Why not use the F-22 to replace the F/A-18 and F-14?
Old February 29th 04, 03:58 PM
Kevin Brooks
"Doug "Woody" and Erin Beal" wrote in message
On 2/28/04 6:42 PM, in article , "Kevin
On 2/28/04 1:54 PM, in article
"Kevin
Brooks" wrote:
Kevin, it's funny how you conveniently snipped the part of my post you
couldn't defend.
Not at all; your argument was so lacking in logic that I saw little reason
to bother. But if you are so interested in improving yourself, here goes:
"CAS is available immediately because it is capping nearby--not because it
is
on some Harrier or STOVL F-35 that's on a mesh field getting fueled and
loaded. It is a function of proper planning, sufficient numbers of
aircraft, and a good DASC."
What you ignore is that the "capping" (by which you actually menat
"stacking", I presume) is utterly dependent upon a number of external
factors that don't necessarily impact the operations of a STOVL aircraft.
You have to have tankers to support the CAS stack--tankers are a commodity
that is becoming more critical these days, and less available. You have to
have bases within range to support continuous operations. The heavies have
less problem with this, but then again we don't have a limitless supply of
heavies, and they *do* have some limits (hard to have a heavy do a Maverick
run). How many F-16's or even F-15E's do you have to have running continuous
operations to support a very long range CAS mission (like Afghanistan from
the Gulf)? Lots if yo0u are going to maintain a continuous CAS stack, and
*lots* of crews, too. Plus more tankers. And if you find yourself a bit
farther away than that Gulf-to Afghanistan trasit distance, then supporting
the CAS requirement becomes even more tenuous, if not impossible. OTOH, if
you establish a forward landing strip to handle C-130's bringging in the
beans, bullets, and bombs, you can also put a few STOVL aircraft in there,
set up FARP's closer to the action, and (voila!", you just reduced your
tanking requirements while also making the CAS package more responsive to
the ground commander's needs. He wants some CBU-105's in the mix? The F-15E
flying from Bumfart 1200 miles distant, on station with GBU's, is not going
to be able to help him much, and by the time he gets a new aircraft on
station the target is gone. OTOH, he gets his STOVL aircraft to hit the FARP
for a couple of CBU 105's, and bingo, he's in business.
That is so far out of reason it is unbelievable. Firstly, if the STOVL
version were axed, the USMC would just buy one of the other two
versions--they will have to replace those old F/A-18's and (by then)
AV-8B's
with *something*, so there is no merit to this strange theory you have
postulated. Secondly, axing of the STOVL would be unlikely anyway,
because
the RN/RAF have placed their bets on that version. Have you got any
*reasonable* reasons why the USAF would allegedly just toss away a few
billion bucks on STOVL aircraft it really does not want?
It was actually YOU that suggested that the USAF was trying to make nice
with the USMC.
No, it was not. I was being quite facetious with that query. That you found
it palusible is rather telling of your grasp of this situation.
Firstly, if the STOVL version were axed, the USMC would most
definitely buy CV versions in reduced numbers, still driving up the unit
costs. Secondly, I never said the USAF didn't want the STOVL version.
They've realized during OIF that CAS and their TACP program is essential
to
warfare, and they see STOVL and forward basing as a way to get on board.
They are already onboard. They just seem to grasp the importance of being
more versatile a bit better than you do.
Any evidence that STOVL kills more pilots than other fast jets? Or any
evidence that the F-35B is inherently unsafe or "risky" technology? ISTR
STOVL X-35 demonstrator did pretty well...
Brooks
Are you joking? How long have you been around Naval Aviation?
When I was at China Lake (for 3 years) we had two class A mishaps (in our
manned aircraft... not counting the drones)--both were Harriers--at least
one pilot was a TPS grad. For one of the pilots, it was his second
ejection
from the AV-8B. The other died in a later AV-8B mishap after he'd
returned
to the fleet. We had one class B mishap--a Harrier. The first guy I knew
of from flight school to die in an aircraft accident? Harrier. The only
flight school classmate I know who was a POW during DS? Harrier. (Sorry,
that last one shouldn't count... Not unique to the STOVL discussion. I
was
on a roll.)
Meaningless. Compare the accident rates per hours flown and get back to me.
Then tell us how that applies to the F-35B, a different aircraft with a
different lift system.
