#11
It is so useless we don't put it on the ATIS anymore
It's useless because pilots don't know what the number means, or what to do about it. Pilots aren't told what it means because it's not much used. It's not much used because... So... what do the numbers correspond to? That is, if I hear a mu of 33, what can I expect? Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
"Jose" wrote in message
. .. So... what do the numbers correspond to? That is, if I hear a mu of 33, what can I expect? http://www.newton.dep.anl.gov/askasc...9/phy99x80.htm |
what can I expect? http://www.newton.dep.anl.gov/askasc...9/phy99x80.htm Yes, I know that much. But the coefficient of friction depends on what I am contacting the runway with. And a mu of 33 implies epoxy, not friction. (I would presume that they mean .33 and leave out the point, but it may well mean .033, leaving out the .0) To decelerate uniformly from 100 feet per second (about 60 knots) to zero in 1000 feet would require 20 seconds, and deceleration of 5 feet per second per second. This is about 1/3 the acceleration due to gravity (for the pedants, yes, it's in a different direction). A mu of about 1/3 (or about .33) would provide the necessary force, assuming the entire weight of the aircraft is on the landing gear (not that great an assumption, but good for starters). So, what are representative mu for various conditions I would encounter upon landing? (dry pavement, wet pavement, ice, snow, packed snow, grass, fifth graders...)? Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
"Jose" wrote in message . com... Yes, I know that much. But the coefficient of friction depends on what I am contacting the runway with. Most often it's rubber. |
Jose wrote: It is so useless we don't put it on the ATIS anymore It's useless because pilots don't know what the number means, or what to do about it. Pilots aren't told what it means because it's not much used. It's not much used because... So... what do the numbers correspond to? That is, if I hear a mu of 33, what can I expect? I have no idea. We were told the industry and the FAA got together and came up with this system and the pilots that wanted the information would know what the numbers mean. So far nobody ever asks for the mu. |
"Newps" wrote in message
Yes, our airport can report in mu. I have yet to find the airline pilot who finds those three numbers useful. They always ask for the standard braking action report. Consider myself found. One night not so long ago, DTW approach switched runways on us while on the base leg. It was unplowed. The first airplane to land on it was a Westwind. The Westwind's crew reported braking as fair. Four inches of snow will stop a Westwind. I copied his report but considerd the source. A standard braking action report is only as good as the crew making the report. Sure enough, the Westwind's fair braking was down right poor for our big tires and 160,000 pounds. We got stopped, but only because of the thrust reversers. This was the same night that SWA ran off the runway at MDW. D. |
| Thread Tools | |
| Display Modes | |
| Southern California airports have worst runway safety records | Larry Dighera | Piloting | 0 | November 26th 05 05:48 PM |
| Pilots | Slick | Piloting | 4 | November 20th 04 12:21 PM |
| Diamond DA-40 with G-1000 pirep | C J Campbell | Owning | 114 | July 22nd 04 06:40 PM |
| F15E's trounced by Eurofighters | John Cook | Military Aviation | 193 | April 11th 04 04:33 AM |
| Rwy incursions | Hankal | Piloting | 10 | November 16th 03 03:33 AM |
