Older Jab - thoughts
Old April 23rd 10, 11:44 PM posted to rec.aviation.homebuilt
Paul Folbrecht
Default Older Jab - thoughts
How would you react to a Jabiru 2200 with these characteristics:
- Build in 95 (sn #60)
- 125h TT
- NEW cylinders & pistons in 2004 (larger fins)
- NEW conrods in 2008, including replacement of all seals & gaskets in
the low end
Such an engine is past the time-based TBO. Is it equivalent (value-
wise) to a run-out core?? Or is it closer to a 2004 engine with 125
TT??
Old April 24th 10, 02:39 AM posted to rec.aviation.homebuilt
Peter Dohm
"Paul Folbrecht" wrote in message
- 125h TT
the low end
TT??
I admit to being something of a novice, especially regarding the Jab--even
though I have been very impressed with their specs--but I would have VERY
serious reservations about that one!
Basically, I can not imagine a sensible reason that the connecting rods
would ever be newer than the pistons in any internal combustion engine.
That leaves me with the impression that thare is something very wrong with
the story. If your local swamp is free of alligators, crocodiles and water
mocasins; it should be a decent engine for a very small airboat. Otherwise,
I would probably just use it as a mock up for cowling dimensions; and weight
and balance during construction.
Just my $0.02
Peter
Old April 24th 10, 03:00 AM posted to rec.aviation.homebuilt
Paul Folbrecht
- 125h TT
the low end
TT??
the story. *If your local swamp is free of alligators, crocodiles and water
mocasins; it should be a decent engine for a very small airboat. *Otherwise,
Just my $0.02
Peter
I should have said - the rods were replaced for a reason - the new
ones are better. There was nothing wrong with the engine or the old
rods. All of this work was done at Jabiru U.S. headquarters.
There is probably really no good answer to my question, I think.
Nobody is going to be able to say with any certainty how to value this
engine.
Old April 24th 10, 11:35 PM posted to rec.aviation.homebuilt
Peter Dohm
- 125h TT
the low end
TT??
Jab--even
with
water
Otherwise,
weight
Just my $0.02
Peter
engine.
Well, I'm still not quite sure how connecting rods in a 3200 rpm, carbureted
and normally aspirated engine can be enough better to justify the expense;
but, if Jabiru US headquarters did the work, then it certainly looks like
the engine was healthy and in very nearly rebuilt condition only two years
ago. Presuming that I read what you wrote correctly, it would strongly
suggest that the engine was recently pretty close to the far end of the
spectrum from where I presumed.
All the best.
Peter
Old April 27th 10, 01:25 PM posted to rec.aviation.homebuilt
Mark
- 125h TT
the low end
TT??
If the factory signed off on it, then what's the
problem?
Older Bo's The Weiss Family Owning 13 July 13th 04 06:34 PM
Older airframes Jim Naval Aviation 14 June 27th 04 09:31 AM
Older Pilots and Safety Bob Johnson Soaring 5 May 21st 04 02:08 AM
New law for older airplanes? Jim B Owning 25 May 13th 04 09:26 PM
Older versions of X-plane Fred the Red Shirt Simulators 0 March 20th 04 10:23 PM
