50th type of Flight Recorder gains IGC-approval.
Old November 21st 11, 05:57 PM posted to rec.aviation.soaring
Ian Strachan
Default 50th type of Flight Recorder gains IGC-approval.
The Colibri II GNSS Flight Recorder manufactured LX Navigation
(www.lxnavigation.si) has gained IGC-approval with effect from 20
November 2011 for "all flights". For IGC-approval levels, see para
1.1.4 of Annex B to the Sporting Code for gliding.
This brings the number of IGC-approved Flight Recorders to 50 types,
from 19 different manufacturers.
The IGC-approval document will be available on the FAI/IGC web page:
http://www.fai.org/gnss-recording-de...ight-recorders
This may not be for some time because the FAI/IGC web pages are being
re-organised. Meanwhile the document is available from
or from the GFAC Chairman at the email address
below.
IGC-approval follows test and evaluation by the IGC GNSS Flight
Recorder Approval Committee (GFAC) in accordance with Annex B to the
Sporting Code for gliding and the Technical Specification for IGC-
approved GNSS Flight Recorders. The Technical Specification is
available through the igc-approved-flight-recorders web site above and
the Sporting Code for gliding through
www.fai.org/igc-documents
A PDF file with a table of all existing IGC-approval documents is on
the igc-approved-flight-recorders web site above. Due to the re-
organisation of the FAI web pages, this document is out-of-date but it
is hoped that the latest version will be available shortly. This
document contains:
(1) a table of all types of IGC-approved Flight Recorders, in
alphabetical order of manufacturer name
(2) a table of Flight Recorder Manufacturers, in alphabetical order of
manufacturer name
(3) a list of all IGC-approval activity from 1996 to the present day
(4) a history of IGC GNSS Flight Recording
Finally, in view of the difficulties encountered this year with the
FAI/IGC web site, to provide an independent source of data on IGC-
approved Flight Recorders, a GFAC web site is being developed,
probably to be based on the GFAC Chairman's internet provider.
Ian Strachan
Chairman, IGC GNSS Flight Recorder Approval Committee
New type of Flight Recorder gains IGC-approval Ian Strachan Soaring 0 August 31st 11 07:21 AM
IGC-approval of the LXNAV Nano GNSS Flight recorder Ian Strachan Soaring 5 September 1st 10 03:41 PM
New IGC-approval for GNSS Flight Recorder Ian Strachan Soaring 0 February 14th 09 09:00 PM
IGC-approval issued for Aircotec GPS Flight Recorder Ian Strachan Soaring 0 May 31st 06 12:47 AM
IGC-approval for new type of recorder - NTE Easy Matchbox Ian Strachan Soaring 0 August 8th 05 11:34 AM