According to a brief by the Navy's Aviation Safety School given a few
years
back, pilots across the TACAIR spectrum with 500 hours or less accounted
for
29% of the general pilot population but were at the controls of 46% of the
"Skill Based Error" mishaps. If you split out the AV-8B community, the
percentage of less than 500 hours is 36% and they're responsible for 67%
of
the mishaps. Conclusions: (1) experience counts. (2) the Harrier is a
more difficult aircraft to fly. This doesn't account for material
failures
etc.
So flying the AV-8B is more demanding of new pilots. Hardly an indictment of
the STOVL concept itself.
I don't know the actual rates, but the Harrier's have consistently been
higher than fleet average.
Then there's common sense. Slow an F-35 down to near stall while
simultaneously opening an upper intake door and engaging a power take-off
that activates a lift fan. Meanwhile rotate the exhaust nozzle in the
back
of the jet through two axes. Any one of these single components fails,
and
there's going to be trouble.
If a helos rotor falls off, it crashes, too. Still kind of a rare event. If
the F-16's engine dies and can't be restarted, it crashes. So?
These opinions of mine were not generated in a vacuum. They were formed
through years of operating TACAIR aircraft--occasionally around
Harriers...
when they weren't falling out of the sky around me. (Sorry, more rant...
and attempted dark humor.)
There's little doubt in my mind that the F-35 STOVL will be a better
platform than the AV-8B, but any slight gain in flexibility of use is
still
not worth the risk and the cost when compared to a less risky CV or CTOL
version.
Unless you can't support the operation adequately with the CTOL aircraft.
Brooks
Now ask me if I think it's a good idea that the F-35 is a single engine
aircraft or whether I think it's a good idea that the Navy guys have
decided
not to put an internal gun on their version.
--Woody
  #222
Old February 29th 04, 05:03 PM
Henry J Cobb
José Herculano wrote:
Couldn't agree more. The STOVL F-35 is a fact of life. The RN needs them to
mantain a fixed wing naval aviation component, the same will apply, in a far
smaller scale, to Spain, Italy and Thailand. Japan is almost certain to buy
them for their "open deck transports" or whatever PC term they are now using
for their carriers in construction. The RAF *thinks* they need'em, and it is
hard to argue with them.
http://straitstimes.asia1.com.sg/asi...237523,00.html
'I Love Japan, I Love Peace. The Maritime Self-Defence Force,' says a
voice-over at the end.
They just need a class of Lending Humanitarian Assistance ships
operating Justice Support Friendship aircraft.
-HJC
  #224
Old February 29th 04, 06:37 PM
Frijoles
Navy opposition to STOVL is about SHIPS not aircraft. They oppose the
concept because they think it threatens 95,000 ton carriers. It is clever
sophistry to argue against STOVL JSF on the basis of the performance of the
Harrier and, Woody, you know that shipmate. The Harrier uses an entirely
different lift/propulsion system, the technology of which is fundamentally
unchanged from the introduction of the AV-8A in the early 70s. While later
models (Night and Radar/Night) added up-to-date avionics and defensive
systems, the lift/propulsion system is little changed. As a consequnce, its
accident rate is similar to the jets of the era in which it was designed --
F-4, F-14 etc. The design suffers from maintainability issues similar to
aircraft of its design era also. $$ for materiel issues have long been a
problem, but as materiel problems have been fixed (like the #3 bearing),
accident numbers have gone down. STOVL JSF is an entirely different animal.
It is simple to fly -- even fighter guys can do it on the first try (and you
don't take it to "near stall" to transition to the landing configuration
anymore than you do a conventional aircraft). For STOVL JSF to transition
to the SDD phase, the technology issues had to be assessed by the government
as "low risk." It is predicted to meet the performance KPPs even at its
current weight.
On the warfighting side, if fighting an air war was simply a matter of
stacking jets somewhere, we could cover the entire battlespace with B-1s or
B-2s. (A trivia question -- how many CV sorties does it take to cover the
same number of DMPIs that ONE B-1 with a full load of SDBs can cover?) And
if tanking isn't an "issue," what's up with all the bragging about what a
great tanking capability the Navy's brand new STRIKE aircraft provides...?
