best self-launcher propulsion system?
Old January 12th 12, 04:41 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default best self-launcher propulsion system?
On 1/11/2012 12:38 AM, bumper wrote:
The Wankel is a bit less fuel effecient than a piston engine.
That is true compared to a four stroke piston engine, but the Wankel is
still more efficient than a 2 stroke piston engine. Not that it matters
in our gliders, as each is equipped with an appropriately sized fuel
tank, and fuel cost isn't going to be an issue!
email me)
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what
you need to know tinyurl.com/yfs7tnz
Old January 12th 12, 02:19 PM posted to rec.aviation.soaring
Dave Nadler
Also I should have mentioned:
There are two Antares 20E and one Arcus E for rent
in Namibia. No problems with temperature !
You often see these gliders on the front page of OLC.
Old January 12th 12, 06:56 PM posted to rec.aviation.soaring
GARY BOGGS
PS: Someone needs to come up with a really good
and appropriately foul acronym for "motor out and
not running".
Boggs, you're on...
PUNT?
Pylon Up Not Turning
PULP
Pylon up Lost Power
PENIS
Pylon Extended No Ignition... ****
Boggs
Old January 12th 12, 07:05 PM posted to rec.aviation.soaring
GARY BOGGS
Pylon Up Nothing Turning?
Old January 12th 12, 08:07 PM posted to rec.aviation.soaring
key[_2_]
Guys
Many thanks for your thoughtful comments and insight. I had read most
of the literature of every type of self-launcher and touring
motorglider, but your first hand experience is what i needed to hear
about. Clearly there are substantial tradeoffs and advantages and
disadvantages for every type of motorglider (not even considering
cost!). I will keep monitoring manufacturing developments, especially
for less expensive electrics. Unfortunately i am too tall (6'4") for
the Silent electric (assuming the cockpit is the same size as the
Silent petrol).
Key
Old January 12th 12, 08:28 PM posted to rec.aviation.soaring
Tony[_5_]
PENIS
Boggs
DINGDINGDING WE HAVE A WINNER!
Old January 12th 12, 08:39 PM posted to rec.aviation.soaring
Dave Nadler
Nah, he'll do better than that...
  #28
Old January 12th 12, 09:17 PM posted to rec.aviation.soaring
T8
Turbo Ignition TroubleS
Sorry... slow work day
-Evan Ludeman / T8
  #29
Old January 12th 12, 09:24 PM posted to rec.aviation.soaring
T8
-Evan Ludeman / T8
Duh. Should have been...
Turbo Ignition TroubleS while motor UP = TITSUP
Any military guy will tell you that means baaaaad news.
-T8
  #30
Old January 12th 12, 09:25 PM posted to rec.aviation.soaring
Peter von Tresckow
Failed unturning climb killer. Mandatory Emergency!
Pete
"T8" wrote in message
-Evan Ludeman / T8
Predecessor to the ETA - BIG ANCIENT self launcher Bob Soaring 0 October 17th 10 10:36 PM
Jet two seat self-launcher nearing completion airshowbob Soaring 9 April 15th 10 04:59 PM
For Sale: Discus A TOP self launcher Chris Soaring 0 December 1st 08 11:57 AM
IF I HAD A ROCKET LAUNCHER X98 Military Aviation 7 August 13th 04 10:17 PM
Vortex Oscillating Propulsion Eric Moore Military Aviation 1 December 14th 03 07:55 AM
