Ditching Gear Down
Old October 5th 03, 03:27 AM
Mike Keown
Default Ditching Gear Down
Question: You are forced to ditch in a a/c
with fixed landing gear. The sea is calm and
search and rescue are aware of your situation
and location. How do you put 'her' down?
Old October 5th 03, 03:43 AM
Dave Kearton
"Mike Keown" wrote in message
Mike - are you declaring an emergency at this time ? ;-)
Cheers
Dave Kearton
Old October 5th 03, 05:52 AM
George Z. Bush
Verrry carefully. (^-^))) Since the sea is calm, there likely wouldn't be any
wind to speak of, so looking for swells and troughs wouldn't be a problem. Just
maintain airspeed high enough to maintain control and try to three point her in.
George Z.
(former ARS pilot)
Old October 5th 03, 06:05 AM
"Dave Kearton"
Along the smooth side of the swell (if any), as slow as possible
while maintaining just enough speed to assure that you don't
stall...repeat after me..."Our father who art...."
-Gord.
Old October 6th 03, 02:53 PM
nafod40
Fixed landing gear? You're going to flip'er head over heels when you
hit. Bail out if you can.
I have a cool mpeg of a *seaplane* with it's gear down flipping on
landing...
Old October 6th 03, 04:04 PM
Pechs1
and location. How do you put 'her' down? BRBR
Crack the doors open a wee bit before ya hit(like a cessna), stay straped in.
Fly as low and slow as ya can, pancake it in...unstrap and swim out. It should
float for a while, even if only the wing is up. Try not to flip it over...
P. C. Chisholm
CDR, USN(ret.)
Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer
Old October 6th 03, 05:39 PM
NiceGuy
on the tail
hold nose up as long as possible
drop it in
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 03:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 06:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
Ditching Gear Down Dave Kearton Military Aviation 18 October 7th 03 11:27 PM
