#28
My take on this is that while it is true that both surfaces on a canard or
tandem wing design are lifitng surfaces, the canard cannot use all of the available lift from the main wing - if you want the stall protection - and thus the main wing needs to be made much larger than needed for cruising flight if one is to expect a reasonable landing speed. In the case of my Quickie the Eppler main wing stalls at a fairly high angle of attack but it's peak Cl is not that good. The result is that during landing the canard is doing more than it's share of the work. Some Quickies (all Quickies are single seat - the 2 seaters are Q-2/200's) land as fast as the much maligned BD-5. Another factor to consider is just because the little wing is in the back it must not necessarily be providing down force. It can also lift and still be part of a pitch stable plane. props.. Flat out, the Glasair was faster, but only slightly -- 215 vs. 210 mph. Even this surprises me, I had been led to understand that the canard design is inherently more efficient because the canard wing, besides its basic function as a stabiliser, also helps to generate lift; wheras the stabiliser in a conventional design must push down. So that for every 100 lbs of weight, the main wing in a conventional design carries 110 lbs, in a canard only 90. |
| Thread Tools | |
| Display Modes | |
| Looking for a fast light plane | Dave lentle | Home Built | 2 | August 6th 03 04:41 AM |
| Glass Goose | Dr Bach | Home Built | 1 | August 3rd 03 06:51 AM |
