$150 10" display glide computer...
Old September 13th 09, 07:07 PM posted to rec.aviation.soaring
Default $150 10" display glide computer...
Ok you've seen the digital picture frames for a while now.
http://www.amazon.com/gp/product/B000H743WC
This one (and many more) run on windoze CE5.
Now watch this video...
http://www.youtube.com/watch?v=5watadHqGAk
Add a copy of XCSoar and a usb to serial converter and you have a 10"
glide computer
while 10" is overkill unless you fly a 232!! there are digi frames in
all sizes starting from 2" up.
Cool huh?
Al
Old September 15th 09, 07:05 AM posted to rec.aviation.soaring
Al[_7_]
On Sep 13, 10:07*am, "
Add a copy of XCSoar and a usb *to serial converter and you have a 10"
glide computer
Cool huh?
Al
guess you guys don't get the implications of this post?
Al
Old September 15th 09, 07:42 AM posted to rec.aviation.soaring
Bernie[_4_]
Al,
I guess the question is what do these frames look like in sunlight?
And will they handle the rough environment that is a glider cockpit?
You need to find one that has a touch screen (they are out there).
I have seen tiny key ring type ones, and 7" ones, but not much in 5"
or so which is what I envisage to be a useful size.
Let us all know when you have one up and running in your glider. I'm
interested.
Regards, Bernie.
Old September 15th 09, 09:31 AM posted to rec.aviation.soaring
Al[_7_]
On Sep 14, 10:42*pm, Bernie wrote:
Al,
interested.
Regards, Bernie.
well you could go for something like this...
http://www.advantech.com/applied-computing-systems/panel-pc/News.aspx?doc_id={920F5B24-3A26-4459-8DFD-5A537D3ACE9
Rugged, touch screen etc...
Old September 15th 09, 05:59 PM posted to rec.aviation.soaring
Rob.Russell
I've been waiting for someone to take one for the team and try to get
WinCE (they say it works) to run on a http://www.alwaysinnovating.com/touchbook/
with XCSoar.
Looks much better than a picture frame, great resolution, etc.
Old September 15th 09, 07:58 PM posted to rec.aviation.soaring
tstock
I think it's great info... I did read it a few days ago and spent some
time reading about it and watching various videos.
Need to find a 5" version with a touch screen.
Old September 16th 09, 12:13 AM posted to rec.aviation.soaring
Al[_7_]
WinCE (they say it works) to run on ahttp://www.alwaysinnovating.com/touchbook/
with XCSoar.
XC soar runs on PC systems as well as CE.
Old September 16th 09, 02:47 AM posted to rec.aviation.soaring
Rob.Russell
Will it run on the Linux OS that comes with the Touchbook? The
Touchbook will run WindowsCE or Linux, but not XP.
If you kept the Linux OS, then you might be able to compile a
compatible version of KFLog/Cumulus, but most people that would
consider that option are already using KFLog/Cumulus.
Old September 21st 09, 01:21 AM posted to rec.aviation.soaring
Bryce
Looks much better than apictureframe, great resolution, etc.
Will it run on the Linux OS that comes with the Touchbook? *The
Getting back to the original post......has anyone had any luck trying
one of these in the cockpit yet. I'm also not sure the touch screen
is that big of a problem. To tell you the truth many of these come
with a remote.....might work out nice. I did a little research and it
looks like the ClearNav runs about 700nits on it's lowest brightness
setting, I've flown one first hand and I can attest this is plenty
bright enough for everyday use. The brightest picture frame I can find
is 400nits (many manufacturers don't list the value)....may or may not
be enough?
Anyone with more info?
Old September 21st 09, 10:16 AM posted to rec.aviation.soaring
Al[_7_]
one of these in the cockpit yet. *I'm also not sure the touch screen
with a remote.....might work out nice. *I did a little research and it
be enough?
I would be curious so hear about the current draw of the glide
computers with these super bright displays at max brightness.
I would put money on the stated current draw is for the lowest
settings.
Was have a laugh with a buddy about the frames, would you like teak or
plastic finish.
Obviously you would strip the device down and panel mount it.
Cheers
Al
iPhone Glide Computer Kloudy via AviationKB.com Soaring 13 September 13th 07 04:41 AM
Glide computer Mark Siegelberg Soaring 1 January 13th 07 02:08 PM
Best Glide computer and why Roger Soaring 10 October 24th 06 09:28 PM
Flight computer with illuminated display [email protected] Piloting 1 August 26th 06 02:58 AM
OQO Handtop computer for flight display. Guy Byars Owning 2 June 28th 05 04:09 PM
