LXnav software with OS X / Wine
Old January 28th 18, 04:05 PM posted to rec.aviation.soaring
Sarah[_2_]
Default LXnav software with OS X / Wine
Hi all,
The windows box I used for these things has ceased to be.
It was surprisingly easy to get "LXSim" working using WINE and the wonderful http://winebottler.kronenberg.org/
But the other one I need, "LXStyler" doesn't quite work. It starts, but selecting a configuration and then any page pops up an empty windows "Critical Error" box and it's locked up.
I suspect there's some magic DLL(s) or other trick I need beyond the default install. Anyone done this?
Old January 28th 18, 04:22 PM posted to rec.aviation.soaring
Kevin Christner
Probably not exactly the answer you're looking for, and would be interested in hearing others experiences, but Parallels Desktop has been flawless for me across a number of Windows applications. Retails for around $70.
On Sunday, January 28, 2018 at 10:05:56 AM UTC-5, Sarah wrote:
Hi all,
Old January 28th 18, 05:28 PM posted to rec.aviation.soaring
jfitch
Hi all,
Either Parallels or VMWare Fusion will very likely run it perfectly. I've yet to find a Windows program that does not run.
Old January 28th 18, 09:13 PM posted to rec.aviation.soaring
Peter Wilson[_2_]
been
for
around $70.
I run it under parallels and it works fine
Old January 28th 18, 09:39 PM posted to rec.aviation.soaring
Darryl Ramm
VMware Fusion and a full copy of whatever Windows version you want/need.
All the LXNav and SeeYou software runs under Windows 10 on the latest VMware Fusion on the latest macOS releases and has for years.
That VMware stuff is just the most amazing, wonderful, fantastic, software. And I'm totally unbiased.
On Sunday, January 28, 2018 at 7:05:56 AM UTC-8, Sarah wrote:
Hi all,
Old January 28th 18, 09:47 PM posted to rec.aviation.soaring
marco
Hi all,
I used: https://www.davidbaumgold.com/tutorials/wine-mac/
Slightly more work but it is also easy to follow.
Parallels is wine, in a commercial way.
I do not run an LX program but use this for SeeYou. Runs OK.
Old January 28th 18, 10:23 PM posted to rec.aviation.soaring
Darryl Ramm
Parallels and VMware Fusion are *not* Wine in a commercial or any other real way.
Parallels and Fusion are virtual machine monitors, they let multiple operating systems run on the computer hardware. Wine is a Windows operating system emulator (regardless of if the name tries to say otherwise). Wine has the benefit of not needing a Windows operating system, at the disadvantage of lots more compatibility issues, and well for some things you really want Windows, warts and all.
Old January 28th 18, 10:55 PM posted to rec.aviation.soaring
Sarah[_2_]
Thanks all, I'm aware of Parallels & VMware. I asked about Wine for a reason - I'm cheap. My need for windows is sporadic (Once a season toying with LXStyler, maybe a spring refresher with LXSim). I don't want to buy a subscription based program, like Parallels, and the associated Windows OS. Do you need to buy a copy of WIndows for VMware? It wasn't obvious on their website.
Encouraged by my luck with LXSim, I tried LXStyler. It's close - as I said, I think I've just not got the right libraries. I read on the LXnav site Styler requires .NET 2.0 ... and as I recall there was a VB dependency as well.
Old January 28th 18, 11:05 PM posted to rec.aviation.soaring
Darryl Ramm
Yes you need a copy of Windows to run in VMware Fusion, just the same as with Parallels. Didn't a handsome clever person just say they are both virtual machine monitors :-)
Unless you know for sure stuff runs with Wine and you are unlikely to have more need then it can be a false economy. I'd love to burn Windows but there are a half dozen or so apps (esp. Naviter SeeYou and Condor) that I just have to have and want them with me on my MacBook Pro, and then always some other new app to want to try out.
Old January 28th 18, 11:22 PM posted to rec.aviation.soaring
jfitch
Once you have VMWare or Parallels (and Darryl may not be quite as unbiased as he says...) there is a trick to running Windows without a license. Microsoft on their developer website maintains Virtual Machine disks for many different versions of Windows for VMWare and Parallels. You can download these for free, they work for 30 days and then time out. Their intended use is to test IE, but I have in the past used them for testing other things.
LXNAV V7 Paul Remde Soaring 2 November 2nd 11 01:31 AM
EW loggers and Linux + WINE Martin Gregorie[_4_] Soaring 4 December 18th 08 12:37 AM
Wine with your 100LL? tom Piloting 52 January 1st 06 04:54 AM
Safelog software/flight log software question Mark Piloting 2 December 8th 03 03:34 PM
x-plane under wine Tim Hogard Simulators 1 August 31st 03 02:28 PM
