WWII FW190's, how good were they in dogfights?
Old May 23rd 04, 03:53 PM
The Enlightenment
"ArtKramr" wrote in message
Subject: WWII FW190's, how good were they in dogfights?
Date: 5/22/04 12:50 AM Pacific Daylight Time
In a bad landing at night the pug nosed FW190A could over nose and
end
up on its back. As the pilot was in a bubble canopy he could
easily
be killed and frequently was.
Ol' Willie never could design a decent landing gear.
The gear was adaquete for the Emil and Fritz (109E and 109F) if a bit
cantankerous: however by the time the heavier Gustav (which replaced
the DB601 with the more powerfull and havier DB605 engine) the
problem got worse. It was basically a problem caused by gyroscopic
precesion (the takeoff swing only on landing) that was made worse by
the narrow track of the undercarriage. A contarotating propellor
would have solved it for instance.
The undercarriage had the advantage of being pined to the fueselage,
thus saving structural weight and allowing easy disassembly of the
wings for transport. (the aircraft could stand on its undercarriage
with its wings detached)
Towards the end of the war the synthetic fuel plants started producing
higher octane fuel. This might have delayed the the need to oversize
the German engines had it come as early as supplies of high octane
came to the Allies.
I don't believe the Me 110, Me 108 or any other Me had under-carriage
problems.
The Me 262 had nose wheel collapse problems but they were due to
faulty materials.
Old May 24th 04, 02:51 AM
Krztalizer
faulty materials.
I disagree - in nearly every case, the failure of the nose gear on a 262 could
be traced back to incorrect towing procedures. Putting the entire weight of an
aircraft on the axel of the nose gear and yanking it around with a Krad is a
sure recipe for an accident. Pilots that mention the fragile nose gear were
usually talking about this type of accident, not failures during landing or
takeoff.
v/r
Gordon
====(A+C====
USN SAR
An LZ is a place you want to land, not stay.
Hiroshima/Nagasaki vs conventional B-17 bombing zxcv Military Aviation 55 April 4th 04 08:05 AM
Good Ad! WWII Pilot Joe Military Aviation 0 January 11th 04 10:37 PM
P-47/51 deflection shots into the belly of the German tanks,reality ArtKramr Military Aviation 131 September 7th 03 10:02 PM
FA: WWII B-3jacket, B-1 pants, Class A uniform N329DF Military Aviation 1 August 16th 03 04:41 PM