45% of Marine CAS sorties during OIF were flown by Harriers -- that's hardly
a trivial number, particularly if you're on the ground getting shot at, or
facing the prospect of having to deal with massed armor and indirect fires.
IIRC, about 1500 strike sorties were flown off L-class ships, principally
Bataan and BHR which each operated 20-25 jets. A couple hundred were flown
from a "recovered" airfield within 10 minutes of Baghdad. An additional
500+ sorties by the one land based squadron in Kuwait. At one point last
year, 100-ish of the roughly 110 fleet AV-8s were deployed in real-world
events somewhere in the world -- that total included a Det of land-based
AV-8s supporting the Army and SOF bubbas in Afghanistan for a year.
"Too little benefit..."?? I think not.
"Guy Alcala" wrote in message
Doug \"Woody\" and Erin Beal wrote:
On 2/28/04 1:54 PM, in article ,
"Kevin
message
SNIP
The groundpounder who wants responsive CAS available *immediately*
throughout an operation would differ with you as to whether having an
asset
capable of hitting a FARP and returning quickly to station is just
"nice to
have".
it is
That also assumes that sufficient numbers of tankers and sufficient
bed-down
space for them will be available, both of which were in short supply last
year.
In 1991, because we had access to Saudi and Turkish bases, the USAF was
able to
put 350 tankers on just 5 airbases. Last year, they only had 200 tankers
(plus
100 for the airbridge; others were supporting ops in Afghanistan and the
Horn of
Africa), and had to scatter them on 15 airbases. Because of the lack of
ramp
space, the marines graded a FOB in the northern Kuwaiti desert with a
parallel
pair of 6,000 foot dirt runways, where they based many of their KC-130s
and
helos. In addition, they offloaded the helos, men and equipment from two
LHA/LHDs, operating each of them with a full AV-8B squadron, just so they
wouldn't take up space on an airfield in Kuwait that was needed by the
CTOL
aircraft.
The USAF weren't the only ones with tanker problems. From an article in
April 14th, 2003 AvLeak, "Lessons Learned", pg. 26, by AvLeak's
correspondent at
a Marine airbase in Kuwait:
"Its air campaign has been shaped to a large extent by the fact that the
service
has only 24 KC-130 tankers in the region, a relatively small number
compared with
the number of strike aircraft it has assembled. What further complicated
tanker issue is that most KC-130 sorties were dedicated to transporting
fuel for
helicopters, as well as tanks and other ground vehicles, to forward areas.
It is
a "rare occurence" for a Marine F/A-18 or AV-8B to be refueled in the air,
said a
senior Marine Air Group 13 representative, who described the tanker
shortage as
'huge'. Problems the USAF has had with its own tankers -- such as poor
availability because of the age of the KC-135s -- have exacerbated the
dilemma,
Marine Corps officials asserted. 'Tanking was very limited,' one Royal
Air Force
Harrier pilot noted . . . .
"Without refueling, fixed-wing a/c operating from here can only fly over
Baghdad
or points north for a few minutes before having to return to base. Pilots
from
Harrier squadron VMA-214 noted that without aerial refueling, they had
little
time to find targets in the 30 x 30-mi. 'kill boxes' set up around
Baghdad.
"The Marines hope to mitigate the problem by establishing forward
operating bases
for AV-8Bs and potential F/A-18s. For its helicopter force, the Marines
have
already built an extensive series of [FARPs]. So far, the Marines have
built
more than 10 FARPs and have even closed down the first few that are no
longer
tactically relevant."
They definitely established a Harrier FARP and were sitting ground alert
and/or
turning AV-8Bs at an airfield east of the Euphrates that the marines had
captured
on their way to Baghdad. I don't know which airfield, because the AvLeak
guy
wasn't allowed to identify it during the war, but I suspect it was around
al-Kut.
Which is why the V/STOL F-35 is unnecessary.
Logic fault. You are claiming that because it was allegedly not
required in
this instance, it will never be required. Kind of hard to support that
kind
of argument. Given a scenario like Afghanistan, where the CAS assets
had to
transit great distances to and from the required area of operations,
ability to get STOVL assets into the A/O early in the campaign could
be a
big advantage, and reduces the load on the other assets (like those
F-15E's
and F-16's transiting out of the Gulf area). If it is unnecessary, why
is
the USAF now joining the STOVL bandwagon--merely to make nice with
their
USMC brethren?
