Fast glass biplanes
Old November 20th 03, 06:58 AM
Ben Sego
ChuckSlusarczyk wrote:
In article .net, Ben Sego
says...
other than Jim Campbell, he liked it...
Corky Scott
Well, I'm sold then!
He likes anything that he thinks will lead to some ad money :-) He only stops
liking them when they stop the ads. zoom likes it and jaun will probably rebuild
it .....but never fly it. LOL!!!
Chuck(believer in 70 year old data) S
I understand it can be difficult to cancel an ad. Perhaps people aren't
speaking clearly and forthrightly enought to them...er...him.
Ben "governing myself" Sego
  #63
Old November 20th 03, 07:45 AM
- Barnyard BOb -
Jay wrote:
*sigh*
Instead of running numbers on Excel with formulas filled with fudge
factors from experimental data taken 70 years ago, I think I'm going
to throw some wings on my FEA computer model and let the computer take
care of the algebra at 2.4GHz.
I give up. Good luck, and please post or publish your results
when you're done. The world awaits.
Dave 'Pontius Pilot' Hyde
Nice try, Pontius.
However, this outcome was inevitable.
Kinda like with his brother, Latchless. g
Barnyard BOb --
  #66
Old November 20th 03, 07:40 PM
Jay
Thanks Alexy,
I wasn't sure what the convention was in aero work for defining
"aspect", it doesn't really matter as long as everybody agrees on the
same definition! So I just took David's definition and went from
there.
Then in his next expresion said "span^2/aero", so I figured "AERO"
meant something that he hadn't defined, but I should have implicitly
known, and figured at this point it wasn't crucial to the discussion.
But this is the reason why I was trying to discuss relationships
before we got into botched algebra. I'm seem to be continually making
those kinds of errors so I end up doing everything 2 ways just to make
sure.
alexy wrote in message . ..
Dave Hyde wrote:
I think you have a fundamental misunderstanding of the basics here.
An infinte (span) wing has an aspect ratio of INFINITY, not zero.
LARGER aspect ratio is less drag.
Dave, to be fair to Jay, you did type
:The _definition_ of aspect ratio is chord/span
Of course, you immediately contradicted that by typing
r span^2/aero (they're equivalent)
which should have clued anyone in that you had inverted the first
expression.
  #67
Old November 20th 03, 07:57 PM
Jay
Hey don't give up Dave, nobody said it would be easy. You haven't
convinced me not to run the model. But you have pointed out 2 things
I will look at more carefully:
1) Will the root/tip losses from 2 wings eat up any benefit from the
shorter/lighter spans? Are there tip treatments that diminish this?
2) What wing configuration can be used that minimizes mutual
interference between the 2 lifting surfaces.
Thanks!
p.s. I will post the results when I get them.
Dave Hyde wrote in message ...
Jay wrote:
*sigh*
  #69
Old November 21st 03, 12:33 AM
Jay
It looks like Atlantica is still in development, they're using the
same software as I am for my dabbling.
Prescott's Pusher looks like it was pretty ordinary in terms of the
trade offs made (high stall speed), the computer used for that
development looks like it was for manufacturability (CAM) rather than
conducting experiments in aerodynamics. The twitchyness in pitch
people write about is obvious because of the distance between the
center of lift and the elevator, no mystery there. If they'd had the
tools available to the hobbiest today, they'd have been able to see it
before they built it.
Computers aren't perfect, they're programmed by people, with the same
assumptions and errors. But the throughput allows a different type of
analysis to be done than was previously available. Instead of trying
to find a closed form aproximation for a particular parameter of
flight, it allows you to model lots and lots of very simple phenomenon
which come together to produce some high level behaviour like a stall
or another unanticipated effect.
On 19 Nov 2003 10:56:41 -0800, (Jay) wrote:
:Instead of running numbers on Excel with formulas filled with fudge
:factors from experimental data taken 70 years ago, I think I'm going
:to throw some wings on my FEA computer model and let the computer take
:care of the algebra at 2.4GHz.
There you go. Exactly what Alan Shaw did with the Atlantica. It
turned out great. And the Prescott Pusher, designed entirely with
McDonnald Douglass CAD. A terrific airplane. A computer can't go
wrong.
BTW, if you aren't using a Pentium 4 3.06GHz 533Mhz 512K Xeon at a
minumum, you aren't even a serious amateur.
  #70
Old November 21st 03, 12:51 AM
Robert Bonomi
In article , Dave Hyde wrote:
Jay wrote:
Okay, thanks for all that, I think you're missing some parentheses in
there because I'm getting a quad decker formula.
The formula is correct as written.
So with this theoretical wing of aspect approaching zero,
2 non-interfering wings of half span, would be essentially the
same lift and drag as one.
Again, to make a successful break from the mouse-maze, you've
either got to have a sound grasp of the fundamentals or be
very lucky. Counting on luck does not instill confidence
(but sometimes produces interesting threads).
Most if not all of those X planes were R&D payed for by the you and
me, the tax payers of America. Its extremely rare for a large company
to take a "flyer" with their own money and reach very far forward.
Who pays is irrelevant. There have been and will continue to
be radical departures from the 'box' even by giants in the aerospace
industry. The simple fact that you are not aware of them does not
mean that they do not exist.
Dave 'to infinity...and beyond' Hyde
AHA! *THERE's* the proper explanation.
Twin wings, with aleph-sub-one aspect ratio _should_ out-perform a
(merely) 'infinite' AR wing. *snicker* chortle =+GUFFAW+=
Looking for a fast light plane Dave lentle Home Built 2 August 6th 03 04:41 AM
Glass Goose Dr Bach Home Built 1 August 3rd 03 06:51 AM
