Fuel Range
Old November 14th 03, 12:51 PM
Corky Scott
On Thu, 13 Nov 2003 21:51:39 GMT, "Toks Desalu"
After quick observations, I noticed that fuel range in certified aircraft is
slightly lower than comparable hombuilt aircraft. Anybody agree with this?
Toks Desalu
It's pretty difficult to compare homebuilts to certified aircraf.
Homebuilts are often lighter, more narrow and almost always more
slippery. In addition, Homebuilts usually do not have similar fuel
tank sizes.
For instance, the Christavia Mk4 I'm building is _roughly_ comparable
to the Cessna 172 in performance. But the Christavia specs two wing
tanks at 12 to 14 gallons each plus an optional fuselage tank that
might hold another 8 to 10 or so for a total of maybe 30 or 32
gallons. The C172 holds 54 gallons, 52 useable. At 10 gallons per
hour, the 172 is flying for more than 5 hours, longer if you throttle
back. The Christavia is only in the air for 3 hours.
What airplanes were you thinking of for comparison purposes?
Corky Scott
Fuel Drip Containment Sven Home Built 28 October 27th 03 10:28 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Fuel pressure Problems smf Home Built 3 September 7th 03 08:25 PM
Question ~ Does fuel injection add weight? Barnyard BOb -- Home Built 0 July 6th 03 09:47 PM
