Backwash Causes Lift?
Old October 3rd 07, 03:57 AM posted to rec.aviation.piloting
Le Chaud Lapin
Default Backwash Causes Lift?
Hi,
Student pilot here, self-teaching using the Jeppensen Private Pilot
Kit after taking ground school.
I read in the book that combustion "creates" energy, which is
technically not true, but I decided to ignore it since the pictures
are sooo pretty.
Now, in Chapter 3, section about airfoils, it actually says:
"In addition to the lowered pressure, a downward-backward flow of air
also is generated from the top surface of the wing. The reaction to
this downwash results in an upward force on the wing which demnstrates
Newtons' third law of motion. This action/reaction principle also is
apparent as the airstream strikes the lwoer surface of the wing when
inclinded at a small angle (the angle of attack) to its direction of
motion. The air is forced downward and therefore causes an upward
reaction resulting in positive lift."
IMHO, the latter part of this paragraph is correct, but the former
part is wrong.
Obviously, any air above the wing can only result in a force downward
on top of the wing. The only force causing the plane to want to move
upward comes from beneath the wing. The effect of any air above the
wing is to cause rarefication above the wing, resulting in lower
pressure, thereby giving the 14.7lbs/in^2 (plus) to do its work. That
"reaction" coming from downward movement of air seems just plain silly
to me.
I am also inclined to take issue with the explanations of Bernouilli's
Principle which I see often in the literature, but that's a different
subject. [Note, I don't doubt Bernouilli's Principle, I just think
there is more to it than the way it is being described in context of
flying.]
-Le Chaud Lapin-
Old October 3rd 07, 04:06 AM posted to rec.aviation.piloting
Dan Luke[_2_]
to me.
Then why does the wing stall and cease lifting when flow separates from the
upper surface?
Dan
T-182T at BFM
Old October 3rd 07, 04:37 AM posted to rec.aviation.piloting
Le Chaud Lapin
to me.
upper surface?
Because the situation of rarefication no longer exists during a stall,
or is significantly abated.
When plane is on the ramp, pressure above and below the wing are
equivalent.
When plane is flying certain critical speed, there is, IMO, pinching
that occurs at the leading edge of wing. This area of high pressure
results in a tendency for air to flow away from that pressure point in
all directions.
1. Flowing forward is not an option - that would make pressure
situation worse.
2. Flowing backward, toward the empennage, is not an option. The
leading edge of wing is there.
3. Flowing upward is possible, since above-the-pressure-point pressure
is less than that induced at pressure point.
4. Flowing backward is possible, since below-the-pressure-point
pressure is less than that induced at pressure point.
But here is the catch. If you take an umbrella, open it, find a friend
with extremely long arms, and ask him to yank the umbrella toward his
torso in one, quick, abrupt motion, he will feel a force immediately.
The umbrella might even invert if the impulse is strong enough.
[Sidenote: In the 1970's, I convinced small children that they could
fly if they jumped of 7ft brick wall with umbrella. Very amusing to
see their faces when they hit ground going just about as fast as they
would have without umbrella.] The force that is felt is due to
pressure building under the curved part of umbrella. But even if the
pressure did not build from compression, a force would still be felt,
becaue the force that was equalizing the pressure under the curved
part will have been removed.
And now the $1,000,000 point:
The air on the "outside" of the umbrella does *NOT* instantaneously
fill the void that is created by yanking the umbrella. A finite
amount of time is required for such air to rush in. If the unbrella
is pulled at even a low speed, the net effect can be felt. Pull it
fast enough, and it will invert or snap.
This is, IMO, a more illustrative way of looking at aerodynamics above
the wing than the canned Bernouilli speech.
1. The pinchage creates pressure.
2. A void is created over the wing, provided that plane is moving fast
enough that air high above win cannot rush in.
3. Air at back of wing participates in futile effort to fill the void.
But the most important thing is the pinchage. That pinching results
in high net speed of air molecules backward. Any air above wing that
tries to rush in and fill void is bombarded backward before it can
"touch" the upper surface of wing. I speculated that, if this point a
view were correct, gliders should have short chords with very long
spans, which, of course, is true.
About stalling:
When the angle of attack is too great, the pinchage is still present,
and depending on the shape of the leading edge, the backward flow is
still pressent, but not at the right angle relative to wing, and
certainly not flowing backward enough to stop the onrush of air coming
from above at back of wing. In the air comes, rushing in, and
pressure builds on top of wing.