Precisely... With one important distinction they're more than likely
hoping
to take their USMC brethren's place and to keep unit costs down by
ensuring
that the STOVL version doesn't get axed.
And you don't think the fact that they were turning A-10s at an FOB in
Iraq (a
somewhat worse for wear Tallil airbase, IIRR) to avoid the extra 100-130
mile
one-way trip back to Kuwait, played any part in their deciding that being
able to
operate out of austere forward locations (by buying some F-35Bs) might be
a good
thing?
I doubt that. Is STVL the way to go for all TACAIR? Of course
not. But eliminating it just reduces your own versatility, and that
would
not be a wise move in the current environment of uncertainty (as
regards
where/when/how we'll have to fight).
Brooks
What I'm claiming is that STOVL is still risky technology that kills too
many pilots in peace time and offers too little benefit in war time for
that
cost.
And let's not forget how dangerous that helo VTOL technology is, so let's
get rid
of the helos while we're at it. Hell, those things have been dropping
like
flies.
Guy
  #225
Old February 29th 04, 06:56 PM
Paul J. Adam
In message , "Doug \"Woody\" and
Erin Beal" writes
On 2/28/04 1:54 PM, in article , "Kevin
throughout an operation would differ with you as to whether having an asset
capable of hitting a FARP and returning quickly to station is just "nice to
have".
CAS is available immediately because it is capping nearby--not because it is
And the equation for "time on station" includes time to and from home
base, and time to turn the aircraft around. For a given force size, the
nearer your bases for refuelling and rearming, the more aircraft in the
cabrank and the fewer in transit to and from. Tankers are useful
extenders, but only if fuel is the limiting factor: we're not yet able
to do air-to-air rearming.
Again, HMS Sheathbill in 1982 is instructive for the extension in cover
it allowed.
not. But eliminating it just reduces your own versatility, and that would
not be a wise move in the current environment of uncertainty (as regards
many pilots in peace time and offers too little benefit in war time for that
cost.
You could say the same about helicopters: IIRC helo crashes were the
biggest single killer of British troops in Telic / Iraqi Freedom.
When you have to kill a man, it costs nothing to be polite.
W S Churchill
Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk
  #226
Old February 29th 04, 07:03 PM
Pooh Bear
JL Grasso wrote:
On Sun, 29 Feb 2004 02:40:53 +0000, Pooh Bear
JL Grasso wrote:
On Sat, 28 Feb 2004 22:08:49 +0000, Pooh Bear
JL Grasso wrote:
On Sat, 28 Feb 2004 02:45:53 +0000, Pooh Bear
JL Grasso wrote:
On Fri, 27 Feb 2004 10:43:07 -0800, "Tarver Engineering"
The A-320 which crashed into the trees in France was performing a
fly-by demonstration, by a line pilot, not an Airbus test or demo
pilot. The profile was to fly by at 500 feet.
The pilot was making a scheduled revenue flight with passengers and came up
with the low slow fly by all on his own.
Actually, it was a charter flight. And not to split hairs, but the
low/slow fly-by was discussed by airline officials and both captains in a
prior briefing that day. The accident was officially caused by descent
below obstacle height combined with a delayed application of TOGA power to
exit the fly-by.
The F.O. was also declared mentally ill for demurring from the above
'explanation'.
Cite?
Crikey ! I thought it was common knowledge ?
Are you sure that you're not thinking of Norbert Jaquet? I thought that
Mazieres (the FO) flew for AF for some time after the accident. I could be
wrong, however.
If it was common knowledge, a cite should be a simple matter. Unless you
mean 'common knowledge' in the Tarverian sense.
I stand corrected, I got the 2 confused. It's been a long time since it happened. The
F.O. stayed 'shtumb' ( is that how you spell it ) and kept out of the way of the flak.
Is that what he told you?
Do you not think it strange that someone who criticised the official findings and
supported the captain being declared mentally insane is a very odd way to go about an
accident investigation ?
Air France was in charge of the investigation, eh?
Don't be silly. AF may have had it's reputation to protect but that was damaged already.
There were larger potential losers here.
Some 'body' had the flight recorders for 10 days directly after the crash who wasn't
entitled to be in custody of them according to French law. During that time they were
tinkered with. They shouldn't have been.
