | [email protected] | Soaring | 82 | October 7th 05 01:58 AM |
| Nimbus 3 25.5 tip spoiler cable replacement | tango4 | Soaring | 0 | May 3rd 04 10:05 PM |
| Spoiler placement and design. | B2431 | Home Built | 9 | November 11th 03 05:02 PM |
