Hot Spark Ignition
Old November 18th 03, 11:52 PM
- Barnyard BOb -
On Mon, 17 Nov 2003 11:55:19 +0100, Philippe Vessaire
Larry Smith a écrit:
A friend in Florida rigged up his own non-magneto ignition robbed
from a late-model motorcycle and installed it on his O-200-powered
Murphy Renegade. If I recall correctly he has it set up to advance
itself as much as 35
degrees. Any more anecdotes about nonstandard ignition boxes?
I just completed a similar thing.
An old magneto without coil, points...
I drill the distributor and bolt two magnetic sensor at 90° angle
I made a steel plate in the distributor gear for one pulse each 180°
I purchased a CDI box from M&W (http://www.mwignition.com) and two
coils.
Philippe,
http://www.mwignition.com) = no address for host
I would love to build what you have.
Any way to get FULL details?
I realize there are some folks here afraid to
even post tires pressures, but what the hell...
can't hurt to ask. g
FWIW...
In the mid 60's, I built a transistor ignition setup.
It worked, sorta'.. but no way would I have trusted
my life to it in an airplane. Reliability was an issue.
A couple years later, I built a CDI - a lot better....
but still nothing I would install/trust in an airplane.
I'm a pretty damn good tech, but no EE.....
or suicide candidate.
Barnyard BOb -- 50 years of successful flight
Old November 19th 03, 09:24 AM
Philippe Vessaire
Sorry http://www.mwignitions.com
other URLs
http://www.cafefoundation.org/aprs/ignition1.pdf
http://www.cafefoundation.org/aprs/ignition2.pdf
http://www.cafefoundation.org/aprs/ignition3.pdf
From the gear:
1-)an old Slick magneto (4000 serie) with impulse.
I remove all things I can (coil, point, ....)
I drill 8mm holes in the distributor cap and rear plate
I remove the distributor arm inside the distributor gear
I cut a target steel (1,2mm thick or 3/64") and glue it inside the
distributor gear. This target give two pulses for one gear turn, or
two crackshaft turns. I get one pulse each crackshaft turn for one
sensor.
2-) two magnetic sensors from RScomponents
pepperl+fuchs NBB1.5-8GM50-E0
The sensors are bolts on the rear plate (1mm gap between target and
sensor). Their positions are 3 and 4 but may be 4&2, 2&1, 1&3.
3-) CDI box PRO12 and coils from M&W ignitions. The coils are bolt
on the engine case, the CDI box on firewall. You may purchase same
box from MOTEC. This box provide input and output for a
distributorless 4 cylinders engine, a 6 cylinders box is available.
4-) HT wires: automotive "spiral" type , plug cap NGK 5000 ohm
resistor, plug NGK BR8EV. Aircaftsrpuce plug adapter (PN 08-06753).
4-) wiring all together (10 wires), a switch for -12V ON wire
(another +12V wire wthout switch).
The spark sequence is 1&2, 3&4, 1&2, ....... No distributor, no EMI
noise, iddle very smooth and very easy start à 0°C (32°F).
The cost around one half of a new magneto.
The fisrt test is with plugs outside of the engine, turning propeller
with hands and checking the #1 spark position and when the spack is
comming (LED on or LED off)
For advance setting, the sensors have LED in their back. When LED ON,
the advance is OK.
I have two spare holes in the magneto for a second CDI set.
Please, send me your Email for target photo.
By
Philippe Vessaire Ò¿Ó¬
Old November 19th 03, 09:40 AM
Philippe Vessaire
target photo.
http://vessaire.philippe.free.fr/allumage/cible.jpg
Old November 19th 03, 01:34 PM
- Barnyard BOb -
other URLs
target photo.
Many thanks, Philippe.
Please keep us informed of your experiences
as you continue with this project.
With the costs coming in at half of a new magneto
and having to pay something for useable mag guts...
an experimenter might want more input about
how successful this homebrew ignition is in an
aircraft before committing.
I've related my past experiences with DIY
electronic ignitions and none were deemed
worthy by my standards for aircraft. The monies
spent turned out to really be wasted. However,
the time spent and things learned were worth a lot.
So, I'm slow to get excited these days, but extremely
interested in your efforts, successes and failures
as you progress.
Hmmmm.
Thinking aloud....
I wonder if Jim Weir/RST would take on an
electronic ignition project?
What about it Jim? bg
Barnyard BOb --
Old November 19th 03, 08:24 PM
Philippe Vessaire
as you progress.
it don't matter....
About electronic ignition:
as a simple curent amplifier, it is not really the best way for
efficiency. The realiability may be good if you take amplifier module
from last '80s cars (see http://www.transpo.de )
A CDI ignition: I used such a system in my firsts cars (the same box
moving from one to another.... I see the advantage of discharge:
hight output at low rpm, no current in coil if engine not running and
switch ON, no dwell sensitivity....
With my plane, I want reliability AND efficiency.
First choice: CDI system, less coil solicitation.
I don't want multispark systems neither single output.
After I search for simple CDI able to drive distributorless set of
coils. I found M&W or Motec (same box)
I am not afraid about electronics and battery dependent ignition. I
have 12 hours battery ignition range and only 4 hours tank range...
And remember '60s engine Potez, equiped with point and coil dual
ignition.
Another point of vue: how many planes fly with VW, single point
ignition engine?
I feel good with a magneto and a full solid state distributorless CDI
ignition. And when I will acheive 40-50 hours like that, I will build
a second CDI set.
By
Electronic Ignition Andre Home Built 1 September 5th 03 06:15 PM
Ignition Exciter Wiring Juan E Jimenez Home Built 0 August 31st 03 06:03 AM
WTB: Ignition Exciter Juan E Jimenez Home Built 0 August 27th 03 08:09 PM
Wright Flyer Ignition Dan Thomas Home Built 6 July 22nd 03 03:45 AM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 01:37 AM
