TRIG TT21NOW IN STOCK
Old September 28th 09, 06:23 PM posted to rec.aviation.soaring
Tim Mara[_2_]
Default TRIG TT21NOW IN STOCK
I have the TRIG TT21 Modde S transponders in stock now.WITH US FAA TSO!
Please call to order
thanks
Tim
Wings & Wheels
Please visit the Wings & Wheels website at www.wingsandwheels.com
Old September 28th 09, 06:56 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I have them in stock also.
I also have wiring harnesses in stock for connecting the control head to the
transponder.
Paul Remde
Cumulus Soaring, Inc.
"Tim Mara" wrote in message
thanks
Tim
Wings & Wheels
Old September 29th 09, 06:41 AM posted to rec.aviation.soaring
Al[_7_]
transponder.
Er... isnt that part of the package
Tim do you have the harnesses too?
I couldn't find one on ebay yet....
Anyone else go these in stock?
Old September 29th 09, 09:15 AM posted to rec.aviation.soaring
Peter Purdie[_3_]
The placing of the main unit relative to the control head is a very
variable distance - I have done one on a ragwing microlight where it was 6
inches, and another on a 3-axis where it was 10 feet.
The kit includes the connectors, but leaves the installer to join the dots
with appropriate cable.
AFE in UK includes providing a harness of customer defined length (plus
the antenna cable) in the base price.
You need a professional (expensive) crimp tool to use the factory supplied
aviation standard D connectors - you can use solder bucket ones for reduced
reliability, which is why getting it done properly by the supplier is a
good idea.
to
transponder.
Old September 29th 09, 03:49 PM posted to rec.aviation.soaring
Paul Remde
Hi Al,
The TT21 comes with all the required connectors. But the connectors require
the use of a crimping tool to connect the wires to the pins.
I offer a pre-wired wiring harness made by Larry Goddard in 2 lengths: 0.5m
and 3m. Custom lengths are available upon request.
Best Regards,
Paul Remde
"Al" wrote in message
transponder.
Old September 29th 09, 11:29 PM posted to rec.aviation.soaring
Tim Mara[_2_]
The TT 21 does come with connectors and installation kit but not cables, the
connectors are simple crimp types and can be done with rather
unsophisticated crimp tools but I also offer a very low cost soldered cable
set for the TT21 for those who buy the transponders. 2' cables will be
standard, but optional custom harnesses to longer lengths available with
rather short delays. Please see my website for options and prices.
I also offer several other harnesses for radios an other transponders,
usually from the manufacturers of the respective equipment but will be
offering similar sets made here by a professional electronics
manufacturer..all with Aircraft grade Tefzel wire.
tim
transponder.
TRIG TT21 Transponders Tim Mara[_2_] Soaring 12 September 26th 09 03:01 AM
Trig TT21 Transponder receives FAA TSO approval Paul Remde Soaring 12 September 19th 09 03:47 PM
Trig TT21 in Experimental Aircraft Paul Remde Soaring 5 July 5th 09 04:15 AM
Trig TT21 Transponder Thoughts? jcarlyle Soaring 16 June 23rd 09 05:38 PM
forgotten trig for climb angle... xerj Piloting 5 January 29th 07 02:08 PM
