#61
Tarver Engineering wrote:
The sole reason for using a static port is so the guts can be removed from the pitot tube, in order to improve reliability. A pitot port produces no static pressure datum. Just as an example, when the aircraft is sitting still on the ground - airspeed = 0. Since the pitot and static ports are in the same state, doesn't that imply that static pressure is present at the pitot port? MAH |
#62
Rich Ahrens wrote:
Yes, those static ports are pretty unreliable! :-) All those moving parts... Yep, I've got a can of static port grease on the shelf next to my bottle of horn fluid and the box of muffler bearings. MAH |
#63
mah wrote:
Rich Ahrens wrote: Yes, those static ports are pretty unreliable! :-) All those moving parts... Yep, I've got a can of static port grease on the shelf next to my bottle of horn fluid and the box of muffler bearings. MAH ....and the coil of shoreline, the bottle of propwash and the paint for the last post?... -- -Gord. |
#64
mah wrote:
Tarver Engineering wrote: The sole reason for using a static port is so the guts can be removed from the pitot tube, in order to improve reliability. A pitot port produces no static pressure datum. Just as an example, when the aircraft is sitting still on the ground - airspeed = 0. Since the pitot and static ports are in the same state, doesn't that imply that static pressure is present at the pitot port? MAH Sure it's there, but it's there only until the a/c starts to move. It's then no longer 'static pressure' because it's been raised by the ram effect of the movement. That's why you now need a 'static port' to supply the static pressure to use as a reference. Is it really that difficult to see?!? -- -Gord. |
#65
mah wrote: Rich Ahrens wrote: Yes, those static ports are pretty unreliable! :-) All those moving parts... Yep, I've got a can of static port grease on the shelf next to my bottle of horn fluid and the box of muffler bearings. MAH ...and the coil of shoreline, the bottle of propwash and the paint for the last post?... -- -Gord. Always good to have about 50 feet of flightline in case something gets loose. Dan, U.S. Air Force, retired |
#66
Tarver Engineering release for service
From: "Gord Beaman" ) Date: 3/2/2004 11:53 AM Central Standard Time Message-id: mah wrote: Tarver Engineering wrote: The sole reason for using a static port is so the guts can be removed from the pitot tube, in order to improve reliability. A pitot port produces no static pressure datum. Just as an example, when the aircraft is sitting still on the ground - airspeed = 0. Since the pitot and static ports are in the same state, doesn't that imply that static pressure is present at the pitot port? MAH Sure it's there, but it's there only until the a/c starts to move. It's then no longer 'static pressure' because it's been raised by the ram effect of the movement. That's why you now need a 'static port' to supply the static pressure to use as a reference. Is it really that difficult to see?!? -- -Gord. Should we tell tarver static ports existed before pitot tubes were used in aircraft? From my experience most aircraft have static ports separate from the pitot tube. Dan, U.S. Air Force, retired |
#67
"B2431" wrote in message ... From: "Gord Beaman" ) mah wrote: Rich Ahrens wrote: Yes, those static ports are pretty unreliable! :-) All those moving parts... Yep, I've got a can of static port grease on the shelf next to my bottle of horn fluid and the box of muffler bearings. MAH ...and the coil of shoreline, the bottle of propwash and the paint for the last post?... -- -Gord. Always good to have about 50 feet of flightline in case something gets loose. Even so, no worries. Secure it with the skyhook, and give it a turn or two with a left-handed monkey wrench. Right as rain. Cheers. |
#68
mah wrote in message ...
Rich Ahrens wrote: Yes, those static ports are pretty unreliable! :-) All those moving parts... Yep, I've got a can of static port grease on the shelf next to my bottle of horn fluid and the box of muffler bearings. MAH right next to a Splap in an as removed state |
#69
"mah" wrote in message ... Just as an example, when the aircraft is sitting still on the ground - airspeed = 0. Since the pitot and static ports are in the same state, doesn't that imply that static pressure is present at the pitot port? Sure, unless: 1) The aircraft is moving 2) The wind is blowing 3) Either 1) or 2) 4) Both 1) and 2) At that point the pressure is no longer static - so you need a static port. IIRC in fact, for an aircraft to be certified for IFR it has to have an alternate static source *as well*. Pitot pressure ceases to be equal to static pressure once the air is in motion relative to the port. Whether the air moves on its own or the plane moves through it is irrelevant. The CO MAH |
#70
"Gord Beaman" wrote in message ... mah wrote: Just as an example, when the aircraft is sitting still on the ground - airspeed = 0. Since the pitot and static ports are in the same state, doesn't that imply that static pressure is present at the pitot port? MAH Sure it's there, but it's there only until the a/c starts to move. It's then no longer 'static pressure' because it's been raised by the ram effect of the movement. That's why you now need a 'static port' to supply the static pressure to use as a reference. Is it really that difficult to see?!? Apparently. The CO |
| Thread Tools | |
| Display Modes | |
| Fine example of Tarver Engineering release for service | running with scissors | Instrument Flight Rules | 64 | March 3rd 04 06:01 AM |
| Fine example of Tarver Engineering release for service | running with scissors | Instrument Flight Rules | 7 | February 28th 04 06:07 PM |
| To Tarver Engineering | fudog50 | Military Aviation | 2 | January 9th 04 08:15 PM |
| About death threats and other Usenet potpourri :-) | Dudley Henriques | Military Aviation | 4 | December 23rd 03 08:16 AM |
| FS: Aviation History Books | Neil Cournoyer | Military Aviation | 0 | August 26th 03 09:32 PM |
