Winching - Reverse Auto Tow
Old July 26th 16, 05:27 PM posted to rec.aviation.soaring
Default Winching - Reverse Auto Tow
On Tuesday, July 26, 2016 at 8:38:31 AM UTC-6, Steve Leonard wrote:
I would get a 15 to 17 inch rim from a junk yard. Cheap, steel, plain. Then, get a stub axle and hub from Tractor Supply or the like with at least a 2000 lb load rating. No need for guides. No need for swivels. Axis of rotation for the wheel to be horizontal, running side to side. Your pull off angles to the side (for the anchor, or the glider while climbing) will never be more than a few degrees, and the rope will not want to climb out of the deepest part of the wheel. Don't add more complication than is needed. With 8000 feet of ramp, you probably don't need much more than 6000 feet of rope.
If you are anchoring the pulley (say, to a parked car), still no need for a swivel. Keep your life simple!
Just my two cents worth.
Steve Leonard
Steve, that is exactly what I was planning to do at first. As I looked at other applications, I began to think that I was making it too simple, and needed more precision. Maybe some other designs are overly complex.
  #52
Old July 26th 16, 05:28 PM posted to rec.aviation.soaring
On Tuesday, July 26, 2016 at 1:51:14 AM UTC-6, Peter Whitehead wrote:
On Tuesday, 26 July 2016 02:12:58 UTC+1, wrote:
Does anyone have particularly bad experiences with pulleys used like this. I am talking about the pulleys themselves. Has someone found a particular diameter that is too small. Obviously larger is better for both bearing speed and rope bending, but there are limitations on cost and availability...particular for the trial run I'm thinking about. I am considering a trial run with a swiveling pulley on the receiver hitch of a pickup, no guides, just the pulley, with around 8,000' of 1/4" poly hollow braid, flying a 1-26. That should prove the launch height, assuming the rope doesn't break on the first launch. I'm not sure what to expect at the pulley end, and don't want the rope jumping out of the sheave, catching and breaking. I doubt it will, but have no experience to back it up.
Hi, I wrote an article "The Expedition Pilot's guide to launching" in the Dec2013/Jan 2014 edition of the UK Sailplane and Gliding magazine. It may be of interest. I use 12mm diameter high density polypropylene rope (Skyrope from Skylaunch) on snatch blocks with, initally steel pulleys on plain bearings 110mm dia. The bearings cooked in spite of lots of grease! These have been modified for regular use to nylon pulleys with steel ball bearings. The steel flaps or cheeks of the snatch blocks keep the rope where it should be. I use either a 2 to 1 or 3 to one system to keep the tow speed down ( we use some rough fields). If you are serious then I can send you a copy of the article and details of the kit, as well as the links to YouTube videos of some launches in the Lake District (UK) using 2 to 1 pulley system, with one pulley on a ground anchor and the other on the car's tow hitch (with the rope tail to another ground anchor). Everything used is inexpensive, and it works. Pete Whitehead
Pete, I watched your videos, and those look like strong launches! Much better acceleration than we typically see. If you could send me an electronic copy of your article, I would love to read it.
  #53
Old July 26th 16, 05:44 PM posted to rec.aviation.soaring
Bruce Hoult
Hi, I wrote an article "The Expedition Pilot's guide to launching" in the Dec2013/Jan 2014 edition of the UK Sailplane and Gliding magazine. It may be of interest. I use 12mm diameter high density polypropylene rope (Skyrope from Skylaunch) on snatch blocks with, initally steel pulleys on plain bearings 110mm dia. The bearings cooked in spite of lots of grease! These have been modified for regular use to nylon pulleys with steel ball bearings.. The steel flaps or cheeks of the snatch blocks keep the rope where it should be. I use either a 2 to 1 or 3 to one system to keep the tow speed down ( we use some rough fields). If you are serious then I can send you a copy of the article and details of the kit, as well as the links to YouTube videos of some launches in the Lake District (UK) using 2 to 1 pulley system, with one pulley on a ground anchor and the other on the car's tow hitch (with the rope tail to another ground anchor). Everything used is inexpensive, and it works. Pete Whitehead
Yes, the launches shown here look like normal launches from a pretty powerful winch, not the average rather anaemic direct-pull car launch. Sadly, we don't see anything of the vehicle or launch setup
https://www.youtube.com/channel/UC_G...WaGdMMduefDVAg
  #54
Old July 26th 16, 06:39 PM posted to rec.aviation.soaring
Dan Marotta
On 7/26/2016 9:28 AM, wrote:
Snip If you could send me an electronic copy of your article, I would love to read it.
