"Discovery Wings" channel showcases a test pilot....
Old September 12th 04, 11:46 PM
frank wight
Default "Discovery Wings" channel showcases a test pilot....
And one of the "tests" is to fly high and level
and throw the after-burner switch, then go to idle,
and then back on after-burner.
Trouble is, they didn't actually film the event
and I'm curious about what such a procedure feels like.
Anybody know?
Old September 13th 04, 10:39 PM
Peter Stickney
(frank wight) writes:
Sure. It's a pretty good way to induce a compressor stall. You also
stand a pretty good chance, if the engine is an an afterburning
turbofan, to get a pressure pulse up the fan duct, when the afterburner
relights, that can casue all sorts of inlet/engine airflow havoc.
A pretty good jolt of acceleration when the AB lights. Then a pretty
fair deceleration when the engine come out of burner and down to
idle. Then a pretty good jolt as things spool back up.
If all goes well, that is. Worst case, a pretty fair jolt when the AB
lights off, then a bunch of deceleration, as before, then no
accelration and a lot of racket as the engine tries to deal with the
disturbed off-design airflow. If it doean't sort itself out, then a
shutdown shutdown & airstart. If it doesn't restart, you may, (best
case) be putting your single engine landing drill to use, or, (worst
case) looking at an ejection seat ride and a mountain of paperwork.
It's the sort of thing that you can't really predict ahead of time,
computationally, and wind tunnel testing isn't representative enough.
It's an important set of test points.
Like most test flying, it's pretty straightforward - you hit your
conditions, and take your data, and all goes well. Most of the time.
But reality isn't always what the predictions indicate. Then things
get very exciting.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old September 14th 04, 01:49 AM
Air Force Jayhawk
On Mon, 13 Sep 2004 16:39:28 -0400, (Peter
get very exciting.
And as we say in the test business, that is why we don't want pilots
with a history degree being the one to do it for the first time...
Ross "Roscoe" Dillon
USAF Flight Tester
(B-2, F-16, F-15, F-5, T-37, T-38, C-5, QF-106)
Is this the end of Discovery Wings Channel ?? LJ611 Home Built 16 December 7th 04 05:26 AM
Discovery Wings Channel ??? Andy Asberry Home Built 0 November 13th 04 06:11 AM
Discovery Wings Channel ??? RobertR237 Home Built 1 November 8th 04 09:40 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
