Correcting Poly-Brush mistake
Old November 19th 03, 04:50 AM
dale
WRONG! WRONG!WRONG!
Read the manual again several times. Ironing is all done before you put on
the Poly Brush. The only ironing done after the Poly Brush is to the pinked
edges of the tapes. Put that iron out in the middle of the fabric and it
will melt the Poly Brush leaving marks in it. Brush marks are leveled out by
the spray coats of Poly Brush and Poly Spray which is last.
Correct on the pink. The pink tint is only there so you can see where you
have been and is not recommended inside the cockpit unless it is painted.
Old November 19th 03, 03:17 PM
Larry Smith
"dale" wrote in message ...
WRONG! WRONG!WRONG!
You forgot to turn your gd iron down. Go watch some of the pros do it,
amateur. A high spot won't come down by spraying over it. It is done
deftly, gingerly --- not hamfistedly like you. One calibrates the iron to
soften, not to melt.
pinked
by
Old November 20th 03, 12:42 AM
O-ring Seals
On Tue, 18 Nov 2003 21:50:08 -0600, "dale" wrote:
WRONG! WRONG!WRONG!
Dale,
I am in agreement with you. Larry's follow-up is absurd. The iron
properly used on the tapes will save many hours of sanding. And, the
Poly Fiber materials do not sand worth a ****. Above all else, keep
the iron off the open areas once the coatings have been applied. It
is obvious that Larry does not have much experience with fabric work,
or he does not have very high standards.
BTW, the stuff in the bottom of the Poly Brush can is, for the most
part, the fire retardant component. It is good to have the proper
amount on the airplane. I know for a fact that it saved an airplane
that I owned a few years ago.
I had a face to face chat with Ray Stits after that incident. He told
me that at the time he was developing the Poly Fiber process he was
also selling plans for airplanes that could be taken home (Playmate
etc.) and stored in the garage. He said that he would not provide a
covering process that would support combustion.
I have put a flame to strips of finished Ceconite removed from
airplanes (nitrate dope is used for the first coat) and I must say
that the material burns quite nicely.
O-ring Seals
Old November 20th 03, 01:54 AM
Larry Smith
"O-ring Seals" wrote in message
Hey, loud mouth, look at pages 52 and 53 of the Poly Fiber Manual, and then
maybe you'll learn not to open your loud mouth. The chapter is entitled
"Heat Smoothing."
You and the other idiot can retract what you have said or I'll type in the
chapter, word for word.
Old November 20th 03, 03:28 AM
Larry Smith
[blahblahblah bs snipped]
Now THAT is impressive. He knows Ray personally. Our hero.
He told
O save us, dear jayzuss, from the hucksters. Notice when Ray sets fire --
on his videotape they get $35 for and is more a shameless and devious
commercial than anything else -- to a ribbon of doped fabric and a ribbon of
his own with PolyBrush on it, it hasn't yet been painted with aluminum flake
OR Aerothane paint, both of which can burn like hell.
The first picture I get of a Stits-covered airplane burnt into a krispy
kritter, I'm going to put it up in a binary group for display. And don't
forget the gasoline accelerant, there, dingaling.
O-wingdingaling, if you don't think vinyl (as well as the explosive aluminum
powder and polyurethane) will burn violently and outgas some vile toxins,
you ought to have your big ears pulled.
Yes, but have you put a flame to strips of finished Stits or Polyfiber, in
order to see that it burns quite nicely?
Old November 20th 03, 02:25 AM
Larry Smith
WRONG! WRONG!WRONG!
That's right. You A R E wrong, wrong, wrong.
If he read it once, that's more than you've read it.
pinked
by
You are not reading from the Polyfiber manual, then.
This is another one who probably did his last cover job --- a patch on a
hangarqueen wing --- in 1950. Get thee to a manual and read pages 52 and
53 --- "Heat Smoothing."
Old November 20th 03, 04:05 AM
dale
Mr. Smith I stand by what I said. Smoothing is using the iron to smooth the
Poly Tak underneath the fabric and before any Poly Brush has been put on.
Once Poly Brush has been applied the iron is only used on the pinked edges
of the tapes.
Dale
PS Don't be so ugly.
"Larry Smith" wrote in message
WRONG! WRONG!WRONG!
pinked
out
by
you
painted.
Old November 20th 03, 04:15 AM
On Wed, 19 Nov 2003 21:05:48 -0600, "dale" wrote:
:PS Don't be so ugly.
It's not like he has a choice.
Latchless Larry... What a maroon.
Old November 20th 03, 04:39 AM
Larry Smith
of the tapes.
Dale
FO.
Read, if you are capable, (which is in doubt) the key sentence in the "Heat
Smoothing" chapter. It says, "The iron's heat replaces most of the
sanding." Now if you're also capable of understanding (which is also a
matter of considerable doubt) that this chapter comes along in chronological
order AFTER a coat of Poly-Brush, could you not admit that the irons may be
used to smooth out the coat of Poly-Brush. I doubt it, but at least the
poor guy you have gravely misled can know where to find the correct
procedure for smoothing the Poly-Brush before he goes to the Poly-Spray.
O-Ring the Dingaling claims he's an IA. What the hell you do you claim to
be? (Other than someone with a head as hard and thick as adamantine stone?)
Old November 20th 03, 07:03 AM
Ed Sullivan
"Larry Smith" wrote in message ...
of the tapes.
Dale
FO.
O-Ring has restored two Grand Champion Aircraft, one a fabric
covered Bellanca and the other a Cessna 310. He operates a highly
thought of Restoration shop. What the **** have you accomplished.
