Increased Skin Cancer Rates in Pilots and Air Crews
Old March 25th 10, 06:04 AM posted to rec.aviation.soaring
Bob
Default Increased Skin Cancer Rates in Pilots and Air Crews
I made my 6 month check up visit to my skin doctor yesterday, and in
our conversations I mentioned I was a glider pilot and was trying my
best to not have any more malignancies.
I was pleased that nothing was found that needed to be cut off (for a
change), but still had the usual substantial number of spots that got
sprayed with liquid nitrogen to kill "pre cancers".
She mentioned that a substantial increase in melanoma and other skin
cancers being found in pilots was "quite the buzz" among
dermatologists right now. It makes sense that glider pilots might
have an even greater tendency for such than the general pilot
community, as we are exposed at the airport and in the air. I went to
the physics department at the college where I used to teach and picked
up a device for testing for UV, placed it inside my canopy, and it lit
up like a light bulb...LOTS of UV coming through. The entire UV
spectrum is hazardous to our skin, along with gamma rays from space.
Most sun screen on the market does not filter out all UV, so buyer
beware. Handily, there are now some clothing products like long
sleeve shirts on the market that are claiming an SPF of 35 that should
help protect much of your upper torso, and gloves and hats, too.
Its not just mental lapses in your flying that can get you pushing
daisies, although skin cancer is not as instantaneous. Older folks
are more apt to be affected, yet all ages are elligible to be
afflicted.
Old March 26th 10, 02:09 AM posted to rec.aviation.soaring
Matt Herron Jr.
Bob,
Increased cancer rates in commercial pilots and crew are likely due to
higher exposures to radiation (cosmic rays) at high altitude for long
periods of time rather than UV light. Additionally, when these rays
strike the metal skin of the aircraft, they scatter, changing energy
levels and actually producing more damage to tissue than direct
exposure. In contrast, glider pilots don't usually fly that high, or
for as long, and don't have that metal skin effect to deal with.
As far as the UV exposure goes, it would be helpful to see some
readings from the meter, measured both inside and outside the cockpit.
Typically, clear plexiglass will knock out 50-70% of UV from the sun
depending on thickness, etc. (see http://www.rplastics.com/plexiglass-transmittance.html
for example) Simple plastic sunglasses can be made to absorb harmful
UV rays in the same way. Of course we must still wear protection,
(mostly from our exposure on the ground when putting the bird
together) but we don't want to leave the impression that flying
gliders significantly increases your chances of getting skin cancer.
Matt
Old March 26th 10, 05:10 AM posted to rec.aviation.soaring
Eric Greenwell
Consumer Reports and many other reputable sources says it does an
excellent job if it's spf 30 and higher, and properly applied, even it
it doesn't get "all" of it.
You didn't mention what kind of UV meter you used, and "lighting up like
a light bulb" doesn't tell us anything. Was it measuring UVB, or UVA,
both? and what fraction of each? What percentage reduction did the
canopy provide? The type of plastic and it's tinting can make an
important difference: for example, the canopy on my previous glider
blocked all the UVB and over 70% of the UVA as measured with a
spectrophotometer, but not all canopies are not that good.
I have a "sports" UV meter that is calibrated in UV index. It shows
essentially zero UV coming through the canopy on my ASH 26 E. While it's
not a calibrated spectrophotometer, it suggests sitting inside the
cockpit is a lot safer than standing around outside it.
Practically speaking, I think if you are properly protected with
clothing and sunscreen for the rigging and waiting in the towline, you
have more than sufficient protection while flying.
Eric Greenwell - Washington State, USA (netto to net to email me)
Old March 26th 10, 07:14 AM posted to rec.aviation.soaring
brianDG303[_2_]
On Mar 25, 9:10*pm, Eric Greenwell wrote:
beware. * Handily, there are now some clothing products like long
* Consumer Reports and many other reputable sources says it does an
I use a Littlemore Scientific UV meter that was developed at Oxford
University to measure UV transmission through different materials and
in spaces where art is displayed and I believe it to be very accurate.
It reads out in mW/M² or µW/lumen and it is mW/M² we are concerned
with here. I once took it out to the airport and expected to see very
little UV transmission through the canopies, based on past experience
with UV through plastic. What I found was that mostly the nicer newer
gliders had canopies that stopped almost all UV, but some of the older
gliders had canopies that let in more than seemed safe, there was an
LS1 with a replacement section that was transparent to UV. The
spectrum of UV you want to block is everything above 420nm or so if
possible.
Tinting can be misleading as I have seen tinted glass before that
reduced visible light without affecting the UV and that is a worst
case situation, as the tinting leads you to think there is protection
when there isn't. However in glider canopies I suspect tinting means a
higher quality product and that would tend to have more UV doping. I
don't think the manufacturers are primarily concerned with human
health as much as the life span of the plastic, the addition of UV
doping agents protects the plastic from the sunlight and blocks UV as
a side benefit. As has been stated the problem is going to be while
rigging and not flying for most of us in newer gliders.
Brian
Brian
Brian
Old April 4th 10, 06:13 AM posted to rec.aviation.soaring
2G
The portion of the UV spectrum that causes burning is 320 nm and
below. Plexiglas filters 98-99% of these frequencies. I have literally
spent hours in my DG at altitudes above 15k w/o any sunburn
whatsoever. I have, however, been severly sunburned on a mountain at a
few hours under 9k. Your greatest UV exposure is the time you spend on
the ramp, before and after you fly. Bewa long sleeve shirts may be
a poor UV filter, so back it up with sunscreen. You can improve your
clothings protection with Sunguard detergent (https://
sunguardsunprotection.com).
Tom
I use a *Littlemore Scientific UV meter that was developed at Oxford
possible.
Brian
Brian
Brian- Hide quoted text -
- Show quoted text -
Increased life expectancy for Antares drive battery Andor Holtsmark[_2_] Soaring 21 December 15th 08 03:22 PM
Ways of Getting The Lowest Possible Life Insurance Rates.( lowestlife insurance rates) [email protected] Piloting 0 March 23rd 08 10:21 AM
Status of NPR for increased currency requirements Robert M. Gary Instrument Flight Rules 1 January 17th 08 01:43 PM
Volcanic Activity Key To Oxygen Rich Increased Production Michael Baldwin, Bruce[_2_] Products 8 September 2nd 07 06:42 AM
Advertisment Increased the range Paul Buchanan Soaring 0 July 28th 06 07:32 AM
