PowerFlarm Portable - Fit in Discus 2A on panel top?
Old May 11th 12, 01:40 AM posted to rec.aviation.soaring
Default PowerFlarm Portable - Fit in Discus 2A on panel top?
Walt
On Thursday, May 10, 2012 6:52:09 PM UTC-4, WaltWX wrote:
Considering renting a PowerFlarm for the Avenal, CA CCSC contest next week before my "Brick" arrives.
Will the portable unit fit on top of the panel cover in a way such that the antenna's do not contact the canopy? Looks like they will touch... and the manual says that is an improper antenna installation.
Any other ideas on where to mount the portable in a Discus 2A or Ventus 2a fuselage?
Walt Rogers, Wx
Walt,
They will touch, but that still works. According to Dave Nadler (and common sense) the ESD thing is a non-issue. I have had my portable since Uvalde last year, mounted in exactly the same way with no problem.
Frank (TA)
Old May 12th 12, 12:14 AM posted to rec.aviation.soaring
Glenn Betzoldt[_2_]
On May 10, 7:40*pm, wrote:
Walt
Walt Rogers, Wx
Walt,
They will touch, but that still works. *According to Dave Nadler (and common sense) the ESD thing is a non-issue. *I have had my portable since Uvalde last year, mounted in exactly the same way with no problem.
Frank (TA)
I used one in my D2a and had no problem
Glen
PowerFLARM portable: rechargeable battery recommendations ursus Soaring 1 February 1st 12 07:02 PM
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported Paul Remde Soaring 24 January 22nd 12 02:50 AM
FS - Powerflarm Portable Westbender Soaring 0 January 9th 12 10:21 PM
PowerFLARM Portable Units in Stock Paul Remde Soaring 0 December 16th 11 03:54 AM
PowerFLARM Portable mount option DaleKramer Soaring 11 October 20th 10 04:45 PM
