Sisteron SGP 2014
Old May 16th 14, 09:08 PM posted to rec.aviation.soaring
Default Sisteron SGP 2014
On Friday, May 16, 2014 1:34:57 PM UTC-5, Gary Ittner wrote:
wrote : - interesting to see how wing's loading was limited to 50 kg/m per square meter in favor of older ventus designs.... I think it was a direct attack on the Diana 2's... the V2/29/27's couldn't compete with it at 58kg/sqm. The maximum certificated wing loadings for the gliders at the Sisteron Grand Prix a LS 8 50.00 kg/sqm Ventus 2 54.29 kg/sqm ASW 27 55.56 kg/sqm Diana 2 57.87 kg/sqm ASG 29/15 59.80 kg/sqm If restricting all the gliders to the same 50 kg/sqm wing loading "hurts" the Diana 2, it hurts the ASG 29/15 even more. So how is this a direct attact on the Diana 2 ? Gary Ittner P7 "Have glider, will race"
- So if Ventus design is heavier than for instance Diana 2, which glider will run better at 50 kg/sqm?
Why is there a restriction in the first place, other than to favor certain glider types?
Old May 16th 14, 11:25 PM posted to rec.aviation.soaring
Andy K
wrote : - interesting to see how wing's loading was limited to 50 kg/m per square meter in favor of older ventus designs... I think it was a direct attack on the Diana 2's... the V2/29/27's couldn't compete with it at 58kg/sqm. The maximum certificated wing loadings for the gliders at the Sisteron Grand Prix a LS 8 50.00 kg/sqm Ventus 2 54.29 kg/sqm ASW 27 55.56 kg/sqm Diana 2 57.87 kg/sqm ASG 29/15 59.80 kg/sqm If restricting all the gliders to the same 50 kg/sqm wing loading "hurts" the Diana 2, it hurts the ASG 29/15 even more. So how is this a direct attact on the Diana 2 ? Gary Ittner P7 "Have glider, will race"
Does anyone know when the restriction was put in place before or after Diana 2 showed up?
Old May 16th 14, 11:32 PM posted to rec.aviation.soaring
Andy K
Prix a
LS 8 50.00 kg/sqm
ASW 27 55.56 kg/sqm
Gary Ittner P7
Not necessarily. The airfoil of Diana 2 was designed to climb very well at high wing loading. There is a Diana 2 design paper. It was a very interesting read.
Old May 17th 14, 12:13 AM posted to rec.aviation.soaring
Papa3[_2_]
I'd look at it a bit differently. I thought that the premise of the Grand Prix was to make it about pilot vs. pilot as opposed to a pure technology race. Since the majority of gliders have to be built to survive in a broad range of uses (i.e. not just optimized for high-end racing), the rule probably makes sense if that's the context. No?
Old May 17th 14, 01:10 AM posted to rec.aviation.soaring
Paul T[_4_]
Doesn't make much difference if you followed the race online -
you'd see that tatics played an important part in today's race.
Hauss took a significantly different line from the other guys coming
out of TP3 - Kawa was approx 100-150m below Hauss at the hill
just before Serres and delayed quite significantly following him up
to the 4th turning point, where Hauss had to climb up and over the
ridgeline to get to TP4 - then's when Hauss started to pull away..
I think Kawa has alluded in the past about about the wingloading
limit being imposed to stop the Diana romping away from the v2's ,
27 and 29's - especially in the mountains.
Simple solution - make everyone fly the same model of glider for
GP. Believe this was the idea a few years ago when the FAI
supposedly had some big media/TV guys interested in Gp's.
Maybe they ought to start linking up with some of the big players in
the gambling world?
Put them all in Duckhawks, with fancy colours?
Old May 17th 14, 02:14 AM posted to rec.aviation.soaring
Yes, but you can't stand it on it's tip and circle up the side of a mountain at those wingloadings in anything else. The advantage is less in the flatlands.
After.
Kawa had a chapter about it in his book. A snippet is on his website too.
http://skyfullofheat.com/ask-sebastian/why-diana-2/
Old May 17th 14, 02:25 AM posted to rec.aviation.soaring
Gary Ittner[_3_]
interesting read.
Ah, I understand you. The ASG 29 airfoil was probably designed to climb
poorly at high wingloading.
The Sisteron World Grand Prix Final was not a race run according to FAI 15m
class rules, but a special race that in this case used a wing span limit of
15m and a wing loading limit of 50 kg/sqm. If the loading limit was an
attack on the Diana 2 and ASG 29 by not allowing them to use their loading
advantage over the Ventus 2, then was the span limit an attack on the Ventus
2 cxa and ASG 29 by not allowing them to use their span advantage over the
Diana 2? (Poor ASG 29; doubly attacked)
Some Grand Prix qualifying races have already been run using 18m gliders,
and I have heard a rumor that the next World Grand Prix Final may be 18m.
Will Diana 2 fans consider that a slap in the face?
If plantain and gkurek care to see a _real_ attack on the Diana 2, they
should seek out an article in Gliding International from a couple years ago,
in which former 15m European Champion Steven Raimond proposes the Diana 2 be
banned from international 15m competition and goes on to state his reasons
(note: I totally disagree with Steve's proposal, and have not heard of
anyone at the IGC seriously considering it).
Gary Ittner P7
Old May 17th 14, 03:14 AM posted to rec.aviation.soaring
GR8
On Sunday, May 11, 2014 1:15:09 AM UTC-4, GR8 wrote:
http://www.sgp.aero/final2014.aspx
The race was won by a great french glider pilot Didier Hauss, strictly on the merits of his superior tactic and his knowledge of local weather and terrain. Gliders didn't really matter.
Old May 17th 14, 04:14 AM posted to rec.aviation.soaring
Andy K
interesting read.
Gary Ittner P7
Gary, please don't quote me and then bring up an attack on Diana 2 in the same response as I had not made such statements.
The race was won by the better pilot and there is no doubt about it.
Old May 17th 14, 09:55 AM posted to rec.aviation.soaring
interesting read.
Or alternatively, the Diana 2 was designed to achieve superb climbing performance.
Page 3 onwards - http://www.rcgroups.com/forums/showa...mentid=3774296
Live coverage of the Sailplane Grand Prix in Sisteron France Paul Remde Soaring 3 May 9th 14 02:15 PM
2014 Region 5N video Sean Franke Soaring 4 April 28th 14 02:23 PM
PHOTOS: March 14-15, 2014 Digital Voices[_5_] Aviation Photos 2 March 17th 14 07:54 AM
PHOTOS: March 8, 2014 Digital Voices[_5_] Aviation Photos 0 March 9th 14 07:47 PM
WGC 2014 Finland Car+crew available [email protected] Soaring 1 August 8th 13 07:06 PM
