Hi,
My awesome cable manufacturer Larry Goddard is having a very difficult time obtaining new power/data connectors for Compaq Aero 1500 units. Does anyone know of a current source for them? Does anyone have any old AeroC-x cables that they are no longer using? I'll give you $10 credit for them. I have customers that need them. I would send them to Larry Goddard for re-manufacture. Best Regards, Paul Remde Cumulus Soaring, Inc. |
On Apr 14, 10:09*am, "Paul Remde" wrote:
Hi, My awesome cable manufacturer Larry Goddard is having a very difficult time obtaining new power/data connectors for Compaq Aero 1500 units. Does anyone know of a current source for them? Does anyone have any old AeroC-x cables that they are no longer using? *I'll give you $10 credit for them. *I have customers that need them. *I would send them to Larry Goddard for re-manufacture. Best Regards, Paul Remde Cumulus Soaring, Inc. Probably more work than most want to go through, but I buy USB Sync/ Charge cables from Semsons (online) for about $5.00 a piece. The wiring for serial vs USB is completely different, so you have to open the connector, de-solder, then resolder the wires to the appropriate pins (pinouts available online too). Unless you have exceptional vision, be prepared to work under a magnifying light! I cut off the USB end and wire a DB9 for my Cambridge (standard RS232), easy. The $5.00 cable is a little longer than 1 meter, which is nice for my setup. http://www.semsons.com/usbhoandchca5.html |
On Apr 14, 11:06*am, Grider Pirate wrote:
On Apr 14, 10:09*am, "Paul Remde" wrote: Hi, My awesome cable manufacturer Larry Goddard is having a very difficult time obtaining new power/data connectors for Compaq Aero 1500 units. Does anyone know of a current source for them? Does anyone have any old AeroC-x cables that they are no longer using? *I'll give you $10 credit for them. *I have customers that need them. *I would send them to Larry Goddard for re-manufacture. Best Regards, Paul Remde Cumulus Soaring, Inc. Probably more work than most want to go through, but I buy USB Sync/ Charge cables from Semsons (online) for about $5.00 a piece. *The wiring for serial vs USB is completely different, so you have to open the connector, de-solder, then resolder the wires to the appropriate pins (pinouts available online too). Unless you have exceptional vision, be prepared to work under a magnifying light! *I cut off the USB end and wire a DB9 for my Cambridge (standard RS232), easy. *The $5.00 cable is a little longer than 1 meter, which is nice for my setup.http://www.semsons.com/usbhoandchca5.html OOPS! Sorry, disregard. I'll be taking reading comprehension 101. |
On Apr 14, 10:09 am, "Paul Remde" wrote: Hi, My awesome cable manufacturer Larry Goddard is having a very difficult time obtaining new power/data connectors for Compaq Aero 1500 units. Does anyone know of a current source for them? Does anyone have any old AeroC-x cables that they are no longer using? I'll give you $10 credit for them. I have customers that need them. I would send them to Larry Goddard for re-manufacture. Best Regards, Paul Remde Cumulus Soaring, Inc. Probably more work than most want to go through, but I buy USB Sync/ Charge cables from Semsons (online) for about $5.00 a piece. The wiring for serial vs USB is completely different, so you have to open the connector, de-solder, then resolder the wires to the appropriate pins (pinouts available online too). Unless you have exceptional vision, be prepared to work under a magnifying light! I cut off the USB end and wire a DB9 for my Cambridge (standard RS232), easy. The $5.00 cable is a little longer than 1 meter, which is nice for my setup. http://www.semsons.com/usbhoandchca5.html For what it's worth, I recently ordered a Siamesed cable with a 12 volt cigar lighter jack on one end, and one cable to a 9 pin serial female connector with 5 volt supply pin built in, and another cable to the older style Garmin female four pin connector. The implication for me is that these combinations can be found if the search is conducted on eBay etc.... Brian W |
| Thread Tools | |
| Display Modes | |
| Seeking Compaq Aero 1500 Pocket PCs | Paul Remde | Soaring | 0 | March 25th 10 10:02 PM |
| Seeking 2 Compaq Aero 1550 PDAs | Paul Remde | Soaring | 0 | November 13th 09 10:26 PM |
| WANTED: Compaq Aero 1550 | WaltWX | Soaring | 12 | March 20th 08 05:10 PM |
| Serial Connector for Compaq Aero 1500 series | [email protected] | Soaring | 1 | April 16th 05 03:58 PM |
| Compaq Aero 1500 Cradle | PENN2P | Soaring | 1 | October 18th 04 07:04 PM |
