Good news and bad news about SPOT 2 devices
Old April 29th 10, 06:29 PM posted to rec.aviation.soaring
Frank[_12_]
Default Good news and bad news about SPOT 2 devices
The good news:
As has already been reported, is the new SPOT 2 devices have a nice
'check-in while tracking' feature that lets you send an OK message
while in TRACK mode. The OK message temporarily interrupts the TRACK
message mode, sends the message, and goes back to tracking.
The new SPOTs have a more powerful transmitter and slightly better
patch antenna, for more reliable transmissions.
Smaller size, lighter weight.
Much easier to get the device into TRACK mode (the old SPOT 1 devices
require a very non-intuitive procedure, but once you know the trick it
isn't too bad)
The bad news:
The higher power transmitter and smaller form factor reduces
advertised battery life significantly. The old SPOT 1 devices (2 AA
lithiums) will go several weeks/months between battery replacement. I
think I replaced mine twice last season, and I flew 9 contests and 250
hours. The new SPOT 2 devices (3 AAA lithiums) appear to only last
about a week in TRACK mode, so you might have to replace them about
every contest.
Any SPOT 2 users out there with actual battery life data?
TA
Old April 29th 10, 07:27 PM posted to rec.aviation.soaring
Westbender
Are you using the "replacement" or the "original" Spot 2?
One of the reasons for the replacement program was power consumption.
I have a replacement unit, but I haven't used it yet. Just curious.
Old April 29th 10, 10:32 PM posted to rec.aviation.soaring
Darryl Ramm
To be anal-retentive clear on this, I don't believe that the issue was
power consumption per se, but rather an incorrect low battery warning
so people would be lead to change batteries earlier than necessary.
AFAIK there was no mod to improve actual battery consumption (just the
apparent consumption). See for example Doug Ritter's comments at
http://www.equipped.org/blog/?p=172
If somebody knows for sure else wise speak up...
It is a pity with the SPOT 2 that the hiker/general user etc. goal of
making the device smaller overrode long tracking battery life. I've
still got the original SPOT and never really had significant dropped
tracking message problems and am not sure I'll upgrade.
Darryl
Old April 30th 10, 11:44 PM posted to rec.aviation.soaring
Ramy
My SPOT1 batteries need replacement after more than a year (over 300
hours). So even if SPOT2 needs more frequent battery replacement it
may not be a real issue for most pilots.
Ramy
Darryl
Old May 1st 10, 04:34 AM posted to rec.aviation.soaring
Frank[_12_]
Ramy
Darryl
Hmm, I have no direct experimental evidence regarding SPOT 2 battery
life. However, Fernando Silva had a new one at Perry, and he had to
replace the batteries after just a few days. The SPOT website quotes a
battery life of between 3.5 and 7 days in tracking mode, and the SPOT
customer service representative I spoke to acknowledged that the SPOT
2 devices do have shorter battery life 'due to the stronger
antenna' (which I interpret as higher transmit power).
I am sticking with my old SPOT 1clunker - I know how to get it into
track mode reliably, and I only have to change out batteries once or
twice per soaring season ;-).
TA
Old May 1st 10, 06:57 AM posted to rec.aviation.soaring
Ramy
Ramy
Old May 12th 10, 07:43 AM posted to rec.aviation.soaring
Ramy
While I can't report yet on battery life, I can report after a couple
of 4-5 hours flights with SPOT2 that I have zero misssing
trackpoints, although it is strapped to my parachute and do not have a
complete clear view of the sky. I used to see at least 10% drop with
my original spot. I can't tell if this is thanks to the better
transmission/antena, or thanks to sending multiple trackpoints with
each transmission.
Ramy
Ramy
Darryl
life. *However, Fernando Silva had a new one at Perry, and he had to
TA- Hide quoted text -
- Show quoted text -
I just upgraded to Spot 2 so I'll be able to report on it later, but
my manual says 7 days in track mode which is 168 hours, or 30 flights
averaging about 5 hours per flight. for someone who fly mostly
weekends this means replacing once or twice per season. I hope in
reality it will be at least as good as the manual says, in the case of
Spot 1 it was even better than the manual.- Hide quoted text -
The news is in. It's not good for the FAA Mike Instrument Flight Rules 0 June 23rd 09 09:16 PM
Freedom Wings Spot on NBC Nightly News [email protected] Soaring 3 October 25th 07 05:13 PM
No news Is Good news? Pete Reinhart Soaring 5 September 23rd 06 06:23 PM
(",) .............. Good News Everyone! .............. [email protected] Owning 0 January 26th 05 10:56 PM
Weak Dollar (Bad News - Good News) JJ Sinclair Soaring 6 January 27th 04 04:06 AM
