ERIXX to Dell Streak via Bluetooth
Old November 12th 14, 05:45 PM posted to rec.aviation.soaring
Default ERIXX to Dell Streak via Bluetooth
Does anyone have experience with connecting an ERIXX flight logger with XC Soar via Bluetooth? I've got a Dell Streak running XC Soar 6.7.5 and an ERIXX flight logger that I would like to connect to one another for GPS position and pressure altitude. I've been looking at the NEMA Bluetooth module available at the following link. Has anyone done this successfully?
http://www.millenair.nl/shop/index.php? ... duct_id=91
Old November 12th 14, 06:19 PM posted to rec.aviation.soaring
Paul Remde
Hi,
A K6Bt would work well for that. I have them in stock.
http://www.cumulus-soaring.com/k6.htm#K6Bt
I could also provide a Goddard cable for connecting the Erixx to the K6Bt
and 12V power. The Erixx and K6Bt would both be powered by 12V.
However, I should mention that the cost of the K6Bt ($200) and custom
power/data cable ($75) are about 2/3 to 3/4 of the price of a new Oudie 2
Lite ($375) - which is supplied with a power/data cable which will connect
directly to the Erixx. You can run XC Soar on the Oudie 2 Lite. For $625
you would get an Oudie 2 with a SeeYou Mobile Lifetime License. The Oudie 2
has been extremely popular. It is a great product.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old November 12th 14, 11:01 PM posted to rec.aviation.soaring
Dan Marotta
I use a K6Bt to connect my CAI-302 to my Dell Streak via bluetooth. It
was straight forward and easy to do. Or you could look into an IOIO device.
Dan Marotta
Best way to connect US PowerFlarm to Dell Streak 5 Blake Seese Soaring 1 July 2nd 14 01:09 AM
Dell Streak - what ROM version? [email protected] Soaring 7 May 24th 14 06:09 PM
Temperature Probe for Dell Streak Dan Marotta Soaring 14 April 20th 13 03:56 AM
Dell Streak 5 available soartech[_2_] Soaring 0 November 14th 12 06:44 PM
Short review of the Dell Streak with XCSoar Max Kellermann Soaring 6 February 9th 11 05:22 PM
