JJ's instrument bin
Old December 9th 09, 05:46 PM posted to rec.aviation.soaring
JJ Sinclair
Default JJ's instrument bin
Sage SV (80mm) with flask, checks OK...................................
$375.00
Cambridge M-nav no flask, checks
OK.....................................$250.00
Cambridge vario (2X, 1X, .5X) with audio, no flask, checks OK....
$175.00
Cambridge vario, no audio, no flask, checks OK........................
$125.00
QuartzChronometer (that's a clock, Mike), checks OK...............
$50.00
Borgelt B-100, checks
OK................................................ .......$250.00
E-mail for photo, add $25 for shipping
JJ Sinclair, Placerville, Ca (530) 622-4991
Old December 9th 09, 10:30 PM posted to rec.aviation.soaring
JJ Sinclair
Sage and Cambridge with audio, sold.
JJ
$375.00
$175.00
$125.00
$50.00
Old December 9th 09, 11:39 PM posted to rec.aviation.soaring
Michael Huber
That´s pretty expensive for shipping a photo, isn´t it? And how can I add
$25 to an e-mail?
SCNR ;-)
Michael
Old December 10th 09, 03:35 PM posted to rec.aviation.soaring
JJ Sinclair
Just for you Michael, I also have 2 Ball varios, an A-8 regulator and
an extremely rare Crossfell vario. Get 'em all and start museum!
JJ
That�s pretty expensive for shipping a photo, isn�t it? And how can I add
$25 to an e-mail?
SCNR ;-)
Michael
Old December 10th 09, 05:46 PM posted to rec.aviation.soaring
Tony[_5_]
an extremely rare Crossfell vario. Get 'em all and start *museum!
JJ
That s pretty expensive for shipping a photo, isn t it? And how can I add
$25 to an e-mail?
SCNR ;-)
Michael- Hide quoted text -
- Show quoted text -
Crossfell can't be that rare. I've got 2 of them. One supposedly works
well. The other one has been floating in the trunk of my car for a
few years.
Old December 10th 09, 09:33 PM posted to rec.aviation.soaring
Andy[_10_]
well. *The other one has been floating in the trunk of my car for a
few years.
Why does your car need a vario? I would think it's high minimum sink
rate would make it a bear to thermal effectively.
9B
Old December 10th 09, 10:49 PM posted to rec.aviation.soaring
Uncle Fuzzy
few years.
Why does your car need a vario? *I would think it's high minimum sink
9B
.... and what is it floating in? The trunk of an old Toyota I had
would take on a bit of water in a heavy rain, but not enough for
anything bigger than a peanut to float in. Maybe you ought to drill
some drainage holes. Or, you might just relocate the vario to the
dash board. It's got to be difficult to read, floating around in the
trunk.
Old December 11th 09, 02:16 AM posted to rec.aviation.soaring
Darryl Ramm
JJ
JJ
Are you offering to post a photo of those pair of Balls?
Darryl
Old December 11th 09, 03:57 AM posted to rec.aviation.soaring
Tony[_5_]
few years.
9B
... and what is it floating in? *The trunk of an old Toyota I had
anything bigger than a peanut to float in. *Maybe you ought to drill
some drainage holes. *Or, you might just relocate the vario to the
dash board. *It's got to be difficult to read, floating around in the
trunk.
Good idea, i suppose I should get that old vario out, try to get it
working again. It has a diaphragm total energy compensator and runs
on 3 D Cells. It would look good in the dash of my Olds Alero.
Old December 11th 09, 06:34 AM posted to rec.aviation.soaring
Bob
trunk.
You could drill some drain holes and the tape them over when you are
in that thermal, so as to not have the pressure difference cause drag!
JJ's Wing Runner JJ Sinclair Soaring 0 December 15th 07 03:41 PM
JJ's 'buttwhacker' comes to fruition! Stewart Kissel Soaring 3 July 30th 06 09:50 PM
Gleim Instrument Pilot Audio CD Set AND Gleim Instrument Pilot FAA Test Prep Software - together on Ebay Cecil E. Chapman Products 0 January 15th 04 12:34 AM
Odd EGT instrument? Ben Jackson Piloting 0 August 17th 03 06:34 AM