Besides, if you ran around saying "Captain Smith had the right-of-way",
I'd think you were mentally unstable too. And there is a significant
difference between unstable and insane.
So, you think that speaking out in defence of his colleauge was sufficient reason to
withdraw his flying license ?
Something about the whole investigation truly stinks. Also, the French aren't exactly
saints when it comes to bending the rules when it suits their purposes.
I don't argue that the crew got the a/c into a very odd flight regime. In part, it was poor
briefing that they received.
There were also known and documented defects with various A320 systems at that time -
including throttle response and height indication. Capt Assiline asserts that the a/c
showed 100 ft altitude when it was actually flying much lower.
In short, they were flying an a/c of questionable airworthiness. That *couldn't* be allowed
to come out in the investigation, so it was *fixed*.
Graham
  #228
Old February 29th 04, 07:12 PM
Frijoles
Woody says, "...the outcome of OIF would not have changed significantly had
the Harriers not
been around to help out..."
There's a stronger case for the Harriers in OIF than there is for a CV Navy
that arrives in the stack with no time-on-station and an understanding of
air support that consists of "gimme a 6-digit grid."
Woody further states "Guy, that's just ridiculous. Helos actually have a
bona fide mission--and
can auto-rotate."
Who's being ridiculous? I guess it doesn't count as bona fide mission
unless it's launched from a CV eh? .
On 2/28/04 11:06 PM, in article
, "Guy Alcala"
"Kevin
message
SNIP
asset
"nice to
have".
it is
bed-down
SNIPPAGE... Lots of tanker stats
AvLeak guy
around
al-Kut.
There's a shortage of USAF tankers in EVERY conflict--especially since the
demise of the A-6 and proliferation of the Hornet. Citing AV-8B ops in
OIF
is only slightly relevant. Of course, if you have STOVL capability, use
it
(OIF)--providing the threat will permit it. You've already sunk the blood
sweat and tears into it. My point is, the excessive risk in peace time
and
the reduction in payload/range isn't worth the small war time advantage,
and
the outcome of OIF would not have changed significantly had the Harriers
not
Yes, it's romantic to operate from austere bases in country...
Leap-frogging
your way to Bagdad. No, it's not worth the risk/hassle.
SNIP
Iraq (a
mile
being able
to operate out of austere forward locations (by buying some F-35Bs)
might be a
good thing?
Given the timeline, I don¹t think that particular example is why there's a
STOVL F-35 being built. Although I'm fairly certain this is why the USAF
is
jumping on the STOVL bandwagon. Frankly, I think the A-10 (or some other
low/slow/straight-wing design) is a better platform for what we're talking
about.
SNIP
too
that
cost.
let's get
rid of the helos while we're at it. Hell, those things have been
dropping
like flies.
Guy
Guy, that's just ridiculous. Helos actually have a bona fide mission--and
can auto-rotate. Why would you want to get rid of them?
--Woody
  #229
Old February 29th 04, 07:19 PM
Pooh Bear
JL Grasso wrote:
On Sun, 29 Feb 2004 02:25:05 +0000, Pooh Bear
JL Grasso wrote:
On Sat, 28 Feb 2004 22:07:53 +0000, Pooh Bear
JL Grasso wrote:
On Sat, 28 Feb 2004 09:23:07 -0700, "khobar" wrote:
Pooh Bear wrote in message
came up
a
to
exit the fly-by.
'explanation'.
You are aware that the DFDR presented in court to substantiate the official
story was NOT the DFDR from the crashed aircraft, yes?
... based on Assiline's assertion which he based on the appearance of the
box. IIRC correctly, he said that the one that he saw shortly after the
crash had vertical stripes on the housing, whereas the one in court had
diagonal stripes.
Pretty conclusive, yes?
Yes actually. I've seen footage of the DFDR being recovered and no way is it the
same one presented in court.
Surely there are some good still images from this footage available,
right? Can you provide a cite, or is this more 'common knowledge'?
It's so long ago, Jerry that I don't have cites readily to hand. I most certainly did
take a great interest in this crash. UK TV did too, with certainly more than one
decent documentary about this event. I believe I may still have a vid of at least one
of the documentaries in question. And before you try discrediting TV documentaries -
realise that in the UK we don't have the same commercial pressures as in the USA and
we make possibly the worlds' finest docs.