But there is an ace in hole. Some books say that a plane will stall
if AOA is above critical angle. I do not think this is quite true. It
would seem that, worst-case-scenario, the dynamics above the wing
become royal mess at huge AOA. However, that mess will be less than
static pressure, and there will still be compression beneath the wing.
So if thrust is great enough, airplane should be able to do whatever
it wants.
-Le Chaud Lapin-
Old October 3rd 07, 05:23 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Le Chaud Lapin wrote in
oups.com:
downward on top of the wing. The only force causing the plane to
want to move upward comes from beneath the wing. The effect of any
air above the wing is to cause rarefication above the wing,
resulting in lower pressure, thereby giving the 14.7lbs/in^2 (plus)
to do its work. That "reaction" coming from downward movement of
air seems just plain silly to me.
from the upper surface?
equivalent.
all directions.
situation worse.
Nope, it's not the same at all.
About stalling:
It's precisely true since th ecritical angle is defined by the stall.
Bertie
Old October 3rd 07, 06:20 AM posted to rec.aviation.piloting
Le Chaud Lapin
What is the definition of a stall anyway?
I'm saying that, if you take a plane with certain critical angle,
throw away engine, put on an engine that can generate 10x the thrust,
the plane should still fly, even if you exceed critical angle.
These books imply that the critical angle is angle at with bad things
happen above the wing, and because of that, the plane will fall. I'm
saying that, you can have all the bad things happen above the wing and
still be able to keep the plane aloft due to compression that occurs
beneath the wing.
Of course, I have only been doing this officially 7 weeks, so I might
be wrong.
-Le Chaud Lapin-
Old October 3rd 07, 06:58 AM posted to rec.aviation.piloting
Mxsmanic
Le Chaud Lapin writes:
An abrupt loss of lift.
No, the thrust of the engine doesn't matter, unless the engine itself is
supporting the weight of the aircraft with thrust (possible in a few fighter
aircraft). A wing above the critical angle will stall at any speed.
Yes, true.
I'm saying that, you can have all the bad things happen above the wing and
beneath the wing.
The wing is not supported by compression. It is supported by the displacement
of a mass (of air) downward. If this displacement ceases to take place, lift
disappears. A stalled wing does not divert air downward, so it doesn't
generate lift.
Old October 3rd 07, 10:20 PM posted to rec.aviation.piloting
Morgans[_2_]
"Le Chaud Lapin" wrote in message
beneath the wing.
be wrong.
You are.
With a stronger engine, the wing would still be stalled. You would be
flying on the thrust of the engine.
Disruption of the flow on the top side of the wing is what defines a stall.
The wing would create only a fraction of the list that it would, unstalled.
Old October 3rd 07, 06:56 AM posted to rec.aviation.piloting
Mxsmanic
it wants.
Pressure beneath the wing is not what lifts the aircraft. It's the twisting
acceleration of air above the wing downward that results in lift.
Old October 3rd 07, 08:37 AM posted to rec.aviation.piloting
Mxsmanic wrote in
wing. So if thrust is great enough, airplane should be able to do
whatever it wants.
twisting acceleration of air above the wing downward that results in
lift.
No, it isn't, fjukkktard.
Unless the rules of physics have changed.
Bertie
Old October 6th 07, 12:12 AM posted to rec.aviation.piloting
Gatt
All you need to change the known science of aerodynamics is a wind tunnel.
For example, some of your fellow aerospace scientists use this one:
http://www.ccastronomy.org/photo_NAS...14_640x480.jpg
http://www.windtunnels.arc.nasa.gov/...2FT/12ft2.html
It's amazing. They even have a supersonic wind tunnel so they can test
their aerodynamic ideas. Not only that, but they have a VR lab nearby that
lets them look at 3D renderings of the wind tunnel results.
-c
How much lift do you need? Dan Luke Piloting 3 April 16th 07 03:46 PM
Theories of lift Avril Poisson General Aviation 3 April 28th 06 08:20 AM
what the heck is lift? buttman Piloting 72 September 17th 05 12:50 AM
Lift Query Avril Poisson General Aviation 8 April 21st 05 08:50 PM
thermal lift ekantian Soaring 0 October 5th 04 03:55 PM
