Vello wrote:
They start from the same point, in Russian media poor fuel is one discussed thing. The obvious problem with that idea is that poor fuel would usually just stop the engines, leaving them 30,000 feet or so of gliding descent in which to report their difficulties and attempt power-off landings. It seems rather likely that some form of malice was at work and that the technical investigations will merely discover whether hijacking or bombs or some other form of sabotage was used. |
"Robert Briggs" wrote in message ... Vello wrote: They start from the same point, in Russian media poor fuel is one discussed thing. The obvious problem with that idea is that poor fuel would usually just stop the engines, leaving them 30,000 feet or so of gliding descent in which to report their difficulties and attempt power-off landings. Gas turbines are pretty tolerant of fuel quality and if this was the problem I'd expect a lot more than 2 aircraft to be affected. Keith |
Keith Willshaw wrote: Gas turbines are pretty tolerant of fuel quality and if this was the problem I'd expect a lot more than 2 aircraft to be affected. Very true. Jet A is basically kerosene. Not exactly a high tech fuel. Turbines will burn almost any similar rubbish within reason. It would be *very* tricky to fuel just 2 a/c - and no others - with contaminated fuel. Graham |
"Pooh Bear" wrote in message ... It would be *very* tricky to fuel just 2 a/c - and no others - with contaminated fuel. One inadvertantly (or purposly) contaminated fuel truck could manage that trick quite well. But I think we would know by now. Vaughn |
"Vaughn" wrote in message ... "Pooh Bear" wrote in message ... It would be *very* tricky to fuel just 2 a/c - and no others - with contaminated fuel. One inadvertantly (or purposly) contaminated fuel truck could manage that trick quite well. But I think we would know by now. Vaughn Trouble is IRC Moscow like most airports uses pipelines to the gates rather than refuelling trucks. Keith ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
"Keith Willshaw" wrote:
"Vaughn" wrote in message "Pooh Bear" wrote in message It would be *very* tricky to fuel just 2 a/c - and no others - with contaminated fuel. One inadvertantly (or purposly) contaminated fuel truck could manage that trick quite well. But I think we would know by now. Trouble is IRC Moscow like most airports uses pipelines to the gates rather than refuelling trucks. Sheremetyevo uses fuel bowsers drawn by large 8x8 cab-overs. Not sure about Domodedovo. The Tu134 was CCCP 65080. The stewardess who died on this flight was the daughter of the stewardess saved by a miracle in a crash during the 80s. |
funkraum wrote:
"Keith Willshaw" wrote: "Vaughn" wrote in message "Pooh Bear" wrote in message It would be *very* tricky to fuel just 2 a/c - and no others - with contaminated fuel. One inadvertantly (or purposly) contaminated fuel truck could manage that trick quite well. But I think we would know by now. Trouble is IRC Moscow like most airports uses pipelines to the gates rather than refuelling trucks. Sheremetyevo uses fuel bowsers drawn by large 8x8 cab-overs. Not sure about Domodedovo. The Tu134 was CCCP 65080. The stewardess who died on this flight was the daughter of the stewardess saved by a miracle in a crash during the 80s. The one who landed in bignum feet of snow? -- Marc Reeve Some guy at a desk somewhere ^reverse^ for email |
"B2431" wrote in message ... From: "Vaughn" Date: 8/26/2004 5:20 AM Central Daylight Time Message-id: "Pooh Bear" wrote in message ... It would be *very* tricky to fuel just 2 a/c - and no others - with contaminated fuel. One inadvertantly (or purposly) contaminated fuel truck could manage that trick quite well. But I think we would know by now. Vaughn Assuming a truck on the scale of an R-5 and full fuel loads on both aircraft it is not likely both aircraft would be able to be refueled from the same truck. Of course it depends on initial fule levels in both aircraft And the odds that both aircraft would then crash at about the same time, even though one had been in the air quite a bit longer and covered a lot more distance away from the departure point? The fuel bit has been a long-shot from the get-go when you consider that fact, along with the transponder signal reported to have been received from one aircraft. If the latest reports indicating that no out-of-the-ordinary conversations were heard on the CVR's proves to be true, then you can nail the coffin door shut on "bad fuel". Brooks Dan, U.S. Air Force, retired |
| Thread Tools | |
| Display Modes | |
| Did we win in Viet Nam? | Lisakbernacchia | Military Aviation | 89 | July 12th 04 07:03 AM |
| SpaceShip 1 - South African Connection | MWEB | Home Built | 4 | July 1st 04 08:08 AM |
| CIA U2 over flight of Moscow | John Bailey | Military Aviation | 3 | April 9th 04 04:58 AM |
| U.S. Troops, Aircraft a Hit at Moscow Air Show | Otis Willie | Military Aviation | 0 | August 28th 03 11:04 PM |
| U.S. Air Force lands at Moscow air show | Otis Willie | Military Aviation | 0 | August 20th 03 05:19 AM |
