What is the L/D penalty of outside mounted GoPros?
Old January 3rd 15, 10:28 PM posted to rec.aviation.soaring
jfitch
Default What is the L/D penalty of outside mounted GoPros?
On Saturday, January 3, 2015 12:55:47 PM UTC-8, wrote:
I am thinking about trying to do some soaring videos. Inside the cockpit footage only is boring and I want to be more like Balleka with amazing outside camera shots. The reason why I haven't done much is concern over the performance penalty of outside cams while trying to do longer XC flights.
Anyone smarter than me (I know most of you are, other than TT) able to figure out the drag penalty of a GoPro either mounted on the wing or on the tail of a 27? It would be attached with the adhesive mount and not the larger suction cup mount in hope of reducing the drag. The GoPro in its larger case to accommodate an extra battery is 41mm H x 59mm W x 40mm D.
What I am hoping to figure out is if it is a 1-2 point L/D penalty or something more like a 4-5 point drop. Those of you who have flown with me know I need every L/D point I can get.
Here's to hopefully a lot of fun 2015 soaring videos shared from a bunch of us!
Bruno - B4
Oh yeah - and Nephi is amazing!
Very roughly: at 48:1 flying at 1000 lbs, total drag is 20.8 lbs. At 60 knots, dynamic pressure is 12.2 lbs/sq ft. Camera is roughly .1 sq ft, adding 1.2 lbs drag, increasing your total to 22 and reducing L/D to 45.5. That is probably pretty worst case (drag coefficient probably less than 1, not in free stream, etc.). A tiny bit of streamlining on it could improve that a great deal I would think.
Externally mounted GoPros okay? Jim Lewis[_2_] Soaring 4 December 30th 14 11:52 PM
UO penalty @ Hobbs For Example John Smith Soaring 4 June 12th 05 09:34 PM
There is no penalty for failing to make the required FAA reports or investigation! Larry Dighera Piloting 9 October 12th 04 05:06 AM
TFR Penalty Magellan Piloting 9 September 5th 04 02:24 AM
~ US JOINS CHINA & IRAN AS TOP DEATH PENALTY USERS ~ Matt Wiser Military Aviation 0 April 8th 04 03:55 PM
