#81
Recently, Mxsmanic posted:
Neil Gould writes: I can guarantee that those other airports are designed with knowledge of the prevailing winds in the area. I can guarantee that prevailing winds are not in the same direction for every airport. It doesn't matter, in Real World 1.0 airport design results in an asymmetrical distribution of x-wind factors, so your assertion that x-winds would be statistically 50% R/L at any airport is just wrong. Neil |
#82
Answer this.....
First some background. For times of bad weather they make a device you can put your bicycle on to "train" indoors called "Rollers" They consist of three rollers about 18 to 24 inches long, 2 are close together and the back wheel rests between them the third is positioned under the front wheel. See photo here.... http://www.nashbar.com/nashbar_photos/medium/TX-SPT.gif In this situation the bicycle is obviously not moving forward. How does it stay upright? -- Chris W KE5GIX "Protect your digital freedom and privacy, eliminate DRM, learn more at http://www.defectivebydesign.org/what_is_drm" Gift Giving Made Easy Get the gifts you want & give the gifts they want One stop wish list for any gift, from anywhere, for any occasion! http://thewishzone.com |
#83
"Chris W" wrote in message
... Answer this..... First some background. For times of bad weather they make a device you can put your bicycle on to "train" indoors called "Rollers" They consist of three rollers about 18 to 24 inches long, 2 are close together and the back wheel rests between them the third is positioned under the front wheel. See photo here.... http://www.nashbar.com/nashbar_photos/medium/TX-SPT.gif In this situation the bicycle is obviously not moving forward. How does it stay upright? A bicycle is an open loop unstable "plant" that is stabilized by an organic neural net closed loop controller. Some aircraft are like that too. e.g. taildraggers on the ground. (how's that for an attempt to drag this back to an aviation related thread?) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
#84
Chris W writes:
In this situation the bicycle is obviously not moving forward. How does it stay upright? The cyclist balances it, assisted by the gyroscopic stabilizing effect of the turning wheel (the heavier it is and the faster it turns, the better). -- Transpose mxsmanic and gmail to reach me by e-mail. |
#85
Greg Farris writes:
THIS : Yes, through momentum. But this momentum is eroded by irreversible effects such as friction with the ground and air. Eventually none is left, and the bicycle stops. PLUS THIS: The cyclist balances it, assisted by the gyroscopic stabilizing effect of the turning wheel (the heavier it is and the faster it turns, the better). EQUALS THIS : "Yes, I was completely wrong, and everything I wrote was complete bull****, based on a complete lack of understanding of the facts. . ." No. If the bicycle cannot turn, it will fall over. It cannot turn on rollers. It can turn on flat pavement. You see, the bicycle stays up because it turns. As long as it has momentum or power and traction, it will continue to turn or roll straight. It can only stop when it has no propulsive power or momentum. This is more obvious in motorcycles than bicycles, but it applies to both. Similar principles apply to aircraft, which is why you generally cannot simply push the yoke forward to descend or pull it back to climb. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#86
Mxsmanic wrote: Newps writes: No, it will not. That's ridiculous. Try it and see. I've got lots of hours on bikes. I am perfectly capable of making a bike fall over. Any kid can do that. |
#87
Mxsmanic wrote: Newps writes: Where did you come up with that statistic? It's statistically inevitable. No, it's not. At my airport the wind blows from the left probably over 90% of the time. But there are other airports in the world. What a genius. All the airports align their runways into the prevailing wind. You will find the predominant crosswind comes from the same side nearly every time. |
#88
"Mxsmanic" wrote in message news ![]() No. If the bicycle cannot turn, it will fall over. It cannot turn on rollers. It can turn on flat pavement. You see, the bicycle stays up because it turns. As long as it has momentum or power and traction, it will continue to turn or roll straight. It can only stop when it has no propulsive power or momentum. This is more obvious in motorcycles than bicycles, but it applies to both. Similar principles apply to aircraft, which is why you generally cannot simply push the yoke forward to descend or pull it back to climb. I'm curious, do you have brown eyes? |
#89
Similar principles apply to aircraft, which is why you generally cannot simply push the yoke forward to descend or pull it back to climb. Horsefeathers!!! You are such an idiot. I can descend by pushing the yoke forward or pulling it back. ^^ ^^ [AKA BS] |
#90
Mxsmanic wrote:
Similar principles apply to aircraft, which is why you generally cannot simply push the yoke forward to descend or pull it back to climb. MX the Great Oracle has spoken. Why, millenia ago Delphi was overrated. Yellow Book dot commmmm...... F-- |
| Thread Tools | |
| Display Modes | |
| Light twins not using contra-rotating propellers | RomeoMike | Piloting | 6 | December 2nd 06 02:47 AM |
| Light twins not using contra-rotating propellers | Newps | Piloting | 0 | November 30th 06 08:40 PM |
| Light twins not using contra-rotating propellers | Greg Farris | Piloting | 0 | November 30th 06 08:25 PM |
| HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB | Mal | Soaring | 59 | October 4th 05 06:39 AM |
| The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 01:07 PM |
