Runway Friction Index
Old March 29th 06, 10:33 PM posted to rec.aviation.piloting
Default Runway Friction Index
WHY would not the US adopt it?
http://www.usatoday.com/news/nation/...ay-tests_x.htm
Old March 29th 06, 11:35 PM posted to rec.aviation.piloting
Icebound opined
NIH, and it is a good idea.
-ash
Cthulhu in 2005!
Why wait for nature?
Old March 30th 06, 03:38 AM posted to rec.aviation.piloting
Cost benefit analysis? There are lots of great safety things the FAA
can spend money on, perhaps in the U.S. icy runways make up less of the
accidents and therefore are not the optimal place to spend money?
-Robert
Old March 30th 06, 03:40 AM posted to rec.aviation.piloting
"Icebound" wrote in message
"The Federal Aviation Administration, which regulates airports in the USA,
helped fund research that Canadians used to establish their system, but the
FAA has been wary of adopting it. FAA officials say there is too much room
for error in the Canadian system."
"As a result, pilots landing on snowy or icy runways in the USA must rely
primarily on the reports of other pilots who have just touched down to
determine whether it is safe. These pilot reports have been criticized for
decades by pilot unions and accident investigators as subjective and prone
to error."
"In the USA, the FAA advises airports to test runways during wintry weather,
but pilots aren't allowed to use the results. The FAA's goal is to
eventually give pilots more precise information tailored to specific
aircraft models, spokeswoman Laura Brown says. Until then, the agency is
hesitant to adopt a system like Canada's. Officials worry that the results
from testing equipment cannot be guaranteed and could be misleading in
certain types of aircraft."
The report is wrong. Vehicles with runway friction measurement equipment
have been used at US airports for years and the information is provided to
pilots.
FAA Order 7110.65R
Air Traffic Control
Chapter 3. Airport Traffic Control-- Terminal
Section 3. Airport Conditions
3-3-4. BRAKING ACTION
Furnish quality of braking action, as received from pilots or the airport
management, to all aircraft as follows:
d. Furnish runway friction measurement readings/values as received from
airport management to aircraft as follows:
1. Furnish information as received from the airport management to pilots on
the ATIS at locations where friction measuring devices, such as MU-Meter,
Saab Friction Tester (SFT), and Skiddometer are in use only when the MU
values are 40 or less. Use the runway followed by the MU number for each of
the three runway segments, time of report, and a word describing the cause
of the runway friction problem. Do not issue MU values when all three
segments of the runway have values reported greater than 40.
EXAMPLE-
"Runway two seven, MU forty-two, forty-one, twenty-eight at one zero one
eight Zulu, ice."
2. Issue the runway surface condition and/or the Runway Condition Reading
(RCR), if provided, to all USAF and ANG aircraft. Issue the RCR to other
aircraft upon pilot request.
EXAMPLE-
"Ice on runway, RCR zero five, patchy."
NOTE-
1. USAF has established RCR procedures for determining the average
deceleration readings of runways under conditions of water, slush, ice, or
snow. The use of the RCR code is dependent upon the pilot's having a
"stopping capability chart" specifically applicable to his/her aircraft.
2. USAF offices furnish RCR information at airports serving USAF and ANG
aircraft.
http://www.faa.gov/atpubs/ATC/Chp3/atc0303.html#3-3-5
Old March 30th 06, 05:20 AM posted to rec.aviation.piloting
"Icebound" wrote in message WHY would not the US adopt it?
The US already has a system?
The big airports can provide runway traction reports measured in 'Mu'. These
reports are much more useful than pilot reports.
D.
Old March 30th 06, 05:22 AM posted to rec.aviation.piloting
"Capt.Doug" wrote in message
As can the not-so-big airports.
Old March 30th 06, 06:49 PM posted to rec.aviation.piloting
Yes, our airport can report in mu. I have yet to find the airline pilot
who finds those three numbers useful. They always ask for the standard
braking action report.
Old March 30th 06, 07:26 PM posted to rec.aviation.piloting
Friction is a variable, a wheel has friction in the wheel
bearing and on the tread to the pavement. The pavement when
clean and dry has a fairly stable Mu which is a coefficient
from perfect friction to no friction.
If there is water or ice, the actual friction may change
second by second as the temperature changes or more
precipitation falls.
It would be nice if somebody built a runway 3,000x24,000
feet with a Teflon surface so pilots could practice
controlled landings. How slick is oiled Teflon?
James H. Macklin
ATP,CFI,A&P
some support
"Newps" wrote in message
adopt it?
airline pilot
the standard
Old March 30th 06, 07:52 PM posted to rec.aviation.piloting
Yes, our airport can report in mu. I have yet to find the airline pilot who finds those three numbers useful. They always ask for the standard braking action report.
I've never heard of mu numbers in this context. How are they used?
Jose
Nothing takes longer than a shortcut.
Old March 30th 06, 08:08 PM posted to rec.aviation.piloting
They give us three numbers, such as 33 35 38, for the thirds of the
runway. It was an attempt a few years ago to standardize the runway
condition so the number means the same thing to everybody and removes
the subjectiveness of braking action fair. It is so useless we don't
put it on the ATIS anymore and when we get asked for the runway
condition we give it to them in the old way, good, fair, etc. Nobody
ever asks for the mu number. Ever.
Jose
Southern California airports have worst runway safety records Larry Dighera Piloting 0 November 26th 05 05:48 PM
Pilots Slick Piloting 4 November 20th 04 12:21 PM
Diamond DA-40 with G-1000 pirep C J Campbell Owning 114 July 22nd 04 06:40 PM
F15E's trounced by Eurofighters John Cook Military Aviation 193 April 11th 04 04:33 AM
Rwy incursions Hankal Piloting 10 November 16th 03 03:33 AM
