Tail Wheels & Tail Booms snapp'n
Old November 21st 11, 02:37 PM posted to rec.aviation.soaring
Default Tail Wheels & Tail Booms snapp'n
On Nov 20, 5:32*pm, Dave Nadler wrote:
Guys - Tail up prevents catching on rough ground
and reduces side-load on tailboom if in crops.
Tail up if you start to groundloop !
See ya, Dave
I have to disagree here as far as suggesting some technique thet is
planned.
Tail up almost ensures a ground loop.
Tail down reduces the likelyhood of a groundloop substantially.
Very few ground loops occur as a planned event(the "I'm running out of
field" event). The strong majority are surprises caused by catch a
wing.
I most cases, the lower energy in the event that come from a slow held
off landing significantly reduces the likelyhood of a fuselage
breaking event.
If you lose it, you don't have much time to try to raise the tail.
Just squeeze the brake hard and hope for the best.
Another opinion FWIW.
UH
Old November 22nd 11, 12:14 AM posted to rec.aviation.soaring
Dave Nadler
Sorry if I wasn't clear:
Tail up AFTER ground-loop starts or is inevitable,
not first. There's plenty of time to respond.
This is *after* a fully held off tail-first landing.
Seen it done multiple times ;-)
Do wish I had a video of the 22 going around.
PS: Most of these guys have Tost brakes so
squeezing won't do anything...
Old November 24th 11, 03:00 AM posted to rec.aviation.soaring
Karl Striedieck[_2_]
The most important reason for forward stick in a ground loop is not to
save the tail boom, as it will come crashing down at the termination
of the event anyway. Keeping the nose buried helps prevent an inverted
wingover as the wing accelerating forward develops enough lift to turn
the ship upside down. This can be fatal and almost was to Joe Conn at
Chester, SC in his ASW-17 many years ago.
And, further to the subject, all pilots should know how to execute an
intentional ground loop should they be faced with the need (fence,
road, embankment, etc.) Stick full forward, wing down, full rudder in
direction of down wing. This is part of German gliding instruction.
Should be here as well.
Tail Canuck[_10_] Aviation Photos 0 February 17th 11 07:52 PM
Tail wheels, or is this forum really dead? [email protected] Home Built 8 February 5th 10 02:33 AM
Source for tail wheels Simon Soaring 11 May 25th 05 05:05 AM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 02:34 PM
Why the T-Tail? Marian Aldenhövel Soaring 57 November 3rd 04 03:03 AM
