Calculating Headwind/Tailwind component
Old March 14th 12, 09:21 AM posted to rec.aviation.soaring
Alan[_6_]
Default Calculating Headwind/Tailwind component
In article m Jim Wallis writes:
I think Ramy is correct in this. In his calculation he is basically
assuming that he is flying his true heading - that is, he has adjusted his
true course to compensate for wind. Because of this, all of the vectors
become co-linear.
- Jim
Ramy
To clarify more, my formula is not Wind =3D TAS-GS, it is HW component
=3D
TAS-GS. This is the true head wind component as I explained. XCSoar does
no=
t currently show the true head wind based on TAS-GS, instead it is
calculat=
ing it from the vector head wind which is not as accurate.=20
Ramy
If Ramy is flying due north at 40 kt, with a 10 kt wind from the east,
he will need to be crabbing into the wind to maintain his ground track.
With his true airspeed of 40 ktas, his true heading will be about
14.48 degrees, and his groundspeed will be about 38.73 kts. His true
course will be 0 degrees.
Relative to his true course, his headwind component is 0 kts.
Thus, TAS - GS = 40 - 38.73 = 1.27 kts.
If you convert that wind from the east into components towards his
nose and towards his right wing, then you get 2.5 kts on the nose, and
9.68 kts on the right wing. When you compute his resultant velocity
from 40 - 2.5 kts forward, and 9.68 kts sideways, you get the same
groundspeed as computed before, about 38.73 kts.
The basic problem is that it is generally meangless to compute TAS -
GS, as those are scalar magnitudes of vector values, and the vectors
are rarely colinear.
Alan
Help calculating Speed To Fly for headwind and tailwind Tim Taylor Soaring 23 June 2nd 10 06:52 PM
Stewart Headwind Copperhead144 Home Built 2 August 19th 08 01:58 AM
Headwind? What's that...? David Lesher Owning 6 January 4th 08 09:17 PM
Is this a Component of a WWll Ships Radar [email protected] Naval Aviation 1 April 22nd 05 07:44 AM
boy it's changed; tailwind [email protected] Piloting 8 February 8th 04 05:03 AM
