PowerFLARM updates and installation notes
  #29
Old June 6th 12, 06:20 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default PowerFLARM updates and installation notes
On Jun 5, 9:47 pm, Eric Greenwell wrote:
It depends very much on the antenna; e.g., the dirty looking transponder
3" stubby rod with a ball on top has insignificant drag on an 18 meter
glider. Probably for a 15 meter glider, too, but I don't recall the
numbers. Blade style transponder antennas are even sleeker.
Com antennas are much larger than the 900-1090 MHz antennas we are
talking about, and can have significant drag, but it's a mistake to rule
out external antennas for the higher frequencies.
email me)
Guess it sort of depends on what you consider to be "insignificant",
Eric. 15 or 18 meter ship, dry, at best L/D only has maybe 20 lbs
TOTAL drag. 1 lbs may not seem like much, but it is 5%. In contest
terms, 50 points. Per day. If there was a really good, really
accurate TE system without using a probe (Schuemann B Box comes to
mind), the really hot pilots would all think just a bit more about
finding a way to put one of those in their plane and do away with the
now seemingly very draggy TE probe. The vertical portion of it is
about the same length as the transponder antenna, but bigger in
diameter.
It may seem like fly specs in the pepper, but over time, it adds up.
So, why do we have TE probes? Because they work, and nobody else has
come up with something that works as well. At least, not as far as I
know.
Steve Leonard
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 26th 12 12:58 AM
If your bored, think about this and notes about Ely, Nv. [email protected] Soaring 15 February 10th 07 12:30 AM
Notes from the RAP pre-OSH party Viperdoc Piloting 2 July 23rd 06 07:24 PM
DG500 AD notes Sailplane Mechanic Soaring 2 August 27th 04 06:35 PM
A few notes from Uvalde Dave Nadler YO Soaring 0 August 13th 04 06:26 PM
