#21
Ron Wanttaja writes:
On Mon, 01 Dec 2003 20:09:35 GMT, Kyler Laird wrote: Ron Wanttaja writes: Well... as far as homebuilts are concerned, fuel exhaustion (defined as the pilot running the airplane out of fuel) plays only a minor role in the overall accident rate. During 1998-2000, only 4.5% of all homebuilt accidents involved fuel exhaustion (including some accidents that occurred during precautionary landings due to a low fuel state). How many of "all homebuilt accidents" involved an "emergency landing"? (I don't think we mean "landing" to include "falling to earth in pieces".) About 20% of the homebuilt accidents in that period involved a loss of power due to mechanical failure of the engine or fuel system (vs. pilot mismanagement of fuel or power system). About 15% engine related, about 5% fuel-system related. So are you saying that there's a 1:1 relationship between losing power and making an emergency landing? No one loses power and performs a stall/spin return to the ground? I'm just trying to get back to the point about fuel probably being already exhausted when an emergency landing is executed. Are you saying that three of every four emergency landings are made with significant quantities of fuel on board? (Another complication is that it's fairly common to still have gobs of fuel on board even when fuel starvation is the cause of the accident.) --kyler |
Ed Wischmeyer writes:
BTW, do any homebuilts use easily-sheared tip-tanks (like some Cessnas and Lears do)? Easily sheared Cessna tip tanks, like on a twin? Don't think the accidents show that those shear... what's your source? No source. I just heard that that's the way they were designed. I assume they shear a lot more easily than the tanks in my wings do. --kyler |
On Tue, 02 Dec 2003 17:09:41 GMT, Kyler Laird
wrote: Ron Wanttaja writes: Well... as far as homebuilts are concerned, fuel exhaustion (defined as the pilot running the airplane out of fuel) plays only a minor role in the overall accident rate. During 1998-2000, only 4.5% of all homebuilt accidents involved fuel exhaustion (including some accidents that occurred during precautionary landings due to a low fuel state). How many of "all homebuilt accidents" involved an "emergency landing"? (I don't think we mean "landing" to include "falling to earth in pieces".) About 20% of the homebuilt accidents in that period involved a loss of power due to mechanical failure of the engine or fuel system (vs. pilot mismanagement of fuel or power system). About 15% engine related, about 5% fuel-system related. So are you saying that there's a 1:1 relationship between losing power and making an emergency landing? No one loses power and performs a stall/spin return to the ground? Certainly, to a depressing extent, especially when the engine failure occurs on takeoff. I apparently didn't make my point clear: Another poster commented that "If you are making an emergency landing in a small plane, chances are that you don't have any fuel left on board to dump." My response was meant to counter this, in that fuel-exhaustion-related accidents were a relative minority. I'm just trying to get back to the point about fuel probably being already exhausted when an emergency landing is executed. Are you saying that three of every four emergency landings are made with significant quantities of fuel on board? No. All I said on my original posting was that 4.2% (I posted "about 4.5%") of all homebuilt accidents in the January 1998 to December 2000 time period (29/692) involved fuel exhaustion. I make no claim about how much fuel remained in the remaining 660-odd accidents that year, other than to guess that the NTSB investigator apparently considered there was sufficient fuel on board to rule out lack of fuel as a reason for a loss of power situation. (Another complication is that it's fairly common to still have gobs of fuel on board even when fuel starvation is the cause of the accident.) Out of the 29 cases of fuel exhaustion, two cases involved a crash during a precautionary landing due to a low fuel state, one involved the fuel tank unporting when the pilot maneuvered at low attitude with a low fuel state, one had a bad header tank, and one pilot failed to select his reserve tank when the main tank ran dry. Three cases of extremely low fuel, two of some amount of fuel. In the remaining 24 cases, the engines quit because the pilot used up all his or her usable fuel (one case included a leaking fuel tank). That would still leave several gallons aboard each aircraft. In ~660 accidents, then, the airplane crashed with sufficient fuel on board to have enabled continued flight. I personally don't think a fuel-dump valve would have helped in most of these cases. But I suspect it's like the ballistic parachute argument; if you need one, then you REALLY need one. :-) Ron Wanttaja |
Ron Wanttaja wrote:
