Is Spooky safe to take downtown?
Old April 29th 04, 03:56 PM
Yeff
On Thu, 29 Apr 2004 07:50:33 -0600, Tex Houston wrote:
For whoever originated the thread...sure these aircraft aren't AC-130
gunships, callsign 'Spectre' rather than the 'Spooky in the title?
http://www.theaviationzone.com/factsheets/ac130.asp
The AC-130U, commonly referred to as "U-Boat", is the most complex aircraft
weapons system in the world today. It has more than 609,000 lines of
software code in its mission computers and avionics systems. The newest
addition to the command fleet, it is the latest in a long line of
heavily-armed, side-firing gunships and is named "Spooky II" in honor of
the first gunship model, the AC-47D. All other AC-130s are referred to as
"Spectre".
-Jeff B.
yeff at erols dot com
Old April 29th 04, 04:21 PM
Tex Houston
"Yeff" wrote in message
aircraft
"Spectre".
-Jeff B.
Interesting, wasn't aware of the rename. Probably use a tactical callsign
for missions anyway. We probably have too many 'II' aircraft what with
Lightning, Texan and others. Sure confuses the issue when the "II' or 'III'
is omitted.
Thanks,
Tex
Old April 29th 04, 09:49 PM
miso
I watched the weapons school at Nellis shoot up range 61 at night.
They used tracers, which were just barely visible from 10 miles
(estimated) away with the naked eye. With binoculars, the tracer fire
was quite easy to see. Conclusion: I was damn glad they were on our
side. I also concluded the "no trespassing" signs on the bombing
ranges are a good idea.
If it is flying blacked out and no tracers, then it shouldn't be easy
to target. Depending on distance, you could probably see it block out
the stars and sky glow with NV gear. I've seen this with blacked out
pavehawk (or similar shape) helicopters, and something the size of a
herc would make it easier.
"Les Matheson" wrote in message news:KT5kc.3556$pJ1.650@lakeread02...
No tracers these days. Only in training. With all the high tech sensors
you don't need the tracers to aim with (went out with the AC-47), and as you
say, "tracers work both ways."
Les
F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret)
"Kyle Boatright" wrote in message
"miso" wrote in message
om...
I think the opposite question should be asked. Is the crew of the
ac130 safe given the amount of SA gear floating around Iraq. Can the
AC130 maintain a safe distance from the weapons of the resistance?
Henry J Cobb wrote in message
http://globalsecurity.org/military/s...ft/ac-130u.htm
The newest addition to the command fleet, this heavily armed
aircraft
incorporates side-firing weapons integrated with sophisticated
sensor,
navigation and fire control systems to provide surgical firepower
or
area saturation during extended loiter periods, at night and in
adverse weather.
Is Spooky safer for the surrounding civilians than laser guided bombs
or
hellfire missiles for attacks on point targets in urban areas?
-HJC
Spooky flies at night, which makes visual targeting more difficult. In
addition, the most visible thing Spooky does is put out a long line of
tracer fire, which appears to curve as you're watching it. That throws
off
visual targeting too. Finally, if you shoot at Spooky, you'd better hit
it
quick, because it shoots back and is accurate enough to ruin your whole
day.
As far as MANPADS go, Spooky has a decent slant range and effective
countermeasures. MANPADS are not terribly effective under those
circumstances..
KB
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.670 / Virus Database: 432 - Release Date: 4/27/2004
Old April 30th 04, 09:31 AM
John Keeney
"Tex Houston" wrote in message
"John Keeney" wrote in message
Going to war is not safe.
That being said, given how they are used I'ld say they have a real
good chance of coming back from their missions.
gunships, callsign 'Spectre' rather than the 'Spooky in the title? AC-47
'Spooky' aircraft might indeed have a little trouble downtown.
"Spooky", Tex, seems to have become a synonym for
"fixed wing gun ship". The few times we trained with
an AC-130 supporting, the grunts all referred to it as
"Spooky".
Besides, it is as official as such things get that the
AC-130U is "Spooky" instead of "Specter".
Old May 1st 04, 04:48 AM
Peter Kemp
The newest addition to the command fleet, this heavily armed aircraft
incorporates side-firing weapons integrated with sophisticated sensor,
navigation and fire control systems to provide surgical firepower or
adverse weather.
Is Spooky safer for the surrounding civilians than laser guided bombs or
One thing I saw in Janes Defence Weekly recently was that Hunter UAVs
armed with Viper Strike munitions (BAT with laser rather than
acoustic/IR sensors) has been cleared for use in Iraq - now that
should be damn useful for low collateral damage urban ops.
Peter Kemp
Old May 1st 04, 05:42 AM
Kevin Brooks
"Peter Kemp" wrote in message
adverse weather.
Another nice tool, but it does little to address the problem of the
mortar-crew-in-the-courtyard (I don't think the BAT submunition (which uses
a SFF, IIRC, as its killing mechanism) would be particularly lethal against
anything other than a vehicle, but correct me if I am wrong), nor will it be
particularly useful against an enemy position in a building. The AC-130 is
good at taking out both.
Brooks
Peter Kemp
Old May 15th 04, 05:54 PM
Henry J Cobb
Frank Vaughan wrote:
In message , "John Keeney"
"Spooky".
Spectre
Frank Vaughan "Spectre Gunner"
Vietnam Veteran -- AC-130E Spectre Gunships
Yes, you served on a Spectre, but the AC-130U is "Spooky".
Would you believe the Air Force on this?
http://www.af.mil/factsheets/factsheet.asp?fsID=71
The AC-130H's call sign is "Spectre." The AC-130U's call sign is
"Spooky. "
-HJC
Old May 16th 04, 05:23 AM
Les Matheson
Frank was correcting the spelling of "Spectre" not saying that the U model
is not "Spooky"
Les
"Henry J Cobb" wrote in message
"Spooky".
Spectre
"Spooky. "
-HJC
Version: 6.0.684 / Virus Database: 446 - Release Date: 5/13/2004
Baghdad airport safe to fly ?? Nemo l'ancien Military Aviation 17 April 10th 04 12:58 AM
Minimum Safe Altitude (MSA) Standards O. Sami Saydjari Instrument Flight Rules 23 April 6th 04 04:28 AM
Anti-Aircraft missiles in downtown Washington D.C. Kevin Brooks Military Aviation 3 February 18th 04 08:13 AM
