Becker AR4201 mic question
Old October 9th 12, 05:10 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Becker AR4201 mic question
On Monday, October 8, 2012 10:04:31 PM UTC-5, Don wrote:
I have an AR4201 that I have always used with a dynamic boom mic and I swapped it with an AR4201 wired for a standard mic in another glider. After sliding it in the box it receives fine and the mic keys the radio, but I'm not getting any transmit audio. Any ideas what adjustments or software instructions to change? Anyone else seen this problem?
Sounds like you put the radio that was in the ship with a standard mic into your ship that has a dynamic, boom mic?
Did you move just the radio, or the wire harness as well? If you just moved the radio, and not the wire harness (you say you slipped it in the box, so this implies to me that you just did a radio move, nothing else), then I would think there is a problem with the microphone. Did you change radios to see if it was a radio problem or a mic problem? Maybe your dynamic boom mic element has died. I have heard of this happening before.
Steve Leonard
BECKER AR4201 guts Soaring 1 April 23rd 12 09:50 PM
Becker AR4201 Low Voltage Warning Papa3[_2_] Soaring 4 February 9th 12 06:09 AM
Becker AR4201 tuning problem Hellman Soaring 2 October 18th 08 12:14 AM
Becker Radio question Fred[_4_] Soaring 7 June 22nd 08 06:06 AM
VHF Becker AR4201 Philippe Home Built 2 July 9th 04 09:30 PM
