Light twins not using contra-rotating propellers
Old November 30th 06, 08:43 PM posted to rec.aviation.piloting
RomeoMike
Default Light twins not using contra-rotating propellers
Mark Levin wrote:
Hello,
As was pointed out to me the Beechcraft Baron does not use contra-rotating
propellers. A bit of research showed me that most U.S. built light twins do
not use them either.
One twin that I have experience with, the Seminole, does have counter
rotating props.
Old November 30th 06, 09:55 PM posted to rec.aviation.piloting
Danny Dot
"Mark Levin" wrote in message
rotating props.
Out of curiosity does this have a marked effect on it's operation compared
with the other twins you've flown?
Any procedures different because of it?
Most aircraft engines rotate counter clockwise as you are in front of the
aircraft looking at it. It is desirable for single engine operations, the
downward stroke of the propeller be next to the fuselage. For this the
right engine would need to rotate clockwise (as looking back from the
front). Most twins don't do this and right engine only handling become
"difficult".
Danny Dot
ml
Old December 1st 06, 01:26 AM posted to rec.aviation.piloting
RomeoMike
My solo multi time is limited to light twins. The most noticeable
difference in "normal" flight is the decrease or absence of left turning
tendency in high AOA situations such as TO and climb because P factor
and torque from one engine cancels those factors from the other engine.
The other main difference with counter rotating props, of course, is the
lack of a critical engine. In other words, no more asymmetrical thrust
is produced if one engine fails compared to the other.Therefore, turning
tendencies are less when practicing critical engine out procedures (or
Vmc demos) than they would be in the conventional set up. I wouldn't say
that any procedures are different. One still practices the same things.
There is still a lot of asymmetric thrust in engine out scenarios. A
multi instructor once told me that a twin is like any other airplane,
but when it loses an engine it becomes a sled. I would add, "even if it
has counter rotating props."
and
Old December 1st 06, 02:00 AM posted to rec.aviation.piloting
Jim Macklin
The symmetric thrust in normal operation is the main
difference, Vmca is still present anytime the engines are
not on the centerline. Having the engines effect the thrust
line the same makes the speed at which you stall, spin and
die the same, it doe snot eliminate the danger.
"RomeoMike" wrote in message
operation compared
noticeable
of left turning
because P factor
other engine.
course, is the
asymmetrical thrust
procedures (or
I wouldn't say
same things.
scenarios. A
other airplane,
add, "even if it
| and
Old December 1st 06, 05:11 AM posted to rec.aviation.piloting
RomeoMike
Guess you're not disagreeing with me, so maybe you meant to respond to Mark.
Old December 1st 06, 06:49 AM posted to rec.aviation.piloting
Jim Macklin
Probably, sometimes keeping the thread and the thought
processes all in order, a strain.
Did I really get the typo below that says, deer mucous [sort
of]?
are
thrust
and
to respond to Mark.
Old December 2nd 06, 02:47 AM posted to rec.aviation.piloting
Sylvain
rotating props.
the Duchess also have counter rotating props. The difference is that
it doesn't have 'critical engine' and should behave similarly whether
you loose the left or right engine.
--Sylvain
Light twins not using contra-rotating propellers Newps Piloting 0 November 30th 06 08:40 PM
Light twins not using contra-rotating propellers Greg Farris Piloting 0 November 30th 06 08:25 PM
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB Mal Soaring 59 October 4th 05 06:39 AM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 01:07 PM
Light Twins - Again - Why is the insurance so high? Doodybutch Owning 7 February 11th 04 09:13 PM