I'm sure.
I most certainly recall seeing the 'black box' being recovered in live recorded
footage - and it was a fairly tatty looking one ( well worn ). The one presented at
the investigation / court was entirely diiferent - almost pristine.
You're a complete kook.
No I'm not. I'm entirely rational. You're the 'kook' for believing what your're spoon-fed
without demur.
Citing your recollection of a news clip (which you saw live in 1998)
Please illustrate where I said that ? 1998 ! Uh ?
as
proof that photos you see months (or even years) later do not contain the
same components as in the live clip.
Actually the clip / photos were in the same documentary. I'm not talking about my memory
abilities, good as they are usually.
There is also I believe a question over 7 or 10 IIRC 'missing seconds' from the DFDR
record !!
Yes, it was on the internet - it must be so!
Well documented elsewhere.
Would you agree that after salvage of a flight recorder that it should be preserved
untouched until an expert organisation specialising in recovery of data is able to
'process' it ?
Just asking. I'm genuinely interested in your view. Is there a good reason for anyone not
ofiically involved in the investigation to step in regardless ?
I leave you to draw your own conclusions.
You hopefully leave people to do their own investigation. You're just
parroting a bunch of kooks.
This particular accident investigation is like no other. It stinks. So, you're saying
senior AF captains are kooks ?
Well.... actually, the 'Concordski' crash investigation was a stitch up too - and that was
also down to the French - hmmmm. Different scenario though.
Graham
  #230
Old February 29th 04, 10:13 PM
Scott M. Kozel
JL Grasso wrote:
On Sun, 29 Feb 2004 18:03:00 +0000, Pooh Bear
exit the fly-by.
'explanation'.
Cite?
wrong, however.
Air France was the party who declared him "mentally unstable". You
pondered that this was a strange way to run an investigation. I am simply
stating that Air France was not in charge of the investigation. Do you
still assert otherwise?
They were apparently in the possession of the DGAC, true. Your assertion
that they were "tinkered with" is apparently based on IPSC's claims. The
same "institute" putting forth the laughable notion that the stripes on
the boxes are oriented differently. This seems to imply that someone
apprently fabricated a recorder from scratch in some outlandish scheme to
save AI's reputation (as any recorder of the same model/part number should
bear the same outer markings).
I haven't seen AF's case against the man, and what you are implying is
that they were definitely related. What do you base this on?
However, it would seem odd that these same "dark hats" would allow the FO
to continue to fly for AF for years afterwards. Odd, unless you understand
the CVR transcript.
Well, that sounds like iron-clad evidence to me.
Oh, so the DFDR tampering was intended to cover for the DFO at Air France?
Which is it again?
Are the boundaries between the parties involved somewhat fuzzy to you?
Speaking to motive, of course.
Anyone who would rely on a pressure altimeter to operate a low, slow
aircraft 100 feet from the ground when a radar altimiter was fucntioning
(and apparently giving accurate aural information) and available is not
making a prudent decision. The pressure altimiter (servo, ADC or
otherwise) is only required to be accurate to app +/- 30 feet at sea level
to begin with (and the DFDR was only required to show pressure altitude
resolution to +/- 100 ft, but may have been more on this unit). A radar
altimiter is accurate (depending on a given antenna/plane configuration)
to within 5 feet (and quite likely less) between wheel height and terrain.
Read the CVR transcript again and tell me how the Captain could possibly
be surprised later when told/shown he was below 100 feet during the
fly-over.
You have no idea what you're talking about. If you have a problem with how
you perceive airworthiness to be determined by the DGAC, you should take
it up with them. The only things questionable here are your understanding
of the event, of the aircraft, and your sources of information.
Not surprising for Puke Bear.
"C-175 SoCal Beware" Original Poster Replies Bill Berle Aviation Marketplace 8 July 8th 04 08:01 AM
More LED's Veeduber Home Built 19 June 9th 04 11:07 PM
Replace fabric with glass Ernest Christley Home Built 38 April 17th 04 12:37 PM
RAN to get new LSD class vessel to replace 5 logistic vessels ... Aerophotos Military Aviation 10 November 4th 03 12:49 AM
Air Force to replace enlisted historians with civilians Otis Willie Military Aviation 1 October 22nd 03 10:41 AM
