How does sun heat the air?
Old October 9th 09, 03:59 AM posted to rec.aviation.soaring
Default How does sun heat the air?
The sun shines down through the atmosphere, hits things on the ground,
the things on the ground get hot, and then the hot things on the
ground heat the air?
Sun light passing through the air does not heat the air at all? Heats
the air some but not much?
If the air is transparent to solar energy, how is the air able to
pick up so much energy from hot objects on the ground?
Bill
6W
Lotsa Heat Maple1 Aviation Photos 2 August 7th 07 04:21 AM
Carb Heat vlado Piloting 9 January 22nd 07 04:08 PM
But it's a dry heat.... Casey Wilson Piloting 31 July 23rd 05 11:09 PM
Pre-Heat at BED? Colin W Kingsbury Owning 7 January 21st 05 03:25 AM
auxiliary heat Jim Burns Owning 15 October 20th 04 10:08 PM
