Verifying flap retraction
Old August 21st 04, 08:22 PM
Bob Noel
In article , "Julian Scarfe"
How exactly do Piper manual flap systems work then?
extend flaps against the spring. retract flaps an exercise
in making they don't snap back (push the button and let the
bar down slowly).
Bob Noel
Seen on Kerry's campaign airplane: "the real deal"
oh yeah baby.
  #52
Old August 21st 04, 08:36 PM
Julian Scarfe
"C J Campbell" wrote:
Most of the problems that I have had on Cessna 172s have been with
flaps. I
agree that pilots should verify flaps up on touch and goes.
Cessna used to have manual flaps. Why did they ever go to this flakey
electrical system in the first place?
"Roy Smith" wrote in message
I did my initial training in Cessnas, and "verify flaps retracting" was
drummed into me as part of the touch-and-go procedure.
Now I fly mostly Pipers. I really like the manual flaps instead of
Cessna's electric ones, and curse the electric trim Piper uses instead
of Cessna's manual trim system.
Simple stuff just works better.
How exactly do Piper manual flap systems work then? We have a Piper Twin
Comanche with an electric flap system. The flaps are pushed down, but come
back up using springs, in effect after latches are removed. We've now had
two asymmetric flap retractions, where one of the springs failed to do its
job. This is Not Good.
So when you lower the flap handle in a manual Piper system, does it drag the
flaps up or does it merely take the latch away and allow the spring to do
its job, as in the electrical equivalent?
Julian Scarfe
  #53
Old August 21st 04, 09:55 PM
Barry
Was this on the ground after landing, or in flight? I'd think that the air
load on extended flaps would help push them up in flight.
  #54
Old August 22nd 04, 03:51 PM
Ash Wyllie
Barry opined
It won't. I had one flap not retract once. It just got hung up half way for some
reason. So I just lowered the flaps until they were symmetric and landed.
It helped that it was a test flight and I was in the pattern at the time.
-ash
Cthulhu for President!
Why vote for a lesser evil?
  #55
Old August 22nd 04, 09:58 PM
Julian Scarfe
We've now had
its
"Barry" wrote in message ...
air
It was in flight. I'm not sure what the magnitudes of the airloads are.
Julian
  #56
Old August 24th 04, 03:08 PM
Paul Sengupta
"Julian Scarfe" wrote in message
news
air
Not answering the original question, I've noticed something recently with
my plane. It has electric flaps. It has two "notches", 15 degrees and
45 degrees, marked "take off" and "landing". When I'm on the ground
and set the flaps to "take off", the motor runs for a certain distance,
stops, but the flaps continue moving for a second and end up in the
correct position.
When I'm in flight, when I select the first notch, the motor runs for the
same distance but presumably because of the air loads, the flaps
stop there, i.e. no run on. This means the flaps aren't extended the
correct amount when set to 15 degrees in the air.
Apart from adding friction to the motor/mechanism so there's no run-on
on the ground, then re-adjusting for the correct position, is there any
way round this?
Paul
  #57
Old August 24th 04, 03:10 PM
Paul Sengupta
Hardly a definitive answer but I seem to remember pre-flighting
something (may have been a PA28) where the flaps stuck down
when I put the lever back down. A quick nudge freed them.
Paul
  #58
Old August 24th 04, 03:33 PM
Bill Denton
Are you sure there is a problem? If the flaps end up in the correct position
the motor run duration may simply be a part of the way things are designed.
"Paul Sengupta" wrote in message
news
air
correct position.
way round this?
Paul
  #59
Old August 24th 04, 06:12 PM
Dale
correct position.
Are you flaps driven by a jack-screw?
Are you sure that the flaps are going to 15 when on the ground? Perhaps
they are adjusted to give you 15 with airloads on them but overrun
slightly on the ground.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
  #60
Old August 25th 04, 12:54 PM
Paul Sengupta
"Dale" wrote in message
with
correct position.
Are your flaps driven by a jack-screw?
Um, I presume so. Haven't looked.
Maybe. But then they'd be in the wrong position for take-off! :-)
Handbook says to take off with take-off flap and gives the technique
for doing so. It does not mention take-off without flap at all. Mind
you, it takes off just fine without them! :-)
There's a flap position indicator dial and it points exactly to the take-off
position when lowered on the ground. When lowered in the air, it
stops slightly before. Adjusting the motor cut-off point is easy, there's
an adjustable microswitch under the floor just behind the seats.
In the real world, this isn't a problem...I doubt an extra/fewer couple
of degrees of flap movement makes much difference to my flying!
Paul
Flap Hinge Moment Calc Bo Home Built 2 February 2nd 05 11:26 AM
Flap Hinge Moment Calc Bo Home Built 0 February 2nd 05 07:01 AM
Flap angles DeltaDeltaDelta Piloting 34 May 18th 04 01:09 AM
McFarlane flap rollers - PIREP please Roger Long Owning 3 November 3rd 03 11:04 PM
Flap design question Chris W Home Built 1 August 4th 03 03:50 PM
