Use of 1201 Transponder Squawk for Salt Lake City TRACON
Old June 6th 10, 04:55 PM posted to rec.aviation.soaring
Dan Thirkill
Default Use of 1201 Transponder Squawk for Salt Lake City TRACON
For pilots flying within the SLC area, use of the 1201 'glider' transponder
sqauwk is now implemented.
Update received from TRACON personnel confirms hardware and software system
configurations now permit recognition of the unique code.
Enjoy-
Dan Thirkill,
SSA Governor for UT
Old June 6th 10, 06:39 PM posted to rec.aviation.soaring
"Dan Thirkill" wrote in message ...
Enjoy-
Dan Thirkill,
SSA Governor for UT
Dan,
Here is a question that shows my ignorance. Does this imply "as SLC TRACON goes, so go all facilities under the purview Salt Lake Center?" (Just wondering for those of us flying in the Boise area; and, those flying out of Mackay, ID and the King Mountain Glider Park near Moore, ID.)
HP-14 "6F"
http://www.soaridaho.com/
Old June 6th 10, 09:22 PM posted to rec.aviation.soaring
Dan Thirkill
Wayne,
A reasonable question- unknown...
I'll see what I can find out-
"Wayne Paul" wrote in message
m...
transponder
system
Enjoy-
Dan Thirkill,
SSA Governor for UT
Dan,
HP-14 "6F"
Old June 7th 10, 09:01 AM posted to rec.aviation.soaring
Mike the Strike
I presume this will also be valid for the Sports Class Nationals at
Parowan the week after next?
Old June 7th 10, 05:34 PM posted to rec.aviation.soaring
Darryl Ramm
Why presume anything? If unclear keep using 1200.
I would be surprised if SLC TRACON has any coverage of the Parowan
local area. And there may be military radar coverage to worry about as
well within the broader Utah area,
Around Reno for example, even though Reno Approach was set up and
eager to use the new squawk code the overlaying Oakland ARTCC was not,
and they provide SSR radar coverage for transponder equipped gliders
in nearby wave windows - so an important saftey issue.
Hopefully people dealing with these things are thinking about these
type of issues. Announcements like the one here for SLC TRACON need to
include the area covered and proceedures say for transiting out of
that area.
Darryl
The
Old June 7th 10, 05:46 PM posted to rec.aviation.soaring
Mike the Strike
Flights from Parowan will transition into SLC's area, but also
others. This leaves us with the situation where you should apparently
change your squawk code as you complete a cross-country task, a
nonsensical proposition for folks who are not talking to controllers.
This needs clarification.
I almost never use 1200 - we have been allocated 0400 by Tucson.
Old June 7th 10, 06:40 PM posted to rec.aviation.soaring
Tim Taylor
others. *This leaves us with the situation where you should apparently
Mike,
You are correct, the Parowan contest sits on the boarder between ZLC
and ZLA for the most part. If I had a transponder I would likely set
it on 1200 and leave it. We have not heard if ZLA is ready for the
1201 code. The 1200 code will get the same recognition, they just
won't be sure you are a glider. To be honest most of the area we will
be flying does not get great terminal services from either facility
unless you are very high.
Old June 8th 10, 04:14 PM posted to rec.aviation.soaring
danlj
I just checked with Todd Ammerman (sp?) of ZMP (Minneapolis Center),
who said that center does not yet know about the code.
It's incredibly easy to telephone the folks at the regional center and
ask if they've implemented it. Is there a technical FAA reference we
can offer when contacting them?
DJ
Old June 8th 10, 04:52 PM posted to rec.aviation.soaring
Frank Whiteley
DJ
http://www.faa.gov/documentLibrary/m...110.66D%20.pdf
See Appendix A, Table A-1. Changes are bolded.
During my phone conversation with ZDV yesterday, found they've
actually been ready since April. I was letting a volunteer track this
as he had been trying to negotiate a glider code on the front range
for some time.
I called center and the appropriate person called me back within two
hours. He was also very interested in the Mitre corporation low cost
ADS-B project which we discussed briefly. He fully encourages glider
pilots to use the 1201 code.
Frank Whiteley
Old June 8th 10, 05:44 PM posted to rec.aviation.soaring
Darryl Ramm
DJ
See Appendix A, Table A-1. *Changes are bolded.
actually been ready since April. *I was letting a volunteer track this
for some time.
hours. *He was also very interested in the Mitre corporation low cost
ADS-B project which we discussed briefly. *He fully encourages glider
Frank Whiteley
And in the Colorado case it sounds like the ARTCC folks already knew
that underlying TRACON/Approach radars are all configured for 1201.
I'm not sure if there are any military RAPCON, etc. in the area that
gliders ever use, but can be worth checking with those as well. In
other areas I hope people having that conversation explicitly ask the
ARTCC folks if they know the situation with all the TRACONs/Approach
radar sites covered by that ARTCC.
Darryl
1201 VFR Glider Code - Approved PHL-ABE-NY Tracon RL Soaring 0 April 13th 10 08:47 PM
Chicago Tracon, Glider Code 1201 Herb Soaring 1 April 7th 10 01:06 AM
1. GA books, 2. Salt water Lake? doylflier Piloting 0 May 23rd 07 08:49 PM
OT. Weather in Salt lake City? Eduardo K. Piloting 12 May 13th 06 06:34 PM
I'm looking for a pilotshop near San Francisco, Salt Lake City, or Las Vegas Alfa Bravo Piloting 2 March 20th 06 10:00 PM