Or post it on Dropbox or similar so we can all read it!
Dan, 5J
  #55
Old December 29th 18, 05:19 AM posted to rec.aviation.soaring
John Foster
This one gives a little more detail of the mechanical set-up. Surprising they are able to get that kind of acceleration from such a small vehicle.
  #56
Old December 31st 18, 04:17 AM posted to rec.aviation.soaring
John Foster
https://www.youtube.com/watch?v=Q0rv1zOmyWg
  #57
Old December 31st 18, 05:18 AM posted to rec.aviation.soaring
Frank Whiteley
Anchored plus reverse pulley, so mechanical advantage of 2 plus speed reduction of 2, so the launch vehicle probably weighes 3,000lb or more so it can provide a 60mph rope speed at 30mph and not break traction on grass. Thus it can give a snappy launch. Slow turn around but better than just anchor pulley for short fields. Appears they can snap onto a working ridge nearby.
Frank Whiteley
  #58
Old December 31st 18, 06:26 AM posted to rec.aviation.soaring
Frank Whiteley
It's a anchor/reverse pulley, thus different from the old Cotswold setup. 2x pull advantage and 2x rope acceleration, so a 2600-3000lb launch vehicle could provide adequate power and not break traction on turf using 4WD.
IMVHO,
Frank Whiteley
  #59
Old December 31st 18, 05:19 PM posted to rec.aviation.soaring
Does anyone have particularly bad experiences with pulleys used like this. I am talking about the pulleys themselves. Has someone found a particular diameter that is too small. Obviously larger is better for both bearing speed and rope bending, but there are limitations on cost and availability...particular for the trial run I'm thinking about. I am considering a trial run with a swiveling pulley on the receiver hitch of a pickup, no guides, just the pulley, with around 8,000' of 1/4" poly hollow braid, flying a 1-26. That should prove the launch height, assuming the rope doesn't break on the first launch. I'm not sure what to expect at the pulley end, and don't want the rope jumping out of the sheave, catching and breaking.. I doubt it will, but have no experience to back it up.
This one gives a little more detail of the mechanical set-up. Surprising they are able to get that kind of acceleration from such a small vehicle..
Frank Whiteley
The 2x speed advantage means a 1/2x force disadvantage, no? The car has to accelerate its own weight, plus twice the tension of the rope. Better have a big engine. After it reaches the needed speed (say 30mph for the car - 60mph for the glider) then no further acceleration is needed, so the car's own mass no longer matters and the engine only has to keep the 2x rope tension going (which gradually reduces towards 1x as the angle of airborne part of the rope increaes). Assuming 1000 pounds tension, 2000 pounds pull, at 30 mph, that's a delivered mechanical power of about 150 HP.
  #60
Old January 1st 19, 12:04 AM posted to rec.aviation.soaring
WB
Frank Whiteley
The SES tow car we used for pulley launch was a late 70's Ford LTD out of a junkyard. It had the 460 cubic inch engine, but it appeared to be running on only 5 cylinders or so. That worked in our favor. Had just the right amount of horsepower to launch a loaded 2 seater. Put it in low gear, floor it and keep the pedal on the floor and accelerate up to 28 mph. As the glider loaded up the line, the car would gradually decelerate to around 18 mph at which time the glider would be at the top of the launch. Launching single seaters or launching with much headwind required backing off the throttle some during the launch, but all-in-all, it was stupid simple and worked very well. We did have to put some bricks in the trunk to weight the rear end for traction. That was on asphalt. We did operate a few times on grass strips and used a Nissan 4 wheel drive SUV for that.
WB
vortex ring state at any point during an auto?? Greg Johnson Rotorcraft 18 August 30th 04 10:12 PM
Auto Fuel Residue Stu Gotts Restoration 4 May 12th 04 09:52 PM
Auto conversions & gear boxes Dave Covert Home Built 56 April 1st 04 07:19 PM
Arrow auto gear extension oddness Roy Smith Owning 10 March 8th 04 03:27 AM
VOR & Reverse Sensing mrwallace Piloting 1 August 21st 03 04:08 AM