No. All I said on my original posting was that 4.2% (I posted "about 4.5%") of all homebuilt accidents in the January 1998 to December 2000 time period (29/692) involved fuel exhaustion. I make no claim about how much fuel remained in the remaining 660-odd accidents that year, other than to guess that the NTSB investigator apparently considered there was sufficient fuel on board to rule out lack of fuel as a reason for a loss of power situation. (Another complication is that it's fairly common to still have gobs of fuel on board even when fuel starvation is the cause of the accident.) Out of the 29 cases of fuel exhaustion, two cases involved a crash during a precautionary landing due to a low fuel state, one involved the fuel tank unporting when the pilot maneuvered at low attitude with a low fuel state, one had a bad header tank, and one pilot failed to select his reserve tank when the main tank ran dry. Three cases of extremely low fuel, two of some amount of fuel. In the remaining 24 cases, the engines quit because the pilot used up all his or her usable fuel (one case included a leaking fuel tank). That would still leave several gallons aboard each aircraft. In ~660 accidents, then, the airplane crashed with sufficient fuel on board to have enabled continued flight. I personally don't think a fuel-dump valve would have helped in most of these cases. But I suspect it's like the ballistic parachute argument; if you need one, then you REALLY need one. :-) Let's not rule out the one advantage of the fuel dump we haven't discussed - that anyone who had to deadstick in due to fuel starvation could then claim he had dumped the fuel to prepare for the deadstick landing. Sure, he'd have some 'splainin' to do when the beast fires right up when resupplied with go-juice, but he could always pull a Unka BOb and claim it was just one of those evil intermittent auto engine systems. Mark Hickey |
Let's not rule out the one advantage of the fuel dump we haven't discussed - that anyone who had to deadstick in due to fuel starvation could then claim he had dumped the fuel to prepare for the deadstick landing. Sure, he'd have some 'splainin' to do when the beast fires right up when resupplied with go-juice, but he could always pull a Unka BOb and claim it was just one of those evil intermittent auto engine systems. Mark Hickey ++++++++++++++++++++++++++++++ All machinery has the capacity to be evil. *Certified* is just less evil in competent hands. Unka BOb -- |
On Wed, 03 Dec 2003 10:59:02 -0700, Mark Hickey wrote:
Let's not rule out the one advantage of the fuel dump we haven't discussed - that anyone who had to deadstick in due to fuel starvation could then claim he had dumped the fuel to prepare for the deadstick landing. Sure, he'd have some 'splainin' to do when the beast fires right up when resupplied with go-juice, but he could always pull a Unka BOb and claim it was just one of those evil intermittent auto engine systems. Actually, he might not have to explain too much. This sort of scenario does happen (where the engine runs OK afterwards), and the NTSB usually just chalks it up to "Engine failure for undetermined reasons." Ron Wanttaja |
#28
or one could say it was certifiably evil.....
![]() Sean RR Urban wrote: Let's not rule out the one advantage of the fuel dump we haven't discussed - that anyone who had to deadstick in due to fuel starvation could then claim he had dumped the fuel to prepare for the deadstick landing. Sure, he'd have some 'splainin' to do when the beast fires right up when resupplied with go-juice, but he could always pull a Unka BOb and claim it was just one of those evil intermittent auto engine systems. Mark Hickey ++++++++++++++++++++++++++++++ All machinery has the capacity to be evil. *Certified* is just less evil in competent hands. Unka BOb -- |
#29
![]() Sean |
#30
Mark Hickey wrote:
Let's not rule out the one advantage of the fuel dump we haven't discussed - that anyone who had to deadstick in due to fuel starvation could then claim he had dumped the fuel to prepare for the deadstick landing. I am reminded of the following accident report which I found quite humorous. This is a partial quote from an NTSB accident report of a C-150 forced landing near Four Corners Regional Airport, Farmington, New Mexico circa October 2003, "According to the tower operator at FMN, as the airplane was entering a left base for runway 07, a expletive was heard over the tower frequency and shortly thereafter an emergency locator transmitter (ELT) signal was heard. According to emergency personnel, when they arrived on scene, they found the pilot had already pulled himself out of the inverted airplane and was sitting on the wing. The pilot told them "don't worry about a fire, there's no fuel." David O -- http://www.AirplaneZone.com |
| Thread Tools | |
| Display Modes | |
| Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 03:57 AM |
| Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 08:09 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 04:07 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 06:12 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
